Brakes what the F!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Critter, Aug 6, 2007.
  1. Aug 6, 2007 at 11:20 AM
    Critter
    Critter [OP] Well-Known Member
    Man don't like the mushy pedal,sometimes goes down and my big foot hits gas pedal. Anybody else have same problem? this is an 07 Crew 4x4:(
  2. Aug 6, 2007 at 11:42 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    i felt that on the truck i test drove but the one i actually bought feels fine. i think it varies from truck to truck
  3. Aug 6, 2007 at 12:28 PM
    Critter
    Thanks! I'll check with Dealer
  4. Aug 6, 2007 at 1:55 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    alot of people,in order to get rid of the mushy pedal feel, are installing stainless braided brake lines and using a "better" type of brake fluid.
  5. Aug 6, 2007 at 4:58 PM
    A2Mich
    A2Mich Well-Known Member
    Jackson, Michigan
    07 Silver Streak Double Cab PreRunner SR5 V6 TRD Sport
    Tube steps, Toyota Bug Shield, Lund Tonneau
    applying the parking brake occasionally will re-adjust the rear brakes and firm up the brake pedal.
  6. Aug 6, 2007 at 5:46 PM
    flyman767
    flyman767 Well-Known Member
    There have been many who have complained abut the 'mushy' feel...including myself. I had the dealer re-adjust the rear brakes and bleed the system. What they found was the 'rear adjusters' were too far out of alignment to self-adjust automatically. Afterwords, this did give the the brakes a somewhat stiffer feel. As tacomaman mentioned, some have replaced the the brake lines with stainless and have had limited success. Also, replacing the factory pads with a high performance pad like the 'Hawk Ceramic' have helped as well. I've learned to live with the mushiness for now and plan on replacing the factory pads sometime down the road; followed by replacement of the factory brake lines with stainless if the high performance pads aren't satisfactory.
  7. Aug 6, 2007 at 5:57 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Try driving a 2007 F150. We have one as a GV and everyone who driven it including me has mashed both the brake pedal and skinny one. Way to close to each other.
  8. Aug 7, 2007 at 6:53 AM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    I added SS brake lines and replaced all the brake fluid with synthetic DOT 4. The pedal feels good.
  9. Aug 7, 2007 at 10:11 AM
    ghan
    ghan New Member
    Try using your NASCAR road racing braking technique - double pump the pedal and you'll have a firm pedal with good feedback when stopping.
  10. Aug 7, 2007 at 12:13 PM
    Critter
    I'm kinda Pe'od about this, this Truck wasn't cheap for me. Bottom line I'll check with dealer. Chow!
  11. Aug 11, 2007 at 9:57 AM
    ghostsix
    ghostsix Well-Known Member
    A WI farm, Sonora, Sedona, Lake Havesue and Canyon
    Impluse Red 2006 Toyota Tacoma TRD Off-road 4x4
    A Roo Bar comes to mind. I also protected the tail lamps. It is a farm and you back over stuff; Willows mostly. All of the factory options are on it. The dealership owner bought it for himself.He put a topper on it and pricey tyres. The Power Wagon does the heavy lifting.
    I was raised on sticks and toe and heel control.
    The problem with the Taco is that you have half a brake pedal and it is too close to the gas.
    So if you use your left foot to brake you are pushing the lever and it is easy to apply brake and gas.
    This is a surprise the first time.
  12. Mar 15, 2009 at 6:34 PM
    beanders
    beanders Member
    I drove my first 2nd Gen this weekend. The brakes were REALLY bad. My 1999 with 125k has better brakes.
  13. Mar 15, 2009 at 6:39 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    i use the parking brake everytime i park my truck i have no problems with my pedal feel.
  14. Mar 15, 2009 at 6:46 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    agreed :wave:
  15. Mar 15, 2009 at 7:35 PM
    Blu08Taco
    Blu08Taco Taco™
    Florida
    08 TRD Sport
    Ditto
  16. Mar 16, 2009 at 9:23 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    They are soft...it's not your imagination.
    Try bleeding first....you can always upgrade lines later.
  17. Mar 16, 2009 at 9:29 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    The dealter adjusted my breaks during tune up and it feels much better.
  18. Mar 16, 2009 at 4:38 PM
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    i found the brake pedal is to close to the gas pedal. i keep touching both. so i fixed that problem buy cutting 1 inch off the brake pedal with my dremal. workes perfect now
  19. Mar 16, 2009 at 4:50 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    I had no problem getting the dealer to bleed my brakes. Definitely firmed the pedal up a bit.
