Broken Speedometer?
Discussion in 'Detailing' started by JT Class, Oct 6, 2012.
  1. Oct 6, 2012 at 9:06 AM
    JT Class
    JT Class [OP] Can't spell class without...
    JT
    Sept-Iles, Canada
    09 DC TRD Sport
    Aries bull bar, Tonneau pro box cover, TrailFX hood deflector, Sleeper lids, US Speedo speedometer gauge (white), more to come...(3incher bilsteins 5100+f/coils+aal w/285 or 265?)
    Morning all,
    Just installed my new us speedo custom white speedometer gauge yesterday. Everything was fine and dandy until i was driving it about 10 mins after installation when i started to brake. The speedometer kept dropping, dropping....dropping past zero...all the way down to about 7 oclock. I read my cluster might be screwed or is it a simple reconfiguration? :confused:
    Thanks for any help!
  2. Oct 6, 2012 at 2:08 PM
    JT Class
    JT
    Sept-Iles, Canada
    09 DC TRD Sport
    anyone? anything?
  3. Oct 6, 2012 at 2:10 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    Take it apart again, put it back to stock and see if the problem goes away.. Also just check all connections making sure nothing got loose in your installation.
  4. Oct 8, 2012 at 6:10 AM
    JT Class
    JT
    Sept-Iles, Canada
    09 DC TRD Sport
    I only changed the face plate :confused:
    If it was broken needle gears Im assuming it would of never worked for those 5 minutes. But tomorrow is my day off ill take er a part and try to calibrate it again.:annoyed:
  5. Oct 15, 2012 at 7:11 PM
    JT Class
    JT
    Sept-Iles, Canada
    09 DC TRD Sport
    Simple fix, turn the speedometer needle counterclockwise (or the side that you feel has resistance to it) all the way around back to zero. That will calibrate it. Same thing for gas and temperature needles if they go coo coo. Spin the needle around the side that has a little resistance on it back to it's proper setting.
    :cheers:
  6. Jan 2, 2014 at 2:30 PM
    aw10tacoma
    aw10tacoma backyard mechanic
    Andrew
    Northern New Jersey
    2011 AC Mgm
    -HomerTaco Grille -Aftermarket Headlights Halo Projectors -rear doors now have pioneer speakers -Kenwood DNX690HD -LED speedo gauge swap and faceplate along with painted needles - auto start and alarm from compustar -TRD painted on grille -Strobe lights in reverse lights -All bulbs are led -XD rims -arb bumper -S.O.S. Concept SLIDERS -OME 3inch suspension lift nitrocharger sport shocks dakar leafs -light racing ucas -toughtlight 22''dual led bar behind my homertaco grille -wet okale seat covers -trailer lights connection moved into bumper -tints -trd cold air intake -trd catback exhuast -total chaos lca skids -Budbuilt Skids -DT Long tubes -URD MAF SENSOR
    by any chance did you happen to take apart the back of the board to the gears... im having a problem with my speedometer and ive taken it apart and its the actual gears back there that wont stay in place and ive tryed using a spring to kind of keep tension on it so it wont pop up and a spacer on the need to keep it from moving off the needle and cant figure it out
