Building the "BEAST"
Discussion in '2nd Gen. Builds (2005-2015)' started by awsumdc, Jan 7, 2009.
  1. Sep 22, 2012 at 4:50 PM
    #921
    awsumdc
    awsumdc [OP] Well-Known Member
    O.C. Cali
    SASED '05 Taco
    SAS, crawler box, 14" coilover shocks, 39.5 tires,dual batteries, and a bunch of other stuff
    Update!
    Got the winch installed and hooked up. Just need to do the in cab stuff now. Man, these things just never stop.
    Moved the solenoid to the engine bay. Now all I have to do is hook up the incab wiring and I'll be good to go.
    I made new wires from 2/0 cable and ran them into the engine compartment and then put heat shielding on them as they go into the solenoid.
    Ran them through the radiator core support and to the winch.
    Put some nifty terminal protectors on the ends and it made for a nice clean install.
    Finished everything up, made a plate to attach the solenoid box to and bolted it to the inner fender. Even made it so you can only see one of the wires coming from the solenoid and not a bunch of big ass wires sprawled every where.
    Next is doing the in cab wiring and moving the hand held remote terminal from the top of the solenoid box to the inside of the cab.
  2. Sep 23, 2012 at 8:31 AM
    #922
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Damn nice install. s e x y !
  3. Sep 23, 2012 at 9:33 AM
    #923
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Thanks Man.
  4. Sep 23, 2012 at 9:34 AM
    #924
    Ugly Betty
    mark
    TX
    where'd you get those terminal protectors, i want some. makes for a real clean install
  5. Sep 23, 2012 at 3:16 PM
    #925
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Got the in cab controls done today. Works like a charm. Next I'll move the remote hand held plug in to the inside of the cab.
    Instead of using the black screws that came with the switch, I went and bought some stainless steel allen head bolts and used those. Gives it nice and neat aircraft look I think.
  6. Sep 23, 2012 at 3:18 PM
    #926
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Let me check for you. I got them online but don't remember where. Need to go to my emails.
  7. Sep 23, 2012 at 3:18 PM
    #927
    Ugly Betty
    mark
    TX
    Awesome switch!
  8. Sep 23, 2012 at 3:19 PM
    #928
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    check out 12voltguy.com
  9. Sep 23, 2012 at 3:21 PM
    #929
    Ugly Betty
    mark
    TX
    Amazon(where i do most of my shopping) has a few, but none that nice
  10. Sep 23, 2012 at 3:21 PM
    #930
    Ugly Betty
    mark
    TX
    will do, thank you sir
  11. Sep 23, 2012 at 3:24 PM
    #931
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Yeah. The in cab controls is from the 12volt guy. Good system I think. Easy to use and easy to set up. Very well made too.
  12. Oct 4, 2012 at 7:54 PM
    #932
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
  13. Oct 23, 2012 at 4:55 PM
    #933
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Took the Beast out for a real test in Arizona.
    http://www.youtube.com/watch?v=jgHeMpkLNZU
    All the up grades worked better than we thought. the new front DeMello plate bumper allowed a better approach angle than before because of how tight it is to the front of the truck while still allowing for a winch. The new Currie Rock Jock has more clearence than the other axle and the three link rear suspension worked far better than the old leaf spring set up did. Without those three changes I would have never made it up that fall.
  14. Oct 23, 2012 at 8:50 PM
    #934
    Ugly Betty
    mark
    TX
    I was sweating watching that. Fu...g ridiculous man! You never fail to amaze me wyatt!
  15. Oct 23, 2012 at 8:54 PM
    #935
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Holy jeebus!
  16. Oct 24, 2012 at 5:06 AM
    #936
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Thanks man
    LOL. Yeah, I had to change my pampers after that one. Way more scary in the drivers seat because you know your rear tire is close to that ledge but you just dont know how close. And if it slips off your in the water head first.
  17. Oct 24, 2012 at 5:43 AM
    #937
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Question mark, on your three link rear, when your axle is articulating left to right, does it roll the axle forwards and backwards?
    Also when it gets under a severe load, are you seeing it force your truck to lean, or any rise and squat?
    I have never seen this type of link setup and it has me wondering. Thanks
  18. Oct 24, 2012 at 9:37 AM
    #938
    Delmarva
    Tucson, AZ
    The day you decide to sell the beast, make sure you PM me first... :p
    :D
  19. Oct 24, 2012 at 6:15 PM
    #939
    awsumdc
    O.C. Cali
    SASED '05 Taco
    No roll forward or backwards like you would get with a leaf spring nor does it cause the truck to lean or squat/rise.
    In fact, this set up is far more stable than the three link front and rear leaf that I had before. And thats with no sway bars at all.
    This three link set up is actually used alot in the Cobra replica scene and hot rods. They seem to handle very well.
    I wanted to see it would handle with 41" tires on a mountain road so I drove it down from Payson to Mesa Arizona while my wife drove the tow rig behind me. Other than some unbalanced tires it drove better than it did when I had the leaf springs and 40" tires. The opposing panhard bars front to rear cancel any weird or unwanted behavior and like I said before, that is with out sway bars.
    Here is another build I helped on with the same setup as mine.
    http://www.rocksolidtoys.com/forum/showthread.php?t=19
    I love this setup and will build another like it but not as big as the Beast.
  20. Oct 24, 2012 at 6:16 PM
    #940
    awsumdc
    O.C. Cali
    SASED '05 Taco
    Will do....
