Bridgestone Duelers cupped @ 5000 miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grist, Jun 16, 2010.
  1. Jun 16, 2010 at 5:32 PM
    grist
    grist [OP] Well-Known Member
    Kevin
    Northeast Pa
    2017 Tacoma trd sport access cab
    Weathertechs, access cover
    My front duelers are cupped with 5000 miles. I called to make a appointment for them to check it out. This should be interesting. Has this happened to anyone else?
  2. Jun 16, 2010 at 7:22 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are they cupped on both front tires? Or only one side?
    Definately get that checked....they shouldn't be cupping at only 5000 miles on a new truck. Definately have dealer look at it under warrantee.
  3. Jun 16, 2010 at 9:25 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The original front tires on my truck cupped at 3,000; Bridgestone Dueler H/T 684II.
    My dealer replaced them; after they accused me of cornering too fast. :rolleyes:
    The replacements didn't cup.
    I tolerated them for 25,000; horrible tire.
  4. Jun 16, 2010 at 10:11 PM
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    Mine did the same, and they did an alignment and found out that from the factory the alignment is off .36. From the factory so have them check that out.
  5. Jun 17, 2010 at 9:22 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I am sure you checked the tire pressure but, be sure its correct prior to bringing it in. They may say incorrect tire pressure caused it. They should replace the tires for free its not your fault the truck was delivered with a misalignment.
    The fact that there is 5000 miles on the tires means somethings wrong....................
  6. Jun 17, 2010 at 11:58 AM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Alignment is out from the factory.
  7. Jun 17, 2010 at 12:10 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Those are a great tire, keep the alignment in spec and correct psi and they will go 40k all day
  8. Jun 18, 2010 at 2:22 PM
    grist
    Kevin
    Northeast Pa
    I think once they are cupped thats it. I had the leaf spring tsb done at 1800 miles and they told me I did not need a alignment. I am not sure if this is the cause or not but I did notice that the steering wheel also is off when going straight. I never noticed that until a few weeks ago. hmmm
  9. Jun 18, 2010 at 2:28 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    An alignment should have been performed after they did the TSB. This is part of the TSB.
  10. Jun 18, 2010 at 5:25 PM
    2.7taco
    Texas
    Sounds like they did not put the axle back on straight.
  11. Jun 23, 2010 at 6:26 PM
    grist
    Kevin
    Northeast Pa
    Thanks for all the advise!!!! I am going in this friday.
  12. Jun 23, 2010 at 6:35 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I Believe, the TSB Specifies, Leaf Pack, Then Alignment. Had TSB Done Last Month, The Post Leaf Pack Alignment was Perfect Before and After they aligned it, according to the printout, I have the Duelers @ 2,200 miles. Have Not Noticed any Problem.
  13. Jun 26, 2010 at 12:17 PM
    grist
    Kevin
    Northeast Pa
    Well my alignment was way off. They rotated the cupped tires to the rear and told me they will straighten themselves out on the rear. I dont agree with that and asked for new tires. They said they cant do it without authorization. They are supposed to call me monday. I probably will be calling Toyota.
  14. Jun 26, 2010 at 4:30 PM
    MachoTaco10
    MachoTaco10 Well-Known Member
    Nick
    New Hampshire
    2010 Tacoma TRD Sport
    duelers are really really bad tires. I own a townfair tire in NH. I took them off the shelves, have a hard time balancing them, have seen layers of the sidewall peel. CRAP.
  15. Jun 26, 2010 at 5:14 PM
    Cape Codder
    Jack
    Dealer Didn't Align Mine after Leaf TSB. I Went Back and THEN They Read the Rest of the 18 Page TSB. "Yup, We Owe You An Alignment". Link to 18 Page TSB Below if You Don't Have It. Page 8 of 18 States: "An Alignment Inspection and Adjustment is Required After the Installation of the New Rear Leaf Springs". Print Out The TSB, Take It to Dealer + Tell them They Own You Two New Tires, If They Had done The Job Right, Your Tires Would Still Be New. IDIOTS!!! (Did I Say That Out Loud, Don't Say That To Them.)
    When I Went Back to Get My Alignment, I Went into A Five Minute Dissertation About How My Time Was More Important to Me Than Anybody Else's On The Planet. They Could Over Charge Me, Take Longer doing A Job Than They Expected, Even Accidentally Damage My Truck, We'll Work It Out. But When They Needlessly WASTE MY TIME, I'll Take My Business Elsewhere. Everybody At My DealerShip Knows Me Now, If They didn't Before
    BTW My Alignment Was Perfect and Required No Adjustment. I Have The Before & After Printout
    GOOD LUCK
    http://www.tacomaworld.com/forum/at...evision-2-includes-2009-2010-t-sb-0305-08.pdf
  16. Jun 27, 2010 at 5:53 AM
    grist
    Kevin
    Northeast Pa
    Thanks I plan on showing them the TSB.
  17. Jun 27, 2010 at 6:23 AM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Having a slow morning again: cupped tires?? Que?
  18. Jun 27, 2010 at 7:41 AM
    KaoskrewPB
    KaoskrewPB -Empty-
  19. Jun 27, 2010 at 1:30 PM
    grist
    Kevin
    Northeast Pa
    Google it ! I think that is a verb now.
  20. Jun 28, 2010 at 12:57 PM
    grist
    Kevin
    Northeast Pa
    The service manager said I will probably have to pay a pro rated price on two new tires because its a wear item. Thats such bullshit I can hardly compose myself. They did not perform a alignment when the rear tsb was performed and that is the cause, period.
