BRAKES FAILED!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Braveheart44, Jun 9, 2024.
  1. Jun 10, 2024 at 5:17 PM
    #61
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Glad I don't have that.
  2. Jun 10, 2024 at 5:57 PM
    #62
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    It's hydraulic assist with an electric pump. It's on all OR's and Pros whether they have crawl (autos) or not.
  3. Jun 10, 2024 at 6:02 PM
    #63
    ShimStack
    Ben
    NC
    Stiff pedal is not a sign of losing brakes but is a sign of lost assist. If this is the case cramming the brakes with *all* your might is the approach. We have all become too accustomed to applying weak levels of effort with the modern day effort-amplifying boost systems for both braking and steering.
    shakerhood likes this.
  4. Jun 11, 2024 at 1:10 AM
    #64
    Cement_wheels
    Cement_wheels Well-Known Member
    2020 Cement TRDOR DCSB 6M
    I knew something was up the first time I stepped on the brakes when my Taco was in the garage. All kinds of whirring electrical sounds. The brakes on mine have an inconsistent feeling sometimes but never in a dangerous way.
  5. Jun 11, 2024 at 6:47 AM
    #65
    ShimStack
    Ben
    NC
    That's the pump. It keeps the accumulator charged and typically you get a couple brake presses before it runs to recharge. Also, the rear brakes are completely brake by wire unless there's failure in the system then it's manual.
  6. Jun 11, 2024 at 6:50 AM
    #66
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    What? o_O
    Literally only hydraulic lines going back there. Only wiring is ABS sensors.
  7. Jun 11, 2024 at 8:02 AM
    #67
    ShimStack
    Ben
    NC
    Brake by wire means no mechanical link directly to the brakes from your foot, not that it's not hydraulically actuated. The pressure applied to the rear brakes comes from a circuit that is pressurized by a pump and the amount of braking applied is determined by an ecu. If there's a failure in the system it may then allow master cylinder pressure generated directly by your foot to actuate the rear brakes.
    You will learn this when you try and bleed the rear brakes.
  8. Jun 11, 2024 at 8:57 AM
    #68
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i stand corrected.
  9. Jun 11, 2024 at 9:27 AM
    #69
    nds0000
    nds0000 Well-Known Member
    Glad you are ok!
    Were you on dynamic cruise control and did the system brake automatically already? Because if you then try to hit the brakes while the dynamic cc is operating them, it feels like your wood log behind the pedal. Release the brake and press again and it is normal. Not very nice feature by Toyota, scared the living crap outta me the first time it happened.
  10. Jun 11, 2024 at 9:31 AM
    #70
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    OP has 2017
    auskip07 likes this.
  11. Jul 21, 2024 at 8:03 AM
    #71
    JPTx
    JPTx Well-Known Member
    Jon
    East Texas
    2024 4Runner Off-Road
    Any update to this? Was interested in the cause but noticed OP hasn't logged in since June.
    BlackTRD4Me likes this.
  12. Jul 21, 2024 at 9:33 AM
    #72
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    When was the last time you had your front brakes done? So new pads, brake fluid change, etc?
    If still OEM and no brake work ever done, how much pad is left and how many miles on your Taco?
  13. Jul 21, 2024 at 10:18 AM
    #73
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    OP disappeared
    shakerhood, JPTx and tonered like this.
  14. Jul 21, 2024 at 10:29 AM
    #74
    ppat4
    Paul
    Kelowna, BC
    Damn, the case of the disappearing OP.
    rosswood and Chew[QUOTED] like this.
  15. Jul 21, 2024 at 10:31 AM
    #75
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    He probably transitioned to the Honda Ridgeline forum
    shakerhood and Chew like this.
  16. Jul 21, 2024 at 10:45 AM
    #76
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Man. There should be some kind of thing to deal with low post shit disturbers. I don't know if the OP was real or not, but threads like this with no resolution feel wrong.
    Of course, the OP might have gotten some help under NDA?
    JPTx and Chew[QUOTED] like this.
  17. Jul 22, 2024 at 8:48 AM
    #77
    rosswood
    rosswood Well-Known Member
    Ross
    South Florida
    2017 SR5 Magnetic Grey
    Current Build: 18” Level 8 Slam Wheels LT285/65/18 Nitto Terra Grappler G2 Icon Stage 1 Lift Kit 2.75” OME HD Dakar Leaf Springs w/extra leaf Caliraised 32” Hidden Dual Row LED LightBar Caliraised Ditch Lights RCI Offroad Short Bed 12” Rack ROAM Adventure Vagabond RTT
    I saw something like this on here a while back where someone had an aftermarket part around the battery/fuse box area and it ended up chaffing or cutting the brake line leaving no brakes.
    Glad everyone is ok OP. Hope you get it figured out
