Bully Dog GT-T+ Toyota Tuner
Discussion in 'Performance and Tuning' started by tcBob, Aug 28, 2013.
  1. Nov 20, 2016 at 6:41 PM
    #701
    Hunter223
    Hunter223 Member
    Hunter
    2015 Toyota Tacoma
    K&N CAI and Flowmaster Dual Exhaust
    Currently out of stock actually
    https://urdusa.com/store/p126051905...t-for-Toyota-1GR-FE-4.0L-V6/product_info.html
  2. Nov 20, 2016 at 11:00 PM
    #702
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Ok, let me correct your statement really quick, your only tuning options that are plug and play are UCON or Unichip, but if you're willing to splice in to your ECU, your bank account is the limit.
    In addition to that, while I agree the BD tuner is junk, I don't think you could expect many gains with an almost completely stock truck. Ok ok you have some random CAI, which we don't need to go into the argument of "the stock intake is already a CAI" and all that.
    And on the subject of UCON, URD issued a statement somewhere saying now that they have the harnesses made for 2005-2015 Tacomas, they are re-supplying UCON stock to match up with their Superchargers before they release the 2009+ UCONs for separate sales. Give it a year tops and I'm sure you'll be able to grab a UCON, which is designed for Tacomas, not a just tuner with a Tacoma random map in it (that doesn't work?
    Torspd likes this.
  3. Nov 26, 2016 at 10:06 AM
    #703
    Grinzler
    Grinzler Member
    Does the Bully Dog come with any tunes on it? Or do I have take it in to get tune files?
  4. Nov 26, 2016 at 9:00 PM
    #704
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
    Picked up a Bullydog Tuner and a Supercharger from a member here today.
    Sending the Supercharge in to have it looked over and rebuilt. So I will be a month without it. Thought I'd play with the tuner and see what it can do for a stock vehicle -- if anything.
    So I am having some issues with the tuner. The model number for the tuner is 40417
    We uninstalled / unlocked the GT tuner from a 2009 Tacoma with a SC. Verfied the status on the Tuner is "unloacked" Then I tried to change vehicle type to a 2006 Tacoma with a Manual Transmission, normally aspirated engine but came up with the following error screen after selecting Toyota> Tacoma> Manual Transmission > 2005-2008 ;
    I pulled the SD card from the unit and viewed all files via PC. I noticed that out of all the files (for all applications), there is no "GTGUT06.GTG"
    The only files I see for the Taco are;
    GTGUT01.GTG
    GTGUT02.GTG
    GTGUT03.GTG
    GTGUT04.GTG
    GTGUT05.GTG
    I then used the bullydog update agent to download all applications to the SD card. Same files after most recent update.
    I do have the ability to select; Toyota> Tacoma> Automatic Transmission > 2005-2008 and the tuner will successfully change to this application file.
    What am I missing? I assume I have to run the MT tune and that the Auto isn't the same?
    I've sent an email to bullydog tech support to see if they can help.
    Anyone have a backed up previous version / file GTGUT06.GTG they could send me?
  5. Nov 29, 2016 at 7:03 PM
    #705
    DistortedAxis
    Toronto
    STOCK
    Anyone?
    Unable to reach anyone at Bullydog two days in a row. Left 3 messages and an email.
    Nothing...
    thewarriordinghy likes this.
  6. Nov 30, 2016 at 11:12 AM
    #706
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I know the bd tuner doesn't work with the 06 auto with s/c either. Worked fine with my 06 pre s/c. Just got the tuner magnuson sells with their s/c but I haven't looked to see if it's compatible with an 06 yet
  7. Dec 1, 2016 at 12:02 PM
    #707
    DistortedAxis
    Toronto
    STOCK
    Finally, 4 days later Bullydog tech support tells me that the latest update somehow removes file GTGUT06.GTG from the card which results in the error for the MT 2005-2008 Tacoma when changing to this vehicle type.
    They sent me the file via email. Saved the file to the card.
    All is right with the world again.
  8. Dec 9, 2016 at 8:00 AM
    #708
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well done, and thank for posting the fix for the 2005-2008 Tacoma Bull Dog MT flash. (<Typed to facilitate quick future searches) :thumbsup:
  9. Dec 10, 2016 at 3:17 PM
    #709
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    A very simple question, with I assume a simple answer;
    When do I run the BD tuner? It's after the installation of the SC correct? However the instructions of the Magnuson SC say that's the first thing you do. Confused.
  10. Dec 10, 2016 at 3:28 PM
    #710
    glorifiedwelder
    jason
    Santa Clarita, ca
    They recommed you install it first in case you have issues loading the tune. That way you don't end up with a supercharger and in tuned ecu
    Torspd likes this.
  11. Dec 10, 2016 at 3:28 PM
    #711
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Before you start the truck with the new larger injectors and s/c.
  12. Dec 10, 2016 at 3:34 PM
    #712
    Camby
    Brian
    Denver
    Thanks for the confirmation, that's what I thought. Why would they list it as the first step? Lol
  13. Dec 10, 2016 at 3:52 PM
    #713
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  14. Jun 11, 2017 at 6:30 PM
    #714
    Tacohago
    Tacohago Well-Known Member
    Jake
    2009 Toyota Tacoma TRD
    Does anyone have any good results with the bully dog?
    Any videos on it also I haven't seen one video with a bully dog on a tacoma would be much appreciated if somone posted one!
  15. Jun 11, 2017 at 11:11 PM
    #715
    Del Scorcho
    Del Scorcho O-------l
    Eagle, ID
    DCLB 6 banger, 4X and Super Charged
    Magnuson Supercharger, 2.85 Stealth Pulley, TRD Baja Suspension, Walbro Fuel pump, Icon add a leaf, Method 701s
    I haven't had any problems with mine. But my BD tuner came with the Supercharger from Magnuson. Since my ECU was reflashed years ago for the "spark knock noise" service bulliten, it couldn't accept the original TRD tune from Toyota. So if I wanted the SC, I had to go with the BD or get a new ECU.
    Magnuson just uses the BD tuner as a way to deliver their tune for the Supercharger. Which according to Dan and Magnuson, its nearly identical to the TRD flash. They are the ones who had the contract with TRD to develop and build the original TRD Superchargers for the 3.4 & 4.0s. I feel safe assuming they know what they're doing.
    BD actually has a "performance tune" for Supercharged Tacomas that are intended to work on top of the TRD flash. I won't touch that with a 10ft pole. From what I understand, that tune is the one that has been causing all the problems. And the with the BD being so invasive along with Toyotas ECU that really won't let you do anything more than once, it a temperamental combo.
    gersus likes this.
  16. Jun 12, 2017 at 6:52 AM
    #716
    Camby
    Brian
    Denver
    Ive had good results with the Magnuson Tune. Had my truck dyno'd to check Boost vs AFR numbers, and sent the graph to Dan of Magnuson, and it was perfect. Still want to install an AFR and boost gauge, but so far so good!
    Lord Helmet and jojotoo like this.
  17. Jun 12, 2017 at 7:37 AM
    #717
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Got a chart? It'd be great to add to this thread.
    https://www.tacomaworld.com/threads/1gr-fe-f-i-mods-and-dynos.465243/
  18. Jun 12, 2017 at 11:14 AM
    #718
    Camby
    Brian
    Denver
  19. Jun 12, 2017 at 11:42 AM
    #719
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    screen shot or print out of your dyno results ?
    and list of your mods..
    Mag SC
    pulley
    tune.. etc etc
    Lord Helmet likes this.
  20. Jun 12, 2017 at 12:21 PM
    #720
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct. All mods. Including boost/pulley size.
    Elevation if you can, as well as ambient temp.
    Tire/wheel size, whether stock or changed.
    Gears, if not stock.
