Broken antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mel a, Oct 28, 2021.
  1. Oct 28, 2021 at 12:49 PM
    Mel a
    Mel a [OP] New Member
    Hoping someone can give me information on how to replace this. My antenna broke off and when it did it bent the threads. Now I can't put a new antenna on.
  2. Oct 28, 2021 at 4:22 PM
    dpf88101
    dpf88101 Well-Known Member
    tap and die maybe able to straighten that out you can go a lot more expensive but this may work fine for this fix
    Rambo MARINE Recon likes this.
  3. Oct 28, 2021 at 4:28 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    There is a good youtube video of this somewhere. Caution: It isn't a smooth/seamless process. I would definitely recommend the tap before you replace the base
    dpf88101 likes this.
  4. Oct 28, 2021 at 4:34 PM
    Waasheem
    Waasheem
    2007 xrunner
    It would look a bit hokey but I've seen something at hardware stores, not sure what it's called. Imagine a bolt but with a very long hex head, on top of the head is a threaded hole.
    Or if you never remove it for a drive though car wash, jb weld the new one in.
    I've replaced them before, kinda pain in the butt. I disconnected it from the back of the stereo, tied a string to it, unscrew it from the fender, pull it up and out. Tie the string you now have sticking out of the fender to the new antenna, pull it in from where the stereo is. Of course if it doesn't want to pull out, don't yank the crap out of it. Look under to see what's keeping it from pulling out. Ziptied, caught on something, something in the way... Plug it into the stereo, screw it onto the fender.
  5. Oct 28, 2021 at 4:36 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    There's a good walkthrough of the antenna assembly replacement process in this thread. Doesn't look particularly fun.
    TnShooter likes this.
  6. Oct 28, 2021 at 5:02 PM
    devkurf
    devkurf Member at Large
    midwest
    I'd try to tap it and then put in a stubby.
  7. Oct 28, 2021 at 5:52 PM
    dairyman
    dairyman Well-Known Member
    Beat up 08 Tacoma
    3” lift 285s
    Same thing happened to mine. I took bolt cutters and cut the treads off the antenna and just stuck it in the hole lol. Still works and hasn’t fell off yet.
    Waasheem likes this.
  8. Oct 28, 2021 at 6:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    I think as long as you don’t get airborne, it’ll work.
  9. Oct 29, 2021 at 3:49 PM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    drill, tap and Die larger for a HeliCoil and walla !!! Did that to mine 4 years ago! You can remove every time for car wash again and NO PROBLEMS at all !!!
  10. Nov 15, 2021 at 9:45 PM
    T-Dozzer
    T-Dozzer Well-Known Member
    Same thing happened to be. Broken bolt extraction bits got it out. Replaced with a stubby
