Brake rotors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ahougland89, Aug 24, 2016.
  1. Aug 24, 2016 at 7:49 PM
    Ahougland89
    Ahougland89 [OP] Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    need new rotors bad, what do you guys suggest? I run them pretty hard on logging roads etc... Thanks for the suggestions
  2. Aug 24, 2016 at 10:44 PM
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    I went with EBC rotors and pads. Noticable difference in stopping power compared to stock.
    urban likes this.
  3. Aug 24, 2016 at 10:58 PM
    Ahougland89
    Anthony
    Orting, Washington
    Did you get the green stuff or red stuff pads?
    I'm getting some pretty damn good shaking when I'm braking and I'm pretty sure it's warped weak les shcwab rotors
  4. Aug 25, 2016 at 1:28 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    On my last brake job on my 1st gen I did OEM rotors and Wagner thermo quiet ceramic pads. They made a noticeable difference with less dust. Just my .02.
  5. Aug 25, 2016 at 1:41 AM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Check all the warped rotor threads on here before you go diving into expensive rotors. There are several causes for rotor run out and I can almost guarantee it's not because one or both are "warped". You can run OEMs or EBCs but if you abuse them you're going to have vibrations again. Along with that I'd encourage replacing pads with the rotors so they can bed in together to prevent squeals and (hopefully) vibrations in the future.
    http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths
    As for your question-spend what you want. Your break in process and your driving habits will have a bigger outcome on your braking system.
  6. Aug 25, 2016 at 5:36 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    Upgrade to Tundra brakes.
  7. Aug 25, 2016 at 5:40 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  8. Aug 25, 2016 at 7:01 AM
    Tacoma005
    Bellingham, WA
    I got the the Extra Duty pads for light truck and SUV. Also got the Ultimax slotted rotors.
  9. Aug 25, 2016 at 7:09 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I'm running StopTech (aka Centric) slotted rotors and have been impressed with their performance. These rotors/calipers are about as big as they can be while still fitting inside a 16" wheel.
    The StopTech rotors also come with an E-coat on the hat surfaces and internal vanes to prevent corrosion. Many other brands lack this.
    2nd gen Tacoma brakes are already the same size as 1st gen Tundra brakes. An "OEM" upgrade path would be 4Runner Limited brakes, but then you won't be able to run 16" wheels.
  10. Aug 25, 2016 at 7:31 AM
    uf20wop
    uf20wop Well-Known Member
    Greg
    PBG, FL
    2013 Super White DCSB TRD OR
    never had a problem with centric rotors on any of my cars
  11. Aug 25, 2016 at 11:54 AM
    Ahougland89
    Anthony
    Orting, Washington
    Well I went with the EBC premiUm rotors and yellow stuff pads. Almost bought the slotted rotors but decided just to stick with blanks
  12. Aug 31, 2016 at 8:09 AM
    Titus139
    Titus139 Well-Known Member
    Tim
    NorCal
    2011 Tacoma DCLB
    By chance would you have the part number of the StopTech Rotors you purchased? I'm about to upgrade and I've heard great things about the StopTech.
  13. Aug 31, 2016 at 8:24 AM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    Any recommendations on ceramic pads to pair with StopTech Rotors? Looking to upgrade very soon. Thanks.
  14. Aug 31, 2016 at 10:14 AM
    KenLyns
    Belly of the Beast
    I ordered everything on Rock Auto:
    Centric/Stoptech/Power Slot P/Ns for the rotors:
    12644129SL (picture on Rock Auto incorrectly shows brake shoes)
    12644129SR
    I also picked up the hardware kit (pad retention pins and anti-rattle clips) P/N 11744075
    For pads I recommend Akebono ASP976.
  15. Aug 31, 2016 at 6:27 PM
    Titus139
    Tim
    NorCal
    2011 Tacoma DCLB
    Thanks man. Much appreciated.
  16. Aug 31, 2016 at 6:46 PM
    Scrubber3
    Scrubber3 Not really here
    2016 T4R XP 4X4 MS
    Careful with slotted rotors and mud/ debris.
    4x4cajun likes this.
