Built Right UCA Alignment too much Caster?
Discussion in 'Suspension' started by tonyplanet, May 22, 2011.
  1. May 22, 2011 at 1:25 PM
    tonyplanet
    tonyplanet [OP] Well-Known Member
    Glendora, CA
    09 Tacoma 4x4 TRD Off-Road
    enough to get me there
    Got my alignment done yesterday. Numbers look good for toe and camber. But getting too much positive caster. I'm getting 4.7 and 5.0 positive caster. Optimal is 2.4 for 33" tires. Tech says that's the best he could do and its because of the uca.
    Not sure if I should take the tech's word, or go some other place and get it realigned.
    My question, can caster be adjusted? Or is it fixed, because caster is built into the uca?
  2. May 22, 2011 at 1:30 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it can be adjusted, but it is changed by the UCA. Go to another shop and see if they can do better then follow up with Built Right.
