Brake Shims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ilovetacos, Oct 16, 2011.
  1. Oct 16, 2011 at 1:41 PM
    ilovetacos
    ilovetacos [OP] Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Should I use the new shims that came with the Durlast pads or reuse the OEM shims?
    Just asking for opinions as I know our brakes can be picky about movement and squealing.
  2. Oct 16, 2011 at 1:44 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i would say the old ones seeing that on the old ones where it contacts seem bigger than the plate on the new ones
  3. Oct 16, 2011 at 1:58 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    I tried taking off the Duralast shims but they appear to be glued down. Can I use the OEM shims over the Duralast shims? And should I use both OEM shims or just one.
  4. Oct 16, 2011 at 1:59 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Pic of the OEM shims
  5. Oct 16, 2011 at 2:01 PM
    johnw
    john
    orlando florida
    Hmm I'm not completely sure hopefully somebody will chime in
  6. Oct 16, 2011 at 2:11 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    the new shims have that coating on them to help stop squealing... if you put the old ones over the new ones you might not have enough room with the added thickness.
    that being said, id use the new ones only and add a bunch of brake lube on them
  7. Oct 16, 2011 at 2:23 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    You are correct...I can't get both of the OEM shims in but can get 1 of them in with the Duralast pads.
    So should I got with no OEM shims or 1 shim :confused:
    Thanks in advance!
  8. Oct 16, 2011 at 2:28 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    I personally would just use the one that came on the pad.... dont sweat the details.
  9. Oct 16, 2011 at 2:28 PM
    Burgman
    Stephen
    Ric VA
    use the new shims, dont want to mix and match
  10. Oct 16, 2011 at 2:34 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Ok, got it. Thanks guys! :cheers:
  11. Oct 16, 2011 at 3:48 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    just use the new shim and lube the shit out of the contact area make sure you clean it first..................
  12. Oct 16, 2011 at 9:12 PM
    ilovetacos
    Gavin
    Sacramento/Woodland
    Sold!
    Finished the brakes up and all went well. Used the Duralast shims only with a ton of lube and so far so good with no brake squeeling (have only driven about 10 miles). I kept the OEM shims just incase I need them later on down the road. Thanks again for the help.
  13. Oct 16, 2011 at 10:53 PM
    saugus
    saugus Well-Known Member
    Wise. I somehow left out one of my corolla shims on a brake change, and then on the last change I noticed that the pads wore unevenly on one rotor. The missing shim pad was rubbing metal.
