Brakes Grinding While In Snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MRAPRIDER, Dec 5, 2007.
  1. Dec 5, 2007 at 7:06 PM
    MRAPRIDER
    MRAPRIDER [OP] Member
    07 TACO DBLCAB TRD OFF ROAD
    Hey guys,
    1st post but very imoprtant imo
    Today maryland got around 5 inches of snow so I wanted to have so fun in my brand new taco. But whenever I hit the brakes in snow I would hear this horrible grinding sound from the truck almost like a metal to metal grinding when I hit the breaks hard. I know the truck was probably slipping just a bit but this sound was ungoldy. IF I hit the brakes softly It would not make that sound. This sound was also very loud and noticable from inside the cabin. It didn't matter if I was in 2wd or 4 it would do this. It almost sounded like tranmission gears were grinding. Now it has abs and electronic brake distrubution and brake force but this sounded above and beyond that.
    It really scared me that my 2 month old truck would make this horrible sound.
    BTW I have a 2007 double cab tao TRD off-road with 2000 miles
  2. Dec 5, 2007 at 7:11 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    2018 TrD Sport Upgrade
    "Hello Kitty" steering wheel cover.
    My first thought would be the ABS system,mine was very noticable in our first snow yesterday.Did you feel any reaction in the brake pedal simultaneously?
  3. Dec 5, 2007 at 7:12 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I've never driven in snow. Do they still salt the roads?
  4. Dec 5, 2007 at 7:16 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    It sounds like it was your anti-lock brakes, to see if it was find road that is not covered in snow and stomp the brakes, listen for screeching tires, also if you can pull a front tire off and check the rotor, that will tell you if you had metal to metal.
  5. Dec 5, 2007 at 7:16 PM
    squad314
    Marc
    Do they ever......My nice black truck is now completely white.:(
  6. Dec 5, 2007 at 7:20 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    Will the salt make the brakes grind when you hit them?
  7. Dec 5, 2007 at 7:27 PM
    MRAPRIDER
    I can feel the reaction in the brake paddle but it sounds so bad. IT sounds like a metal rod is being driven into the transmission but in the brake :eek:
  8. Dec 5, 2007 at 7:30 PM
    concrete jedi
    Rochester N.Y
    They salt the HELL out of the roads up here and I never heard that, pull a wheel.
  9. Dec 5, 2007 at 7:30 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    That's what ABS sounds like when it works.
  10. Dec 5, 2007 at 7:32 PM
    MRAPRIDER
    god my old car with:confused: abs was never this pronounced
    how does you guys cars sound when there is major slippage and you slam the pedal all the way down
  11. Dec 5, 2007 at 7:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im voting that its a mix....a little of the salt on the roads maybe......but more than likely abs doing its job.
  12. Dec 5, 2007 at 7:36 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I took out my Tacoma in a heavy rain just to really feel the ABS. I didn't think it was too bad though.
  13. Dec 5, 2007 at 7:42 PM
    concrete jedi
    Rochester N.Y
    Is it driving ok, any noises while accelerating or highway cruising ?
  14. Dec 5, 2007 at 7:47 PM
    MRAPRIDER
    it drives great no other problems.
    this is the 1st time I have had this problem
  15. Dec 5, 2007 at 7:51 PM
    concrete jedi
    Rochester N.Y
    Did you feel any of the noise through the steering wheel, i.e transfer ? did the steering wheel react to the noise ?
  16. Dec 5, 2007 at 7:53 PM
    MRAPRIDER
    no
    no noise through
    steeringwheel
  17. Dec 5, 2007 at 8:03 PM
    concrete jedi
    Rochester N.Y
    Well I bet it's the ABS, but I realize this is not your first car, you heard what you heard, maybe some of the sound insulation is missing which would make it sound like it's coming apart, make an appt. in the am, i am certain whatever it is it can be taken care of by the wrench at the dealer. While there have him go through the truck and have him point out the highs and lows, do and don'ts. Since this is my first Taco he did this for me and it settled my nerves.
  18. Dec 6, 2007 at 8:29 AM
    squad314
    Marc
    We got snow again overnight and on my way home from work this morning I was thinking about your post.I intentionally turned of the fan and stereo and did some experimenting on some snow covered roads.What I discovered was with the brakes applied hard and the ABS system engaged fully,there were two distinct sounds.The first is a whirring that appears to coincide with the brake pedal pulse reaction.The second was a louder higher pitched sound that seemed to be coming from higher in the dash perhaps near the base of the steering column.My guess is that this is the actual ABS control unit.The harder the brake was applied,the louder the second noise seemed.
    Again,I may be off base with what you are describing,but in my case all seemed normal,but it deffinitely sounded different than my last truck.I would imagine that every vehicle sounds and reacts uniquely when the ABS is activated,and this is what the Tacomas do.Incidently,I think we have the exact same model of truck as well...'07,double cab,4x4,TRD,two months old.On this note,I think concrete jedi is right on the money about having your dealer go over it with you.It may ease your mind as far as ..."this is what they do" vs "Oh,oh,thats not right".
    Hope this helps.
  19. Dec 6, 2007 at 1:46 PM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Last evening I went to my Toyota Dealers New Owners Clinic and thats exactly how the Toyota Tech described how the ABS system reacts on slipery pavement:D
    Not to worry, they will all do that! ! Good Luck with your toy and enjoy it:)
    Don G
  20. Dec 6, 2007 at 2:52 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
    Have no doubt! Its your ABS. No worries, enjoy your ride, Eat Steak :hungry: and sleep well. Oh, and make fun of the Carolina Alliance.
