Broke/Sheared roof rack bracket screws, HELP!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by morninglor, May 14, 2009.
  1. May 14, 2009 at 6:42 AM
    morninglor
    morninglor [OP] Member
    CA Bay Area
    06 4wd auto 4 double cab
    running boards, bed liner, bed extender, tonneau cover, roof rack, bed rails
    OK, first off I am very embarrassed by my mistake I am posting about...
    I just got the OEM roof racks for our 06 double cab for my DH for his birthday - Big surprise for him, and was started installing them myself while he was at work yesterday. This install was supposed to be a "no problem" deal..I read the instructions thoroughly, familiarized myself with the components, got my tools ready and started.
    Well, DH got a new (brealking, not click) torque wrench (ft-lb) which is the one I grabbed when getting tools ready and I misread the torque units in the instructions (lbf-in), so you see what happened, and I did it twice. :mad: I am usually very good at converting, and I actually questioned the value in my mind, but still misread...I think in my excitement of the surprise for DH.
    OK, so now I have a roof with two broken/sheared screws...with the loctite in the roof of my truck. I tried one of those screw extractor kit deals, but I think they are ment to work with softer metal like zinc, so that was a no go.
    does anyone know where I can go to get these screws removed without completely messing up the threads in the roof? I am thinking a local autobody shop....ugg, I am just so embarassed by this and I hope that I can still surprise DH with the racks installed before this weekend.
    Thanks in advance!
    Lori
  2. May 14, 2009 at 6:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any good shop should be able to get them out without an issue.
  3. May 14, 2009 at 7:26 AM
    Gunga
    Gunga Well-Known Member
    Glendale, AZ
    2008 TRD OffRoad DC 4x4
    What is DH?
  4. May 14, 2009 at 7:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "Dear Husband"???
  5. May 14, 2009 at 7:29 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I'm guessing dear hubby.
    Best getting it fixed, as Chris said take it to a shop, props for a cool gift for DH. :thumbsup:
    edit: oops Chris beat me to it lol
  6. May 14, 2009 at 7:32 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    his gender says male so it cant be for his husband......oh wait its 2009 i guess it could be.
  7. May 14, 2009 at 7:36 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Maybe she didn't want to get harassed for being a woman?
  8. May 14, 2009 at 7:52 AM
    morninglor
    CA Bay Area
    sorry, I am a female (do women get harassed on this board?) not male...didn't realize that I was listed as a male....i'ts fixed now...sorry for confusion...and yes, DH is dear hubby- I guess I am on too many boards...
    Thanks for the help....
    I like to surprise DH with accessories on his truck, even though I am the one who drives it mainly...last time it was step rails, I installed those too. I need an idea for the next surprise...these forums are great for inspiration.
  9. May 14, 2009 at 8:00 AM
    drew02a
    San Antonio, TX
    I've not seen any women harassed on this board, just thought it might be a concern.
    I actually had a similar problem very recently when removing the ring gear from my diff carrier. I tried drilling the hole and using a bolt/screw extractor, but it broke off. Those kits are designed for high torque apps especially when locktite has been applied. :wink:
    I was able to remove the ring gear once the bolt head came off which revealed enough of the shaft that I was able to remove the bolt with a huge wrench. I don't think that will be a viable solution for your roof rack problem though.
  10. May 14, 2009 at 8:06 AM
    JsAZ
    JsAZ Member
    Gilbert, AZ
    09 DC PreRunner TRD Sport
    I tease my wife that on her message boards, DH more often than not means "Deadbeat Husband".
  11. May 14, 2009 at 8:07 AM
    drew02a
    San Antonio, TX
    Ha Ha
    I would also suggest taking it to a shop.
  12. May 14, 2009 at 8:15 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    If you're feeling industrious, drill out the screw using a bit with a smaller diameter than the threaded hole. Make sure you're centered when drilling and keep drillbit tip lubricated.
    After drilling through you'll find that the screw threads come out easily. Chase the threads in the hole with a tap and it'll be good as new.
    Of course, this will probably require purchasing drillbits, tap oil, and a tap kit. For a single job, it's cheaper to bring it to a shop. :)
  13. May 14, 2009 at 8:19 AM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    :gossip: Supercharger?
  14. May 14, 2009 at 8:32 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i've broken off several bolts on my days of wrenching... usually i find it easiest for me to just weld a nut back on the top of the broken bolt if there's sufficient room and then remove. i've used this method several times, even once on a broken bolt through the head of a 22RE motor.. always works like a charm. only problem i see using this method for your delima is that there is alot of plastic around to melt with the heat created... good luck and i would advise to just take it to a shop you trust!
  15. May 14, 2009 at 8:34 AM
    mjp2
    NJ
    "Hey hubby, I just bought a Camburg long-travel suspension kit for some guy named 'mjp2' on TacomaWorld. SURPRISE!"
  16. May 14, 2009 at 8:41 AM
    98tacoma27
    Ben
    Not Beech Creek
    Wow, I love it when women speak tools and installtion.
    Nothing to be embarrased about Lori, check this out. That's emarassing.
  17. May 23, 2009 at 2:33 PM
    morninglor
    CA Bay Area
    Thanks for all the advice...(and the post that made me feel slightly less embarrassed....I'm thankful I know the difference between the oil and tranny plug...AND that pink fluids are not all equal.;))
    So I got over to a shop and they FINALLY got me in and were able to remove the fasteners. They were wary of welding a stud, so the ended up drilling them out then using an easyout.
    I can find M6 x 15 screws on McMastercarr, but I am having dificulty finding a good replacement for the Mastic Washers that I destroyed.
    Does anyone have a source or alternate solution for the mastic washers?
    Thanks!
  18. May 23, 2009 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Do you have an Ace Hardware near by? They have alot of that stuff...
  19. May 23, 2009 at 6:22 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
  20. Nov 25, 2014 at 6:37 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would say no. for a short answer.
