Bug Non Stick Coating
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sabre170, May 3, 2018.
  1. May 3, 2018 at 10:27 AM
    sabre170
    sabre170 [OP] Well-Known Member
    Drew
    My taco is my first white vehicle I've owned....that coupled with the fact that the front of a tacoma blasts through the air like the flat side of a frying pan results in lots of bugs really stuck on the front bumper/grill area. With the white, even more visible.
    I'm wondering if anyone has any product suggestions to put on the front of the truck as a coating to prevent the bugs from sticking so much. I've seen people put rain-x on vehicle fronts before, but pretty sure there are better products to be had. I used to use a honda brand spray on my motorcyle years back....worked wonders keeping the front clean. It left a really smooth, almost greasy feel to the front. Bugs would hit, but really wouldn't stick. If they did stick, a damp cloth would take them right off.
    Anyone have a recommendation for a non-stick-like coating to put on the front of the truck.....or if cost effective, the entire truck??
    I married my tacoma likes this.
  2. May 3, 2018 at 10:29 AM
    Yotaholic
    Yotaholic Well-Known Member
    Oahu, HI
    2017 DCSB Sport 4x4 MT
    I wax with Mother’s Caranuba and clean off dead bugs with Mother’s instant detailer.
    TFly and I married my tacoma like this.
  3. May 3, 2018 at 10:29 AM
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    I've used PAM kitchen spray on my snowblower plenty of times to grease the chute. Not sure if it will have the same result with bugs on a truck.
  4. May 3, 2018 at 10:34 AM
    sabre170
    Drew
    That would probably work wonders........probably would also cause all the dust and dirt to stick right to the front though. Haha...love it!
  5. May 3, 2018 at 10:41 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Ceramic coat it.
  6. May 3, 2018 at 10:49 AM
    dweg77
    dweg77 Active Member
    2016 MGM Tacoma SR5
    I am highly interested in this topic as well. Is a traditional waxing the best option, or is there something better/faster and more effective?
  7. May 3, 2018 at 10:56 AM
    Boomer3731
    Boomer3731 Well-Known Member
    2017 DCSB TRD Sport
  8. May 3, 2018 at 11:04 AM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    I have a Llumar clear bra on mine.
    Correct me if wrong, but caranuba is mostly for the darker colors? Go with synthetic wax like Mequiar"s Ultimate. You can apply that on all your exterior plastic as well. Not really a wax, but more of a sealant.
    Tactical_Panda likes this.
  9. May 3, 2018 at 11:11 AM
    pinochle
    NNJ
    Paint protection is great for protecting your paint. But then put a sealant over it, or better yet, ceramic coat the film.
  10. May 3, 2018 at 12:00 PM
    sabre170
    Drew
  11. May 3, 2018 at 12:04 PM
    Matt3400
    Matt3400 Well-Known Member
    2007 Lexus GX470
    Any color vehicle is fine.
    Yes, can use it on plastic and wheels.
    1 bottle should last you months
    Depends on vehicle use but don’t expect more than a month for this kind of product.
    Any properly applied, wax, sealant or coating is going to help protect and help making cleaning the vehicle much easier.
    sabre170[QUOTED][OP] likes this.
  12. May 3, 2018 at 12:27 PM
    commbubba19
    commbubba19 Well-Known Member
    '23 TRD PRO
    i've had two vehicles ceramic coated. sometimes, certain acidic soaps can break down the ceramic unevenly. making it repel water inconsistently and will not be warrantied. almost makes it more work to take care of vs traditional sealants and waxes.
    ceramic coating still scratches. advertising will say that's good since you're not scratching your clear coat. the bad is it's harder to repair ceramic coating vs the clear (and it's permanently bonded to the clear so basically what have you gained). you can either get ceramic re-loaders but they only last a month depending on weather, or reapply the ceramic and you really need that done professionally to make sure the repair holds and is even.
    consumer ceramics maybe last a year but are still dependent on what their exposed to. professionally installed and heat bonded ceramics maybe 3 years. will wear unevenly, and cannot be removed unless sanded off.
    i typically have a professional do a full paint correction. once that's done, use a sealant like adams or colonite.
    https://www.partsmate.net/Collinite...3aHXYlmJyxkq69BXgEk_eHrmDQ6r9dQsaArf-EALw_wcB
    Do your colonite twice a year and you're set. You can also add a filler of gel coat before applying the colonite or sealant to fill any scratches and add depth. any wax/polish etc and even some coatings have fillers that wear off. You apply it thinking you've fixed all your swirls but you're just filling them. after a few washes or rains, that filler desolves leaving you with your swirls. hence putting the sealant on top.
    sorry for the ramble. hope this helps.
  13. May 3, 2018 at 12:30 PM
    commbubba19
    '23 TRD PRO
  14. May 3, 2018 at 12:46 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Turtle wax Ice, wax, and Ice detailer spray works great. Bugs don't stick, they wipe right off with micro fiber.
  15. May 3, 2018 at 12:50 PM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
  16. May 3, 2018 at 12:51 PM
    Voltron4x4
    Denver, Colorado
    This and that...
  17. May 3, 2018 at 12:57 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Voltron4x4 likes this.
  18. May 3, 2018 at 12:59 PM
    TacomaMike37
    13' DCLB MGM
    That's what I use. Easy on, easy off.
    To those recommending Caranuba, well that is like using AOL dialup to get on the internet.
    snickers[QUOTED] and TFly like this.
  19. May 3, 2018 at 1:08 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    carnuba has nothing to do with color. Some companies might add pigment in their waxes for colors or to try to fill in light swirls but its either carnuba wax or synthetic sealants. Generally carnubas have a "warmer" look to them while sealants last a lot longer. I get about 4-6 months out of mine before all beading is gone. I use menzerna powerlock.
  20. May 3, 2018 at 1:09 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Not really, you can use both carnuba on top of sealant if you want for a little more pop.
