Broken Transmission Input Shaft Snout
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 8BoltRacing, Apr 24, 2013.
  1. Apr 24, 2013 at 4:56 PM
    8BoltRacing
    8BoltRacing [OP] Custom Fabrication and Performance
    Jared
    Greensburg PA
    The Angry Warthog
    DO 3 hoop, Wheelers HD Leaf Set w/ES poly bushings, OME 884X Coils, 5100's, Selfmade Satoshi, Single beam headlights, Fogs anytime, high beams with low beams mod, ABS kill switch, AMSOIL fluids in everything, K&N Intake, TB Spacer, FAL Electric Fan and TRD Rad Cap, DT Long Tubes, URD Y-pipe w/xtra O2 bungs and 3" v-band , Custom 3-inch Exhaust w/v-band and 3030XL Aero turbine muffler and Aero 3040 tip, URD Fuel Pump Upgrade, B&M Short Shifter, EBC Dimpled and Slotted Rotors with EBC Yellowstuff pads, Pulseplugs, HIDs: Fogs 3000k, Highs 4300k, Lows 8000k, URD Throwout Bearing Repair kit, Fidanza Aluminium Flywheel+Competition Clutch Stage 4
    Clutch started making noise and feeling rough on engagement/disgagement, through the pedal it felt almost spongy as if it had air bubble in the line. Took the inspection cover off the bell housing and the throwout bearing fork had almost 1/2" side to side play. Pretty much visible that the snout is broken off but is covered over by the bearing sleeve kit I got from URD. Called and Spoke to Gadget there and he has heard of this happening before. Luckily he says the snout is on the bell housing so I just need to find one. Any input?
  2. Apr 24, 2013 at 5:06 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    pictures? im unfamiliar with the "snout". you didn't break the input shaft? I/ve never had this tranny down and have no idea what it looks like. . . . . didn't even know it had an inspection plate! gunna have to check that out!
  3. Apr 24, 2013 at 6:44 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    It gaurds the slave cylinder too.. ill get some pics when I get the chance 2moro till I take her apart
  4. Apr 24, 2013 at 6:47 PM
    92dlxman
    Kevin
    Visalia, CA
    so whats the snout your talking about?
  5. Apr 24, 2013 at 9:16 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    It is part of the bell housing and is what the throwout bearing rides on originallly.
  6. Apr 25, 2013 at 2:15 AM
    hladun
    hladun Well-Known Member
    Alberta
    Tacoma
  7. Apr 25, 2013 at 1:44 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Won't be doing that.. my TO bearing does not squeak but the clutch chatters. Placing a preload on the bearing should cause it to wear out faster and if it decreases the clamp force of the pressure plate it may cause the clutch to slip even minutely and therefore wear out as well. I do a good deal of towing and hauling and is one of the reasons I installed the stage 4 kit. Besides, I don't really have the money to fix the problem i already have let alone do anything else.
  8. Apr 25, 2013 at 2:00 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Search local bone yards would be the best place to start. Not sure how much it will cost new, but can't be better then used.
  9. Apr 25, 2013 at 2:00 PM
    hladun
    Alberta
    Tacoma
    Cost? 150 cylinder at scrapyard ($15?) plus 1 hour of your time vs. URD kit at $225 plus trans out to install vs Toyota TSB with trans out...which do you think is cheaper?
    But if you don't have the problem then great. If you tow I've already told you you might not want to do this. Other vehicle companies preload their TO bearings (like Ford) so this is something that's commonly done and isn't something I've dreamed up.
  10. Apr 25, 2013 at 5:37 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Holy shit, this is kind of scary. The sleeve didn't cause the snout to break, did it?
  11. Apr 26, 2013 at 5:48 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    I literally have less than $20 left after bills from paychecks. Sometimes i have to put off bills til the next pay. Bein house poor/broke sux. The only reason i have time to do it this weekend is that the wife works and my mom has the kids. And I already have the URD sleeve kit that did solve the rough bearing travel and minor squeak.
    I really hope not unless my brother overtightened the set screw.
  12. Apr 26, 2013 at 5:49 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Not asking for sympathy or bein a drama queen btw..
  13. Apr 26, 2013 at 6:17 PM
    92dlxman
    Kevin
    Visalia, CA
    if it broke at the base, I would look really hard for a mobile welder who is set up to do aluminum. as long as it broke where the tob doesn't ride.
    I know aluminum welding on used motor parts (especially cast) isn't going to be 100 percent, but you should see the bellhousing one of my co-workers did for another worker's race-car. . . . still works. A good welder would warn you about anything that may go wrong. a bad one will say "no prob" and proceed to wreck your shit.
    I hope you get this all figured out. . . im scared
  14. Apr 26, 2013 at 6:22 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Yea I found a tranny I'm going to swap in 2moro and ill try welding up the snout this coming week
  15. Apr 26, 2013 at 6:46 PM
    92dlxman
    Kevin
    Visalia, CA
    right on! glad its working out, so the only way for that to break would be throwout bearing binding on it right?
    I finally realize the bad design of this tranny, I thought all tobs rode on the input shaft, which would only make sense because its hardened . . . . . wtf were they thinking?
    and I didn't see the "custom fab" part under your name. . . . didn't mean to try and tell you about welding lol
  16. Apr 27, 2013 at 7:13 AM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Lol its all good. I'm about to start the job of dropping the tranny and hope my current finding is correct. As it turns out I show up at the yard to get the tranny and took one more look at it. Had the guy there get in and push the clutch for me. I could not see that the quill was broken but that the sleeve I put in is loose. Going to pull the trans and hope that is all that is wrong
  17. Apr 28, 2013 at 3:33 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Ok so heres the damage from today..
    The broken snout "quill" on left URD sleeve on right
    Swapped in my old driveshaft after swapping the rear u-joint and flange.. URD y-pipe and my custom straight pipe y-back
  18. Apr 28, 2013 at 5:08 PM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    I know of this happening about 4 times now.
    The ones I am aware of are from a clutch release system that is very far out of adjustment. What happens is the slave cylinder drives the release fork into the pressure plate while it is rotating and the collision force just destroys everything in the bell housing and snaps the snout right off.
    One of the checks that needs to be done before starting the engine after an installation of a new clutch, release bearing, or any combination of parts, is to have someone push the pedal all the way to the floor while you check the release mechanism and make sure it is not going to come in contact with the pressure plate.
    Then start it up and set the clutch push rod length so you have the proper and needed release of the clutch. Then check the release fork to pressure plate clearance again.
    The final check is to make sure you can push the release fork back and compress the slave cylinder into its self by hand. If not you will need to make sure the pedal is coming back up far enough to release the pressure on the slave cylinder.
    We see this problem all the time with people doing the "clutch pedal" mod which can prevent the pressure from coming off the bearing and preventing the pressure plate from applying its full clamp load on the clutch disc. Seen a couple of clutches burned up by this.
    G
    MikeD51 likes this.
  19. Apr 28, 2013 at 9:55 PM
    8BoltRacing
    Jared
    Greensburg PA
    The Angry Warthog
    Thanks Gadget well be sure to check everything when we button it all back up I was just horrified when I saw it today since I elected not to grab the trans Saturday morning even just as a backup plan.
  20. Apr 29, 2013 at 6:55 AM
    hladun
    Alberta
    Tacoma
    Enough instructions from URD that they can say no one ever installs the kit correctly. In the meantime transmissions keep failing. Then a little fearmongering about burning up clutchs. If Gadget is right F150's should be burning up their clutchs all the time. It's your money guys.
