Budget retrofit headlights
Discussion in '1st Gen. Tacomas (1995-2004)' started by ToyotaJim, Oct 21, 2017.
  1. Oct 21, 2017 at 7:31 AM
    ToyotaJim
    ToyotaJim [OP] Well-Known Member
    Jimmy
    1999 Tacoma SR5
    Show me what you guys like in terms of budget retrofit headlights.
  2. Oct 21, 2017 at 7:43 AM
    tony2018
    tony2018 Well-Known Member
    Define this 'budget'.
  3. Oct 21, 2017 at 7:50 AM
    FromTejasWithLove
    FromTejasWithLove Well-Known Member
    Cale
    Hurricane, Utah
    '99 Taco SR5 4x4 V6; manual everything
    Turtle Top Shell, Rear Single Motorcycle Carrier, Refrigerator
    Post jack; Budget projection of "$300-500".
    99 Taco
    Thanks!
    ToyotaJim[OP] likes this.
  4. Oct 21, 2017 at 7:52 AM
    tony2018
    Wait for black friday. TRS will have a discount code you can use to get a complete d2s 4.0 w/ bulb and ballast plus harness. From there you should be able to take apart the headlight and swap in the projector.
  5. Oct 21, 2017 at 7:53 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    I did mine for about $500 including TRS'a cheapest projector kit line the ACME H1, new projector housings, front and rear switchbacks, and assembly by a member on here. All from the Black Friday deal.
    Sicyota04 likes this.
  6. Oct 21, 2017 at 8:27 AM
    FromTejasWithLove
    Cale
    Hurricane, Utah
    Right on. So to ensure my understanding is clear; I would be able to buy two of these units and then disassembly my current headlight assemblies and install these new components. Headlight upgrade done?
    Thanks
  7. Oct 21, 2017 at 8:59 AM
    tony2018
    Some adjustments are needed to align the projectors properly or else the output will be mis-aligned.
    FromTejasWithLove likes this.
  8. Oct 21, 2017 at 9:33 AM
    FromTejasWithLove
    Cale
    Hurricane, Utah
    Roger that partner. Waiting til Black Friday it is. Thanks guys!
  9. Oct 21, 2017 at 9:49 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    95 extended cab sr5
    cxr turbo, fic6, methanol injection, king coilovers, jba uca, skyjacker leafs, rear 12" 5125s, no-slip rear locker, 35" grabber x3, magnaflow muffler, retrofit headlights, trans cooler, bed lined exterior, etc...
    get aftermarket housings with clear lenses.
  10. Oct 21, 2017 at 9:52 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Trust me you don't want to reuse your old headlight housings. Get new completely clear housings.
  11. Oct 21, 2017 at 10:00 AM
    FromTejasWithLove
    Cale
    Hurricane, Utah
    Thanks for the heads-up.
    Is that something I need to get from TRS as well or can the housing be openly sourced?
  12. Oct 21, 2017 at 10:02 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You can usually get something good on ebay
  13. Oct 21, 2017 at 10:09 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Not saying ur wrong at all....
    Those words just rarely go together :fingerscrossed:
  14. Oct 21, 2017 at 10:12 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Amazon! Mine are still going strong. TRS doesn't sell headlight housings. I used these.
  15. Oct 21, 2017 at 10:26 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Just have to know what you are looking for. TYC or DEPO are good brands. If doesn’t say what brand it is, don’t buy it. Best advice I can give
  16. Oct 21, 2017 at 11:26 AM
    tony2018
    Just keep your old headlights just incase you need those pivoting screws and its plastic clips.
  17. Oct 21, 2017 at 12:42 PM
    FromTejasWithLove
    Cale
    Hurricane, Utah
    Thanks for preventing a potential headache.
