brake over ride fail
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S.B., Dec 5, 2010.
  1. Dec 5, 2010 at 11:45 PM
    S.B.
    S.B. [OP] Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I tested the brake over ride that was suposed to be programed in to the ecu when they put in the new pedal, but it failed miserably.
    Here is what I did (multiple times): I was driving (20ish), then I floored it, then hit the brakes. All it did was apply the brakes and engine still floored. So toyota you failed, just saying.
    I really don't care for this "feature" that was supposed to be programed into the truck. I kinda find it funny that toyota failed at something where they just plug it into the computer (or maybe they didn't plug it in?).
  2. Dec 6, 2010 at 4:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you sure it was programmed into the truck?
    I've had two different dealerships tell me different things. One dealership said it was reprogrammed and the other said the tacomas weren't affected by that part of the recall.
    I've tried it on my truck a couple times and my truck did 'stumble' a bit. I'm just not exactly it was in affect. It's kinda hard to have both feet on pedals, watch where you're driving & watch the tach all at the same time (in the situation I was in). :notsure:
    Based on what I've tried, I'm uncertain if something was reprogrammed or not. Just didn't seem 'obvious' enough(to me) to know anything was working.
  3. Dec 6, 2010 at 4:55 AM
    river rat
    river rat Tool Geek
    Midwest
    '11 Timberland Mica regular cab.
    I thought the Tacoma version of the recall was just to replace the floormat as a safety. I was told verbally by the local dealer service manager that Tacomas never had the unintended acceleration problem like some other models.
  4. Dec 6, 2010 at 5:52 AM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    When I had the recall performed they said it was 3 step- cut the pedal, remove the extra padding behind the pedal, and install the brake override software.
  5. Dec 6, 2010 at 5:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    You performed the test wrong. It should activate when the the pedal is not floored (up position) yet the throttle is pegged and the brakes are hit. The ECM has to sense a discrepency in the the Pedal Position in relation to the Throttle Position.
  6. Dec 6, 2010 at 6:01 AM
    Quakee
    Quakee Well-Known Member
    Eddie
    (LA) Tujunga, CA
    2010 TRD Off-Road 4x4
    Toytec ultimate lift kit, Total Chaos UCAs, spidertrax spacers, mudflaps removed, 4wd badge where "prerunner" usually goes, wicked flow 13" muffler, sound ordnance b-8pt sub-woofer.
    Wow, that's good news. Now I know I can torque brake if I ever want to. Dunno why I would, but it's nice to know I can =]
  7. Dec 6, 2010 at 7:06 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  8. Dec 6, 2010 at 7:17 AM
    98tacoma27
    Ben
    Not Beech Creek
  9. Dec 6, 2010 at 8:42 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  10. Dec 6, 2010 at 9:35 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I tried it on my wifes Camry before we traded it....actually on the way.. I could not get it to work, and it was flashed.. I might have done it wrong.
  11. Dec 6, 2010 at 12:54 PM
    S.B.
    Sean
    San Diego
    15 Taco
    They said they would program it in to the system as that was part of the recall.
    To me they said that they just cut/replace the pedal, then update the ecu which includes the brake over ride.
    I had the pedal pushed all the way down to the floor, so it did not move, I then hit the brakes hard and all it did was keep it at full throttle and put on the brakes hard.
    Ps: I will now read that article you posted.
  12. Dec 6, 2010 at 12:57 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I see, I am pretty sure that I was pressing the brakes for more than a 1/2 second, but I will try it again and take account of how long I press the brakes for.
  13. Dec 6, 2010 at 12:59 PM
    S.B.
    Sean
    San Diego
    15 Taco
    The Brake Override System is not active in
    4WD vehicles while driving in low range.
    Got this off the article. ( yes I was in 2 hi going fastish)
