BULL BAR QUESTION??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2006TRDSPORT, Oct 12, 2011.
  1. Oct 12, 2011 at 6:02 AM
    2006TRDSPORT
    2006TRDSPORT [OP] 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    I have what I believe to be a good question but we shall see. I have a lift put on my 2006 DC Tacoma using 5100's up front set at 2.5" w/stock coils. I know that once you go up around 2.5" or so, it's a good idea to get aftermarket UCA's, my question is if I got a bullbar would the weight of that therefore bringing the front down a bit decrease my need for the UCA's, or would it not matter. I have driven the truck over 800 miles post lift including ALOT of highway miles, and only really noticed it being a little squirrely on a few occasions, otherwise drove great with stock UCA's. Thanks for any suggestions/answers!
  2. Oct 12, 2011 at 6:04 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Something like a Westin bull bar would not have enough either to squat the front end. An ARB Bull Bar would do the trick but that's a whole different animal.
    It's squirrely most likely due to alignment. Do you have your alignment specs handy? Also, the truck is higher so the center of gravity is higher also contributing to the problem (slightly).
  3. Oct 12, 2011 at 6:05 AM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    i don’t think a bull bar would compress the shocks much if any at all.
    edit: never mind Pugga beat me to it.
  4. Oct 12, 2011 at 6:09 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Yeah....my bull bar is real light so it wouldn't benefit you at all.
  5. Oct 12, 2011 at 6:14 AM
    SuperTacoma
    SuperTacoma Well-Known Member
    Clint
    Georgia
    2019 Double Cab SR5 4x4 Silver
    They don't do much. A bull bar is more cosmetic.
    I hit an animal in an F150 I had with a bull bar it dented the bar pretty good and still pushed it into the fender, now it did save the fender from be damaged too much but the bull bar was a complete lost.
    my 2 cents.
  6. Oct 12, 2011 at 6:29 AM
    2006TRDSPORT
    Felton, Delaware
    Thanks for the help, I was thinking they might not weigh all that much but wasn't sure. I do still feel a bit of vibration/minor wandering occasionally at certain speeds so once I return to the states I'm gonna get it re-aligned & tires rotated/re-balanced, and hopefully that will do the trick. If not, I'll be investing in the UCA's.
  7. Oct 12, 2011 at 7:27 AM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN WYOMING
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    arb bull bar is what you want lol i'm pretty sure i could hit a cape buffalo and be completely fine lol
  8. Oct 12, 2011 at 7:56 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    Did you have it aligned after the lift? I did a full 3" lift front & rear with stock UCAs and have no problems. Did 85 and feels fine. What size tires are you running? I've heard larger tires can make this happen with stock UCAs.
  9. Oct 13, 2011 at 1:18 AM
    2006TRDSPORT
    Felton, Delaware
    Yes, I had it all done at once. I put on the lift, got new tires installed, alignment & balancing & have 265/70/17 size tires. It is not THAT bad, I only noticed it a few times and that was while driving a total of about 800 miles mostly highway. It could have been other factors such as wind etc. but I really don't think it was that windy & of course I was paying VERY close attn due to all the horror stories on here of lifts & needing UCA's. When I'm in town, I have no problems other then a mild vibration between 20-30 mph. One thing I know for sure is the tires need balanced again because the steering wheel vibrates at highway speeds, not to bad but definitely noticable. Luckily I have lifetime balancing with the Nittos I had installed. :D
  10. Oct 16, 2011 at 12:58 PM
    wheresmikeys
    wheresmikeys Get Some
    Michael
    Red Lodge, Montana
    08 Tacoma SR5 V6 TRD Off Road
    ARB Bumper. Old Man Emu Suspension Dont leave home without it
    I had an ARB Bull Bar on my 98 Taco, my 83 FJ60 and I have one on my 08 Taco. I didnt notice much sag or performance difference with either. What I DID notice is that when you hit deer at 60+ MPH:eek: is a thud and a little wobble in steering, then nothing.:D
    Although, with my 08, i notice a lot of vibration from the ARB on bad washboard:confused:
