Broken Antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blackfoot 7, Jul 8, 2015.
  1. Jul 8, 2015 at 10:00 PM
    Blackfoot 7
    Blackfoot 7 [OP] Active Member
    2009 Black Tacoma DCSB 4x4
    Vehicle was purchased used with running boards, 3" lift, 17" Moto Metal wheels, BF Goodrich All-Terrain T/A KO tires, bed liner, tow package, and bike hooks. Mods Added (ongoing): Hood w/ Scoop (inbound)...
    Okay so my used Tacoma came with a broken antenna. Dealer offered to fix it for like $300 or something ridiculous like that. Figured I'd attempt it myself. Anyone have any advice on the best way to proceed? I would try an easy-out, but it looks like the bottom part of the original antenna is still stuck in the base. Your time and attention to this matter is greatly appreciated.
  2. Jul 8, 2015 at 10:26 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Get a small drill bit center punch and an easy out bolt extractor set.
    http://www.wikihow.com/Remove-a-Broken-Bolt
    Center punch the piece left in the base.
    Drill a hole into the center of the stub.
    Insert the easy out extractor and back the stub out of the hole.
    Stub extracted
    MadDaddy likes this.
  3. Jul 8, 2015 at 10:28 PM
    TXAggieTRD
    TXAggieTRD Well-Known Member
    Andrew
    TX
    '11 Pre-Runner V6 TX TRD Package
    Theres a special kit you can buy at lowes to remove broken screws. I used it when I over torqued a screw on my old dirtbike
  4. Jul 8, 2015 at 10:30 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    That or buy one of those newer concealed antennas...plugs into the radio just like stock and is hidden away somewhere (if you don't care about leaving the fender as is)
  5. Jul 8, 2015 at 11:12 PM
    switch
    switch Well-Known Member
    Norther California
    2022 Tacoma Access Cab
    The exact same thing happened to me. But I decided if I could bust one antenna, I could bust another. So I removed the head unit and installed one of these
    http://www.amazon.com/Hidden-Antenna-Motorcycle-Applications-Windshield/dp/B001QYSXAS
    I put the new "antenna" inside the windshield above the rear view mirror. It has worked great for about 8 years.
    I call this the "shaved antenna mod".
  6. Oct 22, 2015 at 7:55 PM
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    I tried a center punch. No luck. It sounded like the whole fender was going to fall off my truck. It was so loud I thought I was going to knock something loose inside. Not sure what to try next.
  7. Oct 22, 2015 at 8:02 PM
    Jimmyh
    SC
    2012 Prerunner SR5
  8. Oct 22, 2015 at 8:12 PM
    Koam
    Koam Well-Known Member
    Oahu
    2005 TRD Sport DCLB
  9. Nov 6, 2015 at 5:44 PM
    MadDaddy
    Many & varied
    I followed the above diagram to a T. Took me about 90 seconds to punch, drill, remove and install new 17" antenna. Works on all my presets.
  10. Nov 6, 2015 at 8:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Glad you got it. I don't see how it could be easier.
