Brakes were a easy change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Jul 22, 2008.
  1. Jul 22, 2008 at 8:45 AM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    Changed the brakes yesterday and the 2001 tacoma has to be the easiest brakes I have ever changed. I think anybody with a little mechanic skill can do this. I also changed out the drivers lower ball joint, but had my father-n-law to help me. He is a retired mechanic and still has alot of the tools you need. Was suprised that ball joint used mostly standard sockets to change. On the brakes you don't have to remove the calibers off the rotor at all. Take off the anti-ratler and remove the two pins, push back the calibers and remove the pads, resert the new pads and put pins back in and your done. Rick
