Brand new truck - Weird noise
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 4Cylinders, Oct 31, 2023.
  1. Nov 11, 2023 at 1:08 PM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    No I never tried reving the engine in park. I came to the conclusion it was some kind of driveline noise it never got worse. I would request your Toyota dealer have a field tech from corporate look at your truck. Sadly it might be a noise you have to live with man
  2. Nov 11, 2023 at 1:12 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    Mine goes woooooo at 25-35 mph sometimes.
    Gfenza89 likes this.
  3. Nov 14, 2023 at 9:38 PM
    americsg1
    americsg1 Member
    My stock 2023 2.7 4x2 6AT DCSB with 11k miles makes the same noise in the same manner.
    Things I’ve tried but still have it:
    Added Lubeguard Shudderfix
    Drain, refill and check trans fluid level
    Removed Cat theft Protection
    Check tire pressure
    Using ECT Power
  4. Nov 15, 2023 at 8:32 AM
    4Cylinders
    4Cylinders [OP] Well-Known Member
    Anthony
    2023 Tacoma 2.7L 4x4 Auto
    Interesting. I noticed that I can reproduce the noise in park/neutral at between 1,500-2,000 RPMs. Are you able to do the same?
    I had a friend hit the gas while I poked around the engine bay. It seems to be coming from the driver’s side of the bay but it’s hard to tell exactly where it’s coming from.
  5. Nov 15, 2023 at 8:54 AM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Interesting indeed. I had a new 2005 4x4 2.7 manual that started making a high pitch whine around 50-55mph at less than a year old. Turned out to be bad bearings in trans.
    They rebuilt it and about a year later the whine was back. They now put in a RECONDITIONED trans. Same thing as rebuilt...and a few months later I had tranny fluid leaking all over the place.
    Blew the top freeze plug out. Odd? Toyota now had to replace the whole tranny, bell housing and clutch because of fluid blown all over the place. I said to the service manager "maybe you should have done it RIGHT the first time. No reply and no more tranny issues till I sold it in 2021. It had plenty of other issues I never had with my 86 4x4. Too many to list them here.
    Still the biggest piece of junk I ever bought was a 1981 Ford 4x4 straight six. Three years and I had enough of FORD fix or repair daily.
    So far my 2022 4x4 Access has been pretty good other than weird auto trans shifting sometimes. Left ankle issues forced me to auto after 50 yrs.
  6. Nov 15, 2023 at 9:06 AM
    americsg1
    americsg1 Member
    @4Cylinders
    The noise (described as whirring) can be replicated using the stall test, or when driving at low RPM and light acceleration, typically around 25-32 MPH, sometimes low MPH and again around 40MPH. It doesn't shake the truck, but there is a faint vibration accompanied by the noise. It can't be replicated by just being in Park and bringing up the RPM's.
    Tried getting underneath the vehicle for a sound test while in the parking lot with a friend in the driver seat held the brake while in Drive but the test was inconclusive because I couldn't isolate it.
    Other things I've tried...
    Checking Cat heat shields for tightness
    Shaking exhaust system for tightness
    visually inspected carrier bearing and u-joints
    Checked intake plenum inside the right fender well
    Running premium gas
  7. Nov 18, 2023 at 9:48 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
  8. Nov 18, 2023 at 10:18 AM
    4Cylinders
    Anthony
    Tacoma_Grizzley likes this.
  9. Nov 18, 2023 at 10:23 AM
    RedWings44
    Michigan
    Like I said, specifically the noise between 35-45 MPH as some were talking about.
    As for your noise, I can't really hear it. Have you had your fluid levels checked?
  10. Nov 18, 2023 at 10:34 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    More when colder? Maybe a fan clutch that isn't up to snuff?
  11. Nov 18, 2023 at 10:35 AM
    4Cylinders
    Anthony
    My noise does not occur at specific speeds. It occurs are specific RPMs regardless of whether or not the truck is in motion. The truck has 2,000 miles on it and all of the fluid levels were checked by me upon delivery (with the exception of the transmission and differential fluid levels). Since the same noise occurs when the truck is parked AND in motion, I don’t believe it’s possible for the transmission or differentials to be the culprit. This is almost certainly an engine fan, belt, or accessory power noise from what I have gathered thus far.
  12. Nov 18, 2023 at 10:37 AM
    4Cylinders
    Anthony
    Yes, more when cold. Also, weirdly, it always occurs if I let the truck warm up for more than 5 minutes before driving using my remote starter. It almost never occurs when I just “get in and go”. I can’t make sense of that part.
  13. Nov 18, 2023 at 6:17 PM
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    My truck makes the same noise under certain conditions. I am almost certain it is the intake "whistling". I have heard aftermarket intakes cause the same noise on other vehicles I have owned.
  14. Nov 18, 2023 at 7:52 PM
    TacomaVirus
    TacomaVirus Well-Known Member
    Nick
    2020 Cement TRD Sport
    Try seeing if the noise is still present with the AC and / or defrost off. My truck (3.5 v6) had a whistle every time the AC compressor cycled, T-SB-0004-22. Happened every single time the compressor cycled, was most noticeable at light acceleration or 45-60 mph cruising speed but could replicate in park at 2,000 rpms.
    TSB was fairly invasive and not sure I would have dealer do it again but the whistle is gone. Basically replaced the evaporator core which includes the expansion valve and with updated part.
  15. Nov 18, 2023 at 9:37 PM
    #35
    4Cylinders
    Anthony
    It is 40 degrees where I am so I haven’t been running the AC at all. It occurs when the heat is on or off though. The HVAC system doesn’t seem to play a role whatsoever. I’m going to look into the fan clutch and see if that solves it. Are those difficult to replace on the 2.7L?
  16. Nov 18, 2023 at 9:40 PM
    #36
    4Cylinders
    Anthony
    It does sound like that, yes. I thought of that too which is why I had a buddy step on the gas while I looked under the hood. The sound is absolutely not coming from the airbox or passenger side of the engine bay. It can be heard loudest when leaning into the engine bay from the driver’s side front headlight area. It’s just impossible to pinpoint the exact location of the sound due to the ambient noise from the engine revving.
    Do you also have the 2.7L? Can you reproduce the sound when the truck is parked as well?
  17. Nov 19, 2023 at 8:27 AM
    #37
    Darty03
    Darty03 •‿•
    I have the 3.5 v6. I have never tired to reproduce it personally. I don't think it does it often enough that I even could reproduce it. I know it usually only does it under light acceleration low RPMs, around 2k or so. I have been towing a lot lately and I have noticed it when the engine is loaded down trying to accelerate onto the highway a few times.
    I did find these threads talking about the same noise with videos if you haven't seen them yet. I glanced through and it seems like nobody really knows for sure what it is.
    https://www.tacomaworld.com/threads/3rd-gen-tacoma-a-c-noise.550627/page-19
    https://www.tacomaworld.com/threads/faint-whistle-or-whine-while-accelerating.711429/#post-25297142
  18. Nov 19, 2023 at 8:34 AM
    #38
    4Cylinders
    Anthony
    It would be impossible that the noises talked about in those videos are the same as mine. The engine passes through various RPM ranges and the noise randomly occurs. My noise occurs at specific RPMs. I can sit in my truck, in park, with my foot on the gas at 2k~ RPMs and reproduce the noise for hours continuously. I can hold the RPM’s and drive my neighbors crazy with the whistling sound from my truck if I wanted to.
  19. Nov 20, 2023 at 12:49 PM
    #39
    americsg1
    americsg1 Member
    I'm done with troubleshooting; it's a 2023 and under warranty, so it's going to the dealer during the last week of December.
  20. Nov 20, 2023 at 12:57 PM
    #40
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I had to put my headphones on to hear it in your video. If the sound disappears when truck is at operating temperature, don't worry about it. Could be any number of things, fan clutch, power steering pump, smog pump, heat shield... Fluids in the fan clutch and power steering system will have higher viscosity when cold.
