Building first home
Discussion in 'Off-Topic Discussion' started by Tacomada, Apr 4, 2012.
  1. Apr 4, 2012 at 4:24 PM
    #81
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    The BTU's from the proper size fire as well as placement can change cost of cooling and heating on a house drastically. Pools in my opinion are useless...
  2. Apr 4, 2012 at 4:31 PM
    #82
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Well no shit
  3. Apr 4, 2012 at 4:34 PM
    #83
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Well being that I worked in the industry I saw plenty of clientel over step or under step the fireplace and then when it was done and said with wonder why the fireplace didn accomplish what they wanted.....
  4. Apr 4, 2012 at 4:35 PM
    #84
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    huh?
  5. Apr 4, 2012 at 4:38 PM
    #85
    Phil Dammit
    Your Mom
    Tempe, Arizona
    OSB, was texting a friend about the Outer Banks while replying......
  6. Apr 4, 2012 at 4:38 PM
    #86
    OZ-T
    Peter North
    British Columbia
    Woodstove > fireplace
    Especially up here as they are quite often used as a main source of heat .
    Couple that with the thermal massing properties of the concrete over framing for the hydronic system and the house stays warm in between burns .
  7. Apr 4, 2012 at 4:43 PM
    #87
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Agree'd
  8. Apr 4, 2012 at 4:47 PM
    #88
    Larry
    Larry CARL
    CARL
    is not recommended for a custom build.
  9. Apr 4, 2012 at 4:51 PM
    #89
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Why is that?. OSB, these are similar to the walls that I discussed in my engineering class last semester.
    http://www.ibpanels.com/
  10. Apr 4, 2012 at 4:57 PM
    #90
    Larry
    Larry CARL
    CARL
    I recommend 4 ply plywood sheathing over OSB sheathing.
    I have used OSB for budget reasons in the past. But if one is building a custom home (OP)...I would not use OSB.
    yes...it is engineered. but real plywood is better IMO.
    and those insulated panels are a PITA...and designed for production. I couldn't use them in FL if I wanted to anyway probably.
  11. Apr 4, 2012 at 4:58 PM
    #91
    Tacomada
    Tacomada [OP] Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    www.logixicf.com is the website for the company that manufactures the forms we plan on using.
    There are different levels of forms. The main reason to use these is the extra insulation an efficiency, and the sound insulation. It's also a little quicker than framing a house, less labour.
  12. Apr 4, 2012 at 5:03 PM
    #92
    Larry
    Larry CARL
    CARL
    I'd use insulated forms for the foundation...
    but I'd frame and insulate the walls. just an opinion.
  13. Apr 4, 2012 at 5:08 PM
    #93
    OZ-T
    Peter North
    British Columbia
    I never use it , only plywood
  14. Apr 4, 2012 at 5:12 PM
    #94
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Definitely still an option.
  15. Apr 4, 2012 at 5:12 PM
    #95
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Layout looks awesome for a young family starter home!
    Cheers.
    P.S. I especially like the large garage! ;)
  16. Apr 4, 2012 at 5:16 PM
    #96
    OZ-T
    Peter North
    British Columbia
    The ICF's prevent thermal bridging as you would see through the framing in a conventionally framed wall , having said that , I would lean toward ICF's for the foundation , conventional 2x6 ( R20 ) wall framing , covered in 1" of exterior XPS foam insulation panels
  17. Apr 4, 2012 at 5:18 PM
    #97
    Phil Dammit
    Your Mom
    Tempe, Arizona
    This is a production home though, not a true "custom home". With the area that he is living sip ext/int walls will reatian a much higher R value than framed wall construction. And SIP walls are for anywhere.
    Agree on the foundation
    I wouldn use OSB on the roof even though they say you can with these panels. The only disadvantage to SIP walls with OSB is their tolerance to water is significantly lower then that of ply. However if you have water on your osb or ply then there are other factors at play. The cost of OSB versatility of use, and impact on the planet out weigh its one and only disadvantage to ply.
  18. Apr 4, 2012 at 5:27 PM
    #98
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    FWIW ... I would build my whole house out of this if it was available at that time ...
    Last week ... a Home Depot here had several pallets (from Chile) of ... "4'x8'x3/4" cabinet grade (7 ply) plywood" ... at $17.95 each on a 1 day special. ... :eek:
  19. Apr 4, 2012 at 5:29 PM
    #99
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Fortifiber is making a product now that rivals Tyvek flexwrap, the bonus is that is doesn't have the pull back that the Flexwrap has. Also, stateside, Tyvek is struggling a bit, the theories behind their technology are fading and rain screens are becoming prevalent. Soon to be code.
  20. Apr 4, 2012 at 5:30 PM
    #100
    MTgirl
    Weesa
    Bob's secret mod lair
    why? :confused:
    :popcorn:
    plywood...you only have two strength axis along the grain of hte wood. OSB you have multiple, overlapping axis. plywood is available only as large as 4x8, OSB up to 8x24 in most cases. while osb is more cost effective is is also an engineered product and is stronger than ply. it is also a greener, more easily produced product
    :popcorn:
    :quickdraw: you again?!?!
    :rolleyes:
    :cool: I can agree wit that
