Brake warnings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KnckleChldrn, Jul 6, 2020.
  1. Jul 6, 2020 at 4:38 AM
    KnckleChldrn
    KnckleChldrn [OP] Well-Known Member
    Jamie
    Mass
    2017 Tacoma TRD Sport DCSB MT
    Suspension OME 886 Coils OME Nitro Charger Sport shocks OME Nitro Charger Sport struts Deaver Expedition leaf pack Mickey Thompson wheels 265/70/17 KO2 Total Chaos upper control arms Performance K&N air intake Exterior Southern Style Offroad slim line bumper Smittybilt x20 winch Interior Kicker tweeters, front and rear speakers Anytime front and rear camera Hondo Garage stereo knobs Hondo Garage un-Holley mount MESO black out door handles MESO steering wheel MGM overlay MESO puddle pods MESO ultimate red map lights MESO ultimate red dome MESO gasshole MESO ultimate turn signals MESO BD5 3rd brake light MESO stage 3 side markers Retrofit Morimoto 2.0 headlights RGB halo RGB demons RGB DRL Cali Raised raptor LED tail lights SpartanXCustoms scoop light Baja Designs Squadron Sports fogs (amber) Baja Designs Squadron Pro ditch (amber) Baja Designs S8 20" Matt Gecko bed lights Matt Gecko hood lights Switchpro 9100 OEM bed mat 300 Industries grill Bakflip Fibermax cover
    I got in and started driving and noticed a “brake override malfunction visit your dealer” light. Then after applying my brakes there was a little jump in my pedal and the ABS light/warning cane on. Any ideas?
  2. Jul 6, 2020 at 7:39 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Were you pressing the brake pedal and gas pedal at the same time?
    Garyji likes this.
  3. Jul 6, 2020 at 9:58 AM
    KnckleChldrn
    Jamie
    Mass
    Not at all. I found a few threads here after I got to work and tried the resetting by going to ignition and off 6 times then stating it back up but the codes were still there.
  4. Jul 6, 2020 at 10:14 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Scan it and get the trouble codes. It'll point you in the right direction.
    Shellshock likes this.
  5. Jul 6, 2020 at 1:33 PM
    KnckleChldrn
    Jamie
    Mass
    So after reading some threads here I checked brake fuseWhen I got out of work. It was blown. I only had a 15 to put in its place. Any thoughts on what would cause the fuse to blow? And is leaving a 15 in there ok?
  6. Jul 6, 2020 at 1:38 PM
    ShimStack
    Ben
    NC
    Sometimes fuses blow because the fuse gives up. If it doesn't happen again I wouldn't worry about it. If it repeats then I'd search for the cause like something shorting or drawing a bunch of inrush current.
  7. Jul 6, 2020 at 1:40 PM
    KnckleChldrn
    Jamie
    Mass
    Thanks I appreciate the help. I figured if it didn’t blow right away first few times hitting the brake it should be safe.
