Bright clock?
Discussion in 'Audio & Video' started by swervin22, Jun 26, 2010.
  1. Jun 26, 2010 at 8:24 PM
    swervin22
    swervin22 [OP] "Obviously, You're not a Golfer..."
    Jonas
    Chesapeake
    2010 DCLB Sport Barc. Red
    Camburg Spindles, 3in All-Pro Leaf pack, 5100's, Kenwood Stereo with super awesome Aux cable mod
    Just installed my new head unit today. And now that it is dark outside, It appears that my clock is super bright? It doesnt get any darker when the dimmer wheel is rolled, Cant remember if it did before?? anyways, anyone else have this issue, or am I just a tard?
  2. Jun 27, 2010 at 12:00 AM
    dolbytone
    dolbytone Well-Known Member
    09 TRD Off Road
    Some units have a connection for the dimmer wire and some do not. If you were able to connect one, the dimmer wheel should work for stereo illumination.
  3. Jun 27, 2010 at 12:04 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    who helped you install the head unit? What brand head unit is it????
  4. Jun 27, 2010 at 12:09 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    Some HU's have an option in the menu to have different brightness settings (usually 3 different levels), check the manual.
  5. Jun 27, 2010 at 12:34 AM
    lookylookitzadam
    lookylookitzadam Retrofit Club!
    Adam
    San Diego
    07 DC OffRoad
    Clock on the HU or in the panel? I am assuming you are talking about the OEM clock. If so, did you somehow splice the radio's illumination wire to power or ground (not sure if its negatively or positively switched). That would feed a constant voltage instead of a regulated one, causing constant bright.
