Brighter backup bulbs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mystik cabs, Jul 25, 2015.
  1. Jul 25, 2015 at 4:28 AM
    mystik cabs
    mystik cabs [OP] Well-Known Member
    Brian
    North Stonington, CT
    '04 TRD DBL Cab
    I have an '04 and need brighter backup bulbs, can anyone tell me where and what to look for. Sucks getting old, night vision isn't what it was once, lol.
  2. Jul 25, 2015 at 4:33 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
  3. Jul 25, 2015 at 6:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I run aftermarket lights mounted to one of the hitch bolts
    I just love them!!
  4. Jul 25, 2015 at 10:23 AM
    Wulf
    rock raisin
    I've thought about going this direction but would rip them off on a trail for sure
  5. Jul 25, 2015 at 10:58 AM
    Clearwater Bill
    Billy
    Largo Florida
  6. Jul 25, 2015 at 11:04 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 1st Degenerate Urban Off-Roader
    Jon
    Houston, Texas
    2006 Gordita Blanca V8 4x4 aka "Penelope"
    Sliders and bumper, DDI injectors, flowmaster 40
    I don't think first gens can take advantage of that mod. I could be mistaken though.
    Imho, the best bang for your buck is led flush mount pod lights that you stick in your bumper. Just cut out a spot, bolt em in and tap into reverse lights for power, ground to frame. This way you don't have to worry about breaking em on the trail and they look great, plus are crazy bright.
  7. Jul 25, 2015 at 11:10 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    so what stock bulb do we have in there right now? is it a 194 or T10?
  8. Jul 25, 2015 at 11:17 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    921 for 01-04
    1156 for 95-00
  9. Jul 25, 2015 at 11:38 AM
    keakar
    karl
    louisiana
    well according to Toyota, those 921's are 12v 16 watt bulbs so you would need to find a higher wattage wedge bulb for it when you replace it.
    they can be found here: http://www.toyotaonlineparts.com/oe-toyota/9098111059
    for those with 1156 bulbs, those are 21-23 watts so this would be the brighter oem replacement bulb: http://www.ebay.com/itm/1156-Super-...156-/160595821814?hash=item256441c4f6&vxp=mtr
    most replacement bulbs I see at the store or on ebay, even the so called "super bright" ones, are only 5, 7.5, or 10 watt bulbs which are no where near as bright as the oem 16 watt bulbs are. same with the 1156 bulbs at the store which average only 21-23 watts.
    the trouble with buying most LED bulbs is they often don't list the wattage they put out but only show "lumins", while the oem regular incandescent bulbs only list watts and don't show "lumins" so its hard to compare them for brightness when they don't use the same units of measure.
    if the previous owner replaced them with standard T10 or 194 bulbs they bought at the auto store, those would be the 4 or 5 watt bulbs for marker lights and not give you much light at all. I think the first thing you need to do is see if you have the wrong bulbs in it to begin with.
    I know my back up lights put out very good light with the stock bulbs.
  10. Jul 25, 2015 at 11:59 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I have a set of White LED lights I just have not got around to installing them in the bumper.
    In fact I forgot all about it till reading this thread.
    Other then my driveway and job sites about as far as I get off road.
  11. Jul 25, 2015 at 5:02 PM
    camptaco01
    camptaco01 Well-Known Member
    Eric
    Tempe,AZ
    2004 TRD Double Cab 4x4
    I put some 3 watt "eagle eye" style LEDs in my bumper and tapped them into the reverse bulbs. Faced them slightly outwards, great for backing up at night. Also have some very bright floods in my camper shell
  12. Jul 25, 2015 at 10:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I replaced my OEM 23-watt halogen bulbs with aftermarket 55-watt halogen bulbs. It was the easiest way to get more light from the existing circuitry.
  13. Jul 27, 2015 at 11:01 PM
    dlamsonaexsac
    dlamsonaexsac Member
    Northern California
    96 Tacoma SR5
    Theres a mod to replace 1156 bulbs with 194 bulbs? Or am I simply not reading that correctly?
  14. Jul 27, 2015 at 11:15 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    if you want light coverage then the best option is to get a set of lights and mount them to the bumper. the housings have a limited range even with brighter bulb.
    I have no issues seeing but if you have those issues get the "fog light" versions as the light spread is wider than "driving light" versions. wire a relay in to come on with reverse and done.
    or buy LED and just tap into the reverse light wiring, no real load on the electrical to cause problems for the short duration of use.
  15. Jul 27, 2015 at 11:17 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    I believe you've got 194's in an '04. When I upgraded from stock to Sylvania silverstars- I didn't think they seemed that much brighter, but the whiter light helps me for short distance. Granted, it's a very slight improvement if any at all. But a very inexpensive option to at least give it a shot. They're Like $8.
    This Philips LED 921's look interesting. See link- I've been discussing them with another member:
    https://www.tacomaworld.com/threads/philips-921-reverse-led.382192/#post-10501267
  16. Jul 28, 2015 at 6:45 AM
    mystik cabs
    Brian
    '04 TRD DBL Cab
    Hmmm, those Philips do look interesting...
    NMTrailRider likes this.
  17. Jul 28, 2015 at 6:47 AM
    mystik cabs
    Brian
    '04 TRD DBL Cab
    [QUOTE="
    I know my back up lights put out very good light with the stock bulbs.[/QUOTE]
    I am the original owner and I haven't replaced them so they are still the stockers.
  18. Jul 28, 2015 at 7:38 AM
    keakar
    karl
    louisiana
    no, those are completely different sockets
    the 96-00 trucks use 1156 bulbs with the round socket and the 01-04 trucks use the 192 bulbs with the small wedge socket which also look like and can be incorrectly replaced with 194 or T10 bulbs because they look the same.
    what I was saying is its possible that's what happened and I have seen it before where an owner went grab a bulb at the auto store that fits but is the wrong wattage so it doesn't put out enough light.
    there are higher wattage bulbs that fit the 1156 sockets so there are mod options in regular bulbs so LEDs are not the only mod option for the 96-00 trucks
  19. Jul 28, 2015 at 9:33 AM
    NMTrailRider
    New Mexico
    check out some of the Amazon reviews. several people are pretty excited about that Philips LED.
  20. Jul 30, 2015 at 10:33 PM
    NMTrailRider
    New Mexico
