Brake pedal goes to floor after turninng left??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jah8551, Oct 18, 2013.
  1. Oct 18, 2013 at 10:01 AM
    jah8551
    jah8551 [OP] Active Member
    Jeff
    Central NY
    06 Access Cab TRD Offroad
    6" Pro Comp lift, adjustable coilovers, 35's, BHLM, K&N air intake system, rock sliders, tinted windows, tonneau cover
    Ok, so I am at a loss here. I installed a new steering rack yesterday, and when I finished I took it out for a drive. Everything was fine except the alignment was a little off. So when I got home I aligned it straighter and took it out again. This time when I took a left turn my brake went to the floor. I checked my lines and they weren't leaking any fluid and when I pumped the brakes a few times they went back to normal. I also checked the lines with the wheels turned all the way and don't see any binding. Anyone have any suggestions on what it could be?
  2. Oct 18, 2013 at 10:04 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    I don't know why it would do that, but I suggest you make like a UPS driver and only turn right for a little while.
  3. Oct 18, 2013 at 10:07 AM
    SGT Taco
    SGT Taco Disco Disco...
    Scott
    Rio Rancho Nm.
    R.I.P. 2007 TRD... Now a Land Rover Disco II
    Wife rolled it 3x mod...
    What if he is a nascar driver???
  4. Oct 18, 2013 at 10:10 AM
    jah8551
    Jeff
    Central NY
    Haha no nascar here but on my way to work I make mostly left turns
  5. Oct 18, 2013 at 11:25 AM
    jah8551
    Jeff
    Central NY
    OK so here's an update, still have no idea what is causing it, but when I lifted the front and took wheel off it doesn't do it, then I put jack stand under control arm to put weight back on it and it does it.
  6. Oct 18, 2013 at 12:15 PM
    jah8551
    Jeff
    Central NY
    Well I found the problem, its just a coincidence that it happened right after changing the rack, the passenger side wheel bearing is shot and when turning the wheel it would push the caliper in.
  7. Oct 18, 2013 at 12:19 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    That's interesting. Glad you found it.
  8. Oct 18, 2013 at 12:32 PM
    BamaToy1997
    Bill
    Navarre, FL
    I can help you with the wheel bearing problem. lol. Just click my link in my sig!
  9. Oct 18, 2013 at 12:53 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Beat me to it lol.
  10. Oct 21, 2013 at 10:17 PM
    jah8551
    Jeff
    Central NY
    I might have to take you up on that, I just replaced it 2 days ago and the new one is already shot, don't know if its something I did wrong or if it was a faulty bearing.
