Building first home
Discussion in 'Off-Topic Discussion' started by Tacomada, Apr 4, 2012.
  1. Apr 4, 2012 at 5:30 PM
    #101
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OSB swells , sometimes significantly , if it gets wet during the build , and it is essentially ground up sapwood , we call it beaver puke .
    It moulds fast , in our area it is not significantly less expensive than 1/2" standard plywood .
    The OP and myself live in the temperate rainforest region of coastal BC , it WILL rain on your frame before you get the roof on .
  2. Apr 4, 2012 at 5:32 PM
    #102
    OZ-T
    Peter North
    British Columbia
    Rainscreen is code here , and in my experience , I haven't ever had a spring back issue with FlexWrap , although we did have some problems with Typar's equivilent to Flexwrap
  3. Apr 4, 2012 at 5:32 PM
    #103
    Tacomada
    Tacomada [OP] Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    I don't know about other methods of construction, have only seen 2x6 and some of these icf homes up here. Majority are 2x6 as that's basic code requirement.
    Another factor is our snow load. 112.7 Psf ground snow load. Combined with whatever the rain factor is. Things have to be engineered pretty sturdy up here.
  4. Apr 4, 2012 at 5:32 PM
    #104
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    X2 get yourself some good 5 ply CDX 1/2" and be sound.
  5. Apr 4, 2012 at 5:35 PM
    #105
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    For some reason I was thinking north east. Not BC, dont know what I was reading. Yeah it would be a bitch to try and keep the OSB dry during construction. Out here in the desert its prime for use. Im sure their are manu's that will do SIP with ply sheathing.
  6. Apr 4, 2012 at 5:35 PM
    #106
    Fightnfire
    Marysville, WA
    We've seen a lot of issue with mold where the Tyvek product pulls away from the bottom corners in window installs, after install. The problem comes when expansion contraction, or shoddy application, and the corner of the window punctures the flexwrap and water can then get behind the moisture management system and into the walls, or trapped.
  7. Apr 4, 2012 at 5:35 PM
    #107
    OZ-T
    Peter North
    British Columbia
    If OSB is so much stronger than plywood , why are all our site built seismic shear and portal walls spec'ed to be framed of plywood and not OSB ?
  8. Apr 4, 2012 at 5:36 PM
    #108
    OZ-T
    Peter North
    British Columbia
    Your truss manufacturer will factor in the snow load when designing your trusses .
  9. Apr 4, 2012 at 5:37 PM
    #109
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Is this construction all happening up in BC? If so your answer to me will anwer your own question. The market value to the area and again climate as you stated ealier.
  10. Apr 4, 2012 at 5:39 PM
    #110
    Fightnfire
    Marysville, WA
    Aye OSB is not stronger than Plywood. Also, it shouldn't get wet during framing tho most manufacturers allow a certain time of exposure before it has to be covered up. Weyerhaeuser makes a product for floors, edge gold, that resists moisture wicking and has a way longer saturation point.
  11. Apr 4, 2012 at 5:39 PM
    #111
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Yeup they will do your live load and dead load according to snow fall of the region. However, if you are going to expand the ext walls to code 2x6 then you will have overall dimension shifts. The OP OG plans call out for 2x4 ext walls.
  12. Apr 4, 2012 at 5:39 PM
    #112
    MTgirl
    Weesa
    Bob's secret mod lair
    So you've never ever used Simpson Strong Walls? Ply has its limitations too.
  13. Apr 4, 2012 at 5:39 PM
    #113
    OZ-T
    Peter North
    British Columbia
    I would suggest that is more poor detailing , and again , a drained 10mm rainscreen cavity between the paper or housewrap and the back of the siding is code here .
  14. Apr 4, 2012 at 5:40 PM
    #114
    Fightnfire
    Marysville, WA
    Also, the green aspects of OSB are debatable and really relies heavily on the manufacturing processes to be considered green.
  15. Apr 4, 2012 at 5:40 PM
    #115
    OZ-T
    Peter North
    British Columbia
    You spec seismic shear walls sheathed in OSB ?
  16. Apr 4, 2012 at 5:42 PM
    #116
    Phil Dammit
    Your Mom
    Tempe, Arizona
    did an elevated 600 sq. ft. cantilevered tree house employing this wall usage, but that is a discussion for another thread.
  17. Apr 4, 2012 at 5:43 PM
    #117
    OZ-T
    Peter North
    British Columbia
    Yes , I have
    Simpson Strong walls are designed to reduce the amount of wall it takes to provide the desired lateral resistance , their use has nothing to do with whether OSB is as strong or stronger than plywood
  18. Apr 4, 2012 at 5:43 PM
    #118
    Fightnfire
    Marysville, WA
    Isn't that intended for use in areas where they don't shear the whole house? In the pacific NW and in Canada the whole house is sheeted top to bottom. I thought shear walls like Simpsons were intended for use on the corners or around openings to regain shear.
    Anywho, it hasn't and won't catch on out here. Other than engineered floors almost everything else out here is framed with wood and sheeted.
  19. Apr 4, 2012 at 5:44 PM
    #119
    OZ-T
    Peter North
    British Columbia
    Interesting .
    No issue with the nails pulling through the OSB easier than through plywood of a comparable thickness during a seismic event ?
  20. Apr 4, 2012 at 5:45 PM
    #120
    OZ-T
    Peter North
    British Columbia
    See my post
