built up 4.0l
Discussion in 'Performance and Tuning' started by zkdawg, Feb 13, 2015.
  1. Feb 13, 2015 at 9:38 AM
    zkdawg
    zkdawg [OP] Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
    I was wondering if any one has built( after market ) there 4.0l v6 and if so, what did u do ( in detail ).
    I was just pondering the idea instead of a s/c.
    Is there a better power to price ratio compared between them?
    I searched for this stuff on here with no luck and that's the reason for this post.
    Hopefully this will be helpful for anyone interested.
  2. Feb 13, 2015 at 9:52 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Forced induction is the only way to get noticeable gains man.
  3. Feb 13, 2015 at 10:21 AM
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    So, if I was to bore out the motor and get digger pistons then there won't be much diff?
  4. Feb 13, 2015 at 10:23 AM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
  5. Feb 13, 2015 at 10:25 AM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Tor's and Cliff's thread will give you all the info you need. Cliff just sold his long block stroker not too long ago. Believe he stroked out to 4.7 or 4.8.... Stroked motor with s/c would be nice. But at the price point to build its cheaper to go LS3 or LSX....
  6. Feb 13, 2015 at 10:28 AM
    Phil Dammit
    Your Mom
    Tempe, Arizona
    I think long block was somewhere in the 5 to 6k range for Cliff, tor is on a playing field all to himself with the amount of money he has in his motor.
  7. Feb 13, 2015 at 3:57 PM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
  8. Feb 13, 2015 at 4:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    I'd guess that if you have to ask this question (because you aren't familiar with the engineering/calculations required; lots of on line calculators are available), you don't need to undertake the project.
    Not being mean here, just seen it too many times before, across all marquees.
    Even if you figure it out, be sure to do a $/hp calculation as well. You will likely find that a full transplant of something with more grunt and more aftermarket support would be much more feasible.
  9. Feb 13, 2015 at 5:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    His is a 4.3L.
    Poor tuning methods did his blew his head gasket. Good thing though, with all of that built hardware in there, it is easily rebuild-able.
    There have been others to buy built engines from URD and LC Engineering. Those are all running strong, as long as they have been properly tuned.
    I have only one component in mine that others in the States don't have. Nothing to special, except that they are almost harder to find than a unicorn. My custom Kelford Cams.
    If you are going to get an engine built, either send yours in, or have them do all of the sourcing and work for you. It will save you loads of headache. :thumbsup:
  10. Feb 14, 2015 at 12:23 PM
    zkdawg
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Thx for all the info guys.
    I'm not saying I am going for it, just curious as to what it would cost.
    I have a guy In my area that has bored out some stuff and decked some stuff before and he is cheap so I was thinking of maybe some pistons and a cam.
    Probably nothing more.
    Just a thought.
    Thanks though
  11. Feb 16, 2015 at 10:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only one place sells completely new cams. Another uses your stock cams. Both are about the same price. ~$1400.
    I don't recommend the cams,unless you thoroughly discuss them with a company like LC Engineering. Due to the technical nature of it with the VVT-I. Otherwise you could end up with pistons pistons valve damage.
    You can get one set through LC Engineering.
    If you're changing pistons, do the rods too.
    Molnar rods are the cheapest cost wise. On up to CP Carrillo. www.Dezod.com carries both.
  12. Feb 17, 2015 at 6:49 PM
    11 Tacoma
    11 Tacoma Active Member
    Sacramento
    TRD Off Road 2wd
    For the price ratio to power I don't think you can beat a SC. Although I don't understand why you would SC a tacoma. Put a SC on a tacoma and you get 60 HP?? Put a SC on a sports car and you get 200hp
  13. Feb 17, 2015 at 8:02 PM
    NfiniteZERO
    NfiniteZERO Well-Known Member
    Matthew
    Boise, ID
    2013 Double Cab TRD Sport
    AVS BugFlector and Vent-visors, Wet Okole seat covers, Extang Trifecta Signature,
    Depends on the SC, tune, and any supporting mods. TRD's Roots blower was designed to be run on the factory engine block with only a ECU reflash and to be reliable enough to stick a warranty on it.
    URD's Rotrex makes a lot more power and is a better built, more reliable kit. Especially if you add the supporting mods. Gadget's truck (Gadget@URD) was just dyno'd at 539HP and 441 ft/lb of torque on 93 ocatane. His 1GR is built, sleeved, and stroked.
    I'm going with the URD kit in due time.
  14. Feb 17, 2015 at 8:23 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Efficiency. TRD is solid, good, and easy. No TRD kit ever puts out high numbers. Rotrex or turbo kit will gain you exactly that at ~ 8psi, to the wheels. Going past that safely and reliably, and internals are strongly recommended.
