Break Caliper Bolt Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ben Warren, Jun 3, 2009.
  1. Jun 3, 2009 at 4:30 AM
    Ben Warren
    Ben Warren [OP] Member
    apopka florida
    04 PreRunner
    Please Help.
    I have a 2004 Tacoma Pre runner with a 4 cylinder engine single cab. My problem is that i need to buy a new front break caliper bolt because one fell off on the road.. This bold is the short one that connects the caliper onto the wheele hub. I am having soo much trouble but i need to know the size because i might have found a place that carries them. Any help would be great! :)
  2. Jun 3, 2009 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Can you pull one from the other side, and get one that matches it?
  3. Jun 4, 2009 at 4:56 PM
    csxrailfan
    csxrailfan Active Member
    North Cackalacky
    2021 Toyota Tacoma DBL CAB TRD / GONE: 2002 Toyota Tacoma Access Cab TRD, 2011 Tundra TRD
    It is a common item that almost all autoparts stores will have in the "help" section.
