Brake swap from 4th gen into third gen.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rorgan, Apr 30, 2024.
  1. Apr 30, 2024 at 4:20 PM
    rorgan
    rorgan [OP] Well-Known Member
    2022 tacoma TRDOR 4wd
    none yet
    Has anyone figured out if it's possible to swap the brakes from the 4th gen Tacoma onto the third gen Tacoma. I know it's a long shot since the 4th gen is a complete redesign but Toyota does like to carry over in the name of reliability.
    I-Give-Up likes this.
  2. Apr 30, 2024 at 8:12 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    4th gen hub bore is smaller, so 4th gen rotors won't fit on 3rd gen hubs.
    4th gen SR5 rotors are 12.6" dia., while the TRD rotors are 13.4" dia. The standard 4Runner rotors for the past 14 years have been 13.3" dia., so that's an equally beneficial upgrade path with plug-n-play parts: https://www.tacomaworld.com/threads...unner-bbk-upgrade-for-2nd-gen-tacomas.504234/
  3. Apr 30, 2024 at 10:26 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    why?
    oconnor, TS4x4, kahanabob and 6 others like this.
  4. Apr 30, 2024 at 11:01 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    This^^^
    kahanabob likes this.
  5. Apr 30, 2024 at 11:05 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
  6. May 1, 2024 at 4:32 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    never felt that i needed more braking power in the rear
    soundman98, RIX TUX, oconnor and 5 others like this.
  7. May 1, 2024 at 5:17 AM
    abou824
    abou824 Well-Known Member
    Aidan
    Central PA
    '21 TRDOR Army Green 6MT, '13 Lexus RX350
    TRD Lift (Toyota 5100's) LT265/75 AT4W Method MR305 16x8 Bronze ARB Diff Breather Subaru Tweeters Garmin Dash Cam Clutch accumulator delete plate Vibration dampers on MT driveshaft shield
    When I got my 3rd gen I planned on doing a rear caliper swap almost immediately. After driving it I put it off and ~2yrs later I don't see the need. The drums are perfectly fine for me even when towing 5klbs, offroading, road tripping, etc.
  8. May 1, 2024 at 5:44 AM
    wake100
    Syracuse, NY
    I mean... towing that much youre usually required to have brakes on the trailer...
    abou824[QUOTED], RIX TUX and Chew like this.
  9. May 1, 2024 at 5:46 AM
    abou824
    Aidan
    Central PA
    Good point, mostly used the U-Haul surge brakes when towing my car. Even so that's even more reason to not need a brake upgrade LOL.
    Chew likes this.
  10. May 1, 2024 at 8:57 AM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Some people just can't leave well enough alone.
    RIX TUX and kahanabob like this.
  11. May 1, 2024 at 10:00 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    especially around these parts.
    Hackin' up a new truck to get those clicks, likes, and shares!
  12. May 1, 2024 at 10:35 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    We need a button "No Like" to comment
    RIX TUX and Chew[QUOTED] like this.
  13. May 1, 2024 at 10:49 AM
    sublimaze
    sublimaze Well-Known Member
    True…but one could argue that you can’t have too much braking power (assuming no wheel lockup).
  14. May 1, 2024 at 10:58 AM
    Cetacean Sensation
    Cetacean Sensation Never lost in a parking lot
    PNW
    6MT ELM Taco (slow) // N54 BMW 135 (fast)
    But that's the thing. The stock 3rd gen brakes are already enough to lock the tires.
    Bigger brakes are only good for repeated high-speed stopping, and this is a truck, not a sports car.
    oconnor, TS4x4 and Chew like this.
  15. May 1, 2024 at 11:10 AM
    sublimaze
    I don’t tow anything, but I suspect that if you have 5000 lbs rolling behind you, it’s harder to lock up the brakes (even if the trailer has its own brakes). I could be wrong.
  16. May 1, 2024 at 11:31 AM
    Cetacean Sensation
    PNW
    It's actually easier to lock the front's while towing. Tongue weight moves the truck's effective CG way back, and the trailer reduces weight transfer to the truck's front wheels under braking.
    sublimaze[QUOTED] likes this.
  17. May 1, 2024 at 11:53 AM
    sublimaze
    Ah, that makes sense. You learn something new every day. Thanks!
    oconnor likes this.
