Brightest stock fog light bulb
Discussion in 'Lighting' started by bajamoon, Feb 16, 2009.
  1. Feb 16, 2009 at 4:51 PM
    bajamoon
    bajamoon [OP] Well-Known Member
    STEVE
    Whittier
    Looking for a brighter fog light bulb in my taco, what is the maximum wattage that i can put in before things go bad, just put in some silverstars and was not impressed, i no i can't get them as bright as the headlight but how bright can i go.
  2. Feb 16, 2009 at 4:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The bulb that would put out most light is an HID (kit, not just bulb). Stock wattage is 42, while the Silverstars are about 30 or so.
  3. Feb 16, 2009 at 5:00 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
  4. Feb 16, 2009 at 5:05 PM
    bajamoon
    STEVE
    Whittier
    thanks guys, don't want to go hid, to many problems with cops in kali, if i put 65 watt bulbs in what will the problems be, melting the lens, wires, those are the things i don't want to happen. tacoco have you put those bulbs in.
  5. Feb 16, 2009 at 5:07 PM
    TacoCo
    Colorado
    Yup, I got some 4000k halogens that I put in mine, and I haven't had any problems with them at all. I've got 6000k HID's for my headlights, and between the fogs and the headlights, they light up the road clear as day.
  6. Feb 16, 2009 at 5:11 PM
    bajamoon
    STEVE
    Whittier
    cool, thanks for the info, now i will have to find the bulbs, places out kinda suck for stuff like that, internet here i come.
  7. Feb 16, 2009 at 5:14 PM
    TacoCo
    Colorado
    The bulbs that I used were Philips Crystal Vision Ultra 9005's. I got them at Napa... Can't remember how much they were to be honest. If you compare one of the 9005 bulbs to the 9145 bulbs, you'll see that one of the tabs is a little bit longer, but it'll still fit into the stock housing with a little bit of wiggling... You don't really need to force them in. They're technically for headlights, but I've never been flashed or bothered by cops.
  8. Feb 16, 2009 at 5:16 PM
    bajamoon
    STEVE
    Whittier
    i will check out napa, thanks for the info bro.
  9. Feb 20, 2009 at 8:07 AM
    txusa03
    txusa03 Well-Known Member
    I have H10 for my fog light, does that tell you anything about it's intensity? I don't know much about light bulb. But I know my H10 is more than 30 Watt (I have to double check the containers it came with).
  10. Jul 9, 2015 at 7:49 PM
    Vansurfing
    Vansurfing Well-Known Member
    J
    Rockport, Texas
    2021Tacoma TRD off-road/1996 Hilux Surf
    I bought silverstar Xze mine are h11
  11. Nov 5, 2015 at 8:39 PM
    beavis87
    beavis87 Well-Known Member
    El Paso
    '10 Silver TRD OR
    This thread says they are H10: https://www.tacomaworld.com/threads/lighting-faq-please-read-before-posting.84308/
    Yet
    Then,
    So I'm confused. Will our trucks accept 3! different kinds of bulbs and if so, which halogen size/bulb offer the best brightness that is still compatible for our factory fog lights?
  12. Nov 5, 2015 at 11:31 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    2005-2011: H10 45w
    2012-2015: H11 55w
    Look at your fuses. Amps=watts/volts. You can determine what the safe wattage level is using that formula compared to your stock fuse amps. If you look at the headlight upgrade I've done linked in my sig, the fogs really become a non factor as the headlights over power everything. I'd suggest just getting a higher quality bulb. There are several suggestions on page 4 of the headlight upgrade thread of lumen output vs bulb life.
    Also 9011 HIR bulbs produce MASSIVE more amounts of light than 9005s. Interesting tech that was beat out by HIDs at the time, but is still available although rare. I can't recommend a +20w bulb upgrade to a 45w fog, as it is nearing 50% increase over stock. Check your fuse ratings. Amps=watts/volts.
