Broke right-rear shock
Discussion in '1st Gen. Tacomas (1995-2004)' started by TonyTacoBC, Nov 7, 2010.
  1. Nov 7, 2010 at 12:39 AM
    TonyTacoBC
    TonyTacoBC [OP] Well-Known Member
    Tony
    Langley, BC
    '03 Reg cab 4cyl 4x4
    tires
    It snapped off right at the base where it attaches to the axle. The shock absorber isn't from the factory - it's a cheapy replacement. So for now I just pushed it out of the way until I can swap in a new one this coming week. I just have to be careful over bumps :)
  2. Nov 9, 2010 at 12:10 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    Time for an upgrade.
  3. Nov 9, 2010 at 12:14 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I was thinking the same thing :D
  4. Nov 9, 2010 at 5:52 AM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    I put new shocks in last night. Monroe Sensatracs. We'll see how they do.
  5. Nov 9, 2010 at 10:04 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/URD 2.2" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    This can happen if the shock body is too long for the application. When the shock bottoms out it will eventually break the weld.
    On 1st gen Tacomas one shock is shorter than the other. If they are mounted incorrectly (long shock on the short side) the shock can be damaged. Stock replacement shocks should be side specific.
  6. Nov 9, 2010 at 10:23 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Hmm my 5150's were the same part number and neither one said right or left. i hope there on right.
  7. Nov 9, 2010 at 10:39 AM
    Digiratus
    Roaming the PNW
    The RedHead
    You are no longer stock either. Here is a great explanation of how this all works.
    http://www.bajataco.com/travel-measurement.html
  8. Nov 9, 2010 at 5:05 PM
    TonyTacoBC
    Tony
    Langley, BC
    tires
    Thanks for the info Digiratus!
