Bummer! Took my truck in for service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gunnyz39, Nov 4, 2011.
  1. Nov 4, 2011 at 12:38 PM
    gunnyz39
    gunnyz39 [OP] Well-Known Member
    Shawn
    Albuquerque, NM
    Tacoma TRD 4x4
    Elusive Elements Grille & Behind Grille Lightbar, Tacoma-World sticker + 10 hp
    Bummer! So I took it into the Toyota dealership for the $25 oil change special and the 3 safety recalls. I requested they do a full inspection (which was free) they advised me the 30,000 mile service was denied by previous owner so the power steering viscosity is water, and needing flush as well as the diff housing and transmission fluids also coming up on their 2nd revolution. The tech said I have 5% fuel pressure when 9% is needed and they traced it to over carbon buildup in the throttle body and also injectors starting to get damaged due to that. Also informed me the spark plugs need replacement and that the alignment was off.
    Question 1: can I just clean my throttle body and replace some spark plugs?
    I told them not to mess with anything as I'm sure I could do most of that stuff cheaper by myself.
    Let me know your opinions.
  2. Nov 4, 2011 at 1:04 PM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    :sadviolin:
    Post your current mileage... that sounds like a little bit too much....
  3. Nov 4, 2011 at 1:07 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    Sounds like you got a bit of the old "scare tactics"! Spark plugs, throttle body cleaning, diff fluids, all easy DIY's. I think i would loose my job if i told my customers that kind of crap!!!
  4. Nov 4, 2011 at 1:10 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Change the fluids yourself...and don't worry about the other crap imo.
  5. Nov 4, 2011 at 1:12 PM
    Toyota Tech31
    Debary, Florida
    Plus, where did this "tech" even get his numbers from? This is how it reads in the repair manual:
    m) Measure the fuel pressure.
    Standard:
    281 to 287 kPa (2.87 to 2.93 kgf/cm2, 40.8 to 41.7 psi)
    5%-9%??????????????????
    I think i would be looking for a new shop, if it were me.
  6. Nov 4, 2011 at 1:16 PM
    jeremy_283
    Get the tune up in a bottle sort of stuff
    :yay:
  7. Nov 4, 2011 at 1:31 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Someone care to explain to me how carbon buildup in the throttle body could possibly lead to reduced fuel pressure and injector damage?
  8. Nov 4, 2011 at 1:35 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    IF the fuel going to the throttle body was impeded...then the fuel pressure would go UP, not down. basic engineering.
    i would ask them to explain this. like putting your thumb over a garden hose..the hose will stiffen up from the increased pressure. and "%" is not a unit of pressure. i call BS. find another shop.
  9. Nov 4, 2011 at 1:41 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're up for it, here's how to clean the throttle body:
    http://www.tacomaworld.com/forum/technical-chat/94203-how-throttle-body-cleaning-2005-v6.html
    I'm guessing you're at 60k miles since you said spark plugs are coming up on their second cycle so you should change the spark plugs and diff fluid if you haven't done so yet. Spark plugs are relatively easy to swap out with basic tools and a little time. You don't need a flush for diff, just a drain and refill. Your call on the transmission fluid, but a drain and refill would probably suffice depending on your mileage. Some stealerships have actually told people not to change their tranny fluid (I'm not buying it personally but it's been said). Power steering fluid, if it's not making any weird noises and seems to function fine, tell them to go fly a kite.
    FWIW, I changed plugs, differentials and X-fer case fluid at 30k miles. Also, check your air filter and change your cabin air filter. I plan on changing the transmission fluid for the first time at 60k miles.
    Also, why was your truck on the alignment rack? I have a hard time believing they would put it on the alignment rack if you had no intention of getting the truck aligned.
  10. Nov 4, 2011 at 1:44 PM
    Tacoma Mike
    Southern Maine
    Some places you would lose your job if you didn't.......
  11. Nov 4, 2011 at 1:45 PM
    TmecTaco79
    TmecTaco79 Well-Known Member
    Adam
    Escondido,CA
    06 TRD PreRunner 4x2
    Bilstein 5100's, 33" BFG AT, Magnaflow
    Lol how would you have carbon build up in the throttle body and injectors? Sounds like bs. Start a new one up at the dealer and see if yours idles a lot differently. Did they do any sampling too to determine that your oils were crap? But the diff you can easily do in your garage.
  12. Nov 4, 2011 at 2:02 PM
    Toyota Tech31
    Debary, Florida
    I know, but not around here, i wouldnt want to work for a shop that made it's techs do that kind of crap, i have always said, "if i wouldnt sell it to my mom, i wont sell it to you!"
    My dealer believes strongly in techs talking to customers, but if they caught me scaring a customer, i would truely be in some shit, thats our rep, its why we have return business. You know that.
  13. Nov 4, 2011 at 5:11 PM
    Tacoma Mike
    Southern Maine
    YEUP :thumbsup:
  14. Nov 4, 2011 at 5:17 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    +1 for you
  15. Nov 4, 2011 at 6:13 PM
    gunnyz39
    Shawn
    Albuquerque, NM
    Tacoma TRD 4x4
    Yea, I'm right at 60,000 miles. They printed a big list of to do's. It sounded off to me as well, I told them to pound sound. Local Toyota dealership. It's 6 speed with ZERO problems. My gas mileage is roughly 16mpg in the city and roughly 18 highway.
    I appreciate the responses! And REALLY appreciate the DIY hyperlink. I'll spend some quality time with the white taco this weekend.
  16. Nov 4, 2011 at 9:29 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    There is no fuel going to the throttle body on these engines, Toyota trucks never did have TBI, and certainly not now.
    I suspect the fuel % numbers from the "tech" are duty cycle numbers for the injectors rather than pressure, higher % of duty cycle = more fuel being injected into the manifold. If the % is higher than normal for the RPM and load, it would be an indicator running rich possibly due to poor tune condition and poor fuel milage. But the CATs, not the injectors, would be the first item to suffer from the lack of maintenance, other than fuel milage.
    Service it up, tune it up (plugs, clean TB, clean MAF sensor with MAF cleaner, change the PCV valve or clean it, and go on your merry way.:)
  17. Nov 4, 2011 at 9:53 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My 2 cents.
  18. Nov 5, 2011 at 1:00 AM
    gunnyz39
    Shawn
    Albuquerque, NM
    Tacoma TRD 4x4
    Thanks! This is some good solid helpful info/insight. Unbelievable that dealerships are scamming folks! Luckily I am a decent do it myself type.
    Again, thank you to all & I hope this may help someone else along the line too.
  19. Nov 5, 2011 at 2:19 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Dealerships are hit and miss man... some are good, some are junk. In massachusetts, I wanted to strangle the service manager. Here in Roseville, I plan on puttin in a good word to the owners for the service tech and reps jobs in my recent debockle.
  20. Nov 5, 2011 at 2:24 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    My old standby on 4x4 maintenance is a five gallon bucket of gear lube with a pump lid...change all your gear box fluids in hour. Get a can of intake manifold cleaner and some techtron for the gas. No worries mon.
    Power steering fluid should be low viscosity.
    Howard
