Bringing up the driver's side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joe B, Mar 27, 2009.
  1. Mar 27, 2009 at 4:43 AM
    Joe B
    Joe B [OP] Well-Known Member
    I was going to go with coilovers but because I only want to raise the front .85 to help level with the back.I'm probably going with 5100s..
    I also rather go with 5100s over coilovers because I've read coilovers need a rebuild every 2-3 years.The cost difference is nice too.:)
    My question...
    Is there a spacer or plate made for the 5100s that can add 1/4" to 1/2" to bring up the drivers side?
    I believe Chris 4X4 said the OME makes a plate for their shock but it won't fit the top of the 5100.
  2. Mar 27, 2009 at 4:58 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can get a trim packer from toytec...........should do what you need it to do for the driver side. i believe the ones you can get are 5mm.
  3. Mar 27, 2009 at 5:13 AM
    Joe B
    Thanks tacomaman06,but I only see the OME trim packer on the Toytec site.:(
