budget freindly speedo corection
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacotruck 2.7, Feb 24, 2013.
  1. Feb 24, 2013 at 9:48 PM
    tacotruck 2.7
    tacotruck 2.7 [OP] Well-Known Member
    Katy TX
    09 cab and a half 2.7
    With all the tire swaping that goes on this forum does anyone know the cheapest way to correct the speedo after puting bigger tires on a second gen taco ?
  2. Feb 24, 2013 at 10:12 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    I used the SPEEDOHEALER on my motorcycle (on 4 so far actually over the last 11 years) since a motorcycle is normally ~8% high in mph/odometer. Piece of cake as they have the factory plugs, you simply put it in-line.
    http://www.healtech-electronics.com/
    I wonder if something exists like this for the Tacoma?
  3. Feb 25, 2013 at 6:03 AM
    2wheelnut
    2wheelnut Well-Known Member
    Angelo
    Vallejo, CA
    '11 S/C K.I.S.S. "Factory Enhanced" DC TRD OR
    TRD Supercharger, TRD First Gen CAI, TRD FJ Alloy, Toyo OC A/T II 265/75/16, 5100's Front and Rear, OME 885x with 1/4 taco lean spacer, Toytec AAL 1.5" non TSB. TSB not done. WheatherTech Side Window Deflector, Satoshi Grill, T Rex Eyelids, Matt123 Skid Black stamped, Modded Maglite with Maglite mod for driver seat, Bed extender. Full debadging
    I was thinking the same, I use speedo healers too. Older cars used gears in the transmission, if these are similar then I would figure they wouldn't be able to be corrected easily.
  4. Feb 25, 2013 at 6:16 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    22 JLUR 6MT
    You could use an ultragauge and just calibrate it. I have one and it shows MPH but I have been too lazy to calibrate it. I believe they are +- $70 after the rebate?
  5. Feb 25, 2013 at 6:18 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2 on the Ultragauge. It's easy and has a lot of other uses besides just showing you your actual speed.
  6. Feb 25, 2013 at 8:34 AM
    Agro
    San Diego
    I would have to imagine our speed sensor is electronic not a manual one. But I don't actually know.
    The nice thing about the SH over possibly other display devices is you actually reduce the # of miles your racking up on your odometer. I care about that as well.
  7. Mar 2, 2013 at 8:03 PM
    tacotruck 2.7
    Katy TX
    I just downloaded the ultragauge instructions and i did not see anything tire/speedo corection related. Is there a diffrent model ?
  8. Mar 2, 2013 at 8:13 PM
    KingDavey
    KingDavey Well-Known Member
    Think about it...
    Western Massachusetts
    2013 Regular Cab 4x4
    5100s, OEM back-up cam, JVC
    hypertech makes a speedo calibrator. I used to have one.
  9. Mar 3, 2013 at 4:47 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    There is a speed calibration on the UltraGauge. It does not change the speedometer, but gives you a readout on the UG that shows your corrected speed.
  10. Mar 3, 2013 at 5:30 AM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
  11. Mar 3, 2013 at 6:19 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Nice, I like that Hypertech one. Going to have to get when I lift my taco. Tks for link!!!
  12. Mar 3, 2013 at 7:06 AM
    DueNorth
    DueNorth Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Yes the Hypertech Speedo calibrator works really well... Fairly easy to install, just need to take your dash apart...
    or for a cheaper alternative, you could use a Dakota Digital...
