Bump Stops.. Need help
Discussion in 'Suspension' started by teddygrahams, Jun 10, 2010.
  1. Jun 10, 2010 at 7:12 PM
    teddygrahams
    teddygrahams [OP] Well-Known Member
    Im trying to install some bump stops on my taco. I have a few questions. they are 2.0 fox 4" stops.
    1st) does it matter if the bump stop is compressed while the truck is static
    2nd) Is it necessary to utilize all of the bump stop -- meaning removing the original poly stoppers (obviously its going to be better, but thats not what im asking). So is it a progressive dampening system? Does the last little remainder of the bump stop make the difference or having a poly stopper before the hydraulic bump stop maxes out.
    Details on why would be awesome. Im looking to maximize the bump stop. THanks
  2. Jun 11, 2010 at 7:47 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    whoa, where are you going to mount air bumps? front/ rear?
    these things dont just mount up and your good to go...
  3. Jun 11, 2010 at 7:50 AM
    mjp2
    Milton Juevos Portimous II
    NJ
    '06 TRD Access Cab, v6, 6-speed
    Scaffolding and a painted grill
    x2. We need details, man.
    4" is for use in the rear and not the front. Up front you'll want to run 2" or 2.5" travel air bumps, and you definitely don't want to be riding on the bumps at static height.
    What year is your truck and what other components are you running? Are you doing the welding/fabrication to mount these or someone else?
  4. Jun 11, 2010 at 8:01 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    haha, this was way more advanced than the title suggested.
  5. Jun 11, 2010 at 1:11 PM
    teddygrahams
    im planning to mount them myself. A lot of what ive seen, people place them at static height right before the spring compress. So the stop is just touching the arm at static.
    as far as the 2" vs 4". ive seen plenty of people using 4" in the front.
    So do any of you know if this is a progressive dampening system?
    Meaning they get harder to compress the further the compress, and is the rebound to strenuous for them to be compressed at riding height.
  6. Jun 11, 2010 at 1:13 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    *waiting for mike to respond*
  7. Jun 11, 2010 at 1:17 PM
    mjp2
    NJ
    The front suspension travel is non-linear, so a 2.5" travel bumpstop will kick in for the last 5" or so of compression. A 4" travel bump will impact compression at all but full droop if it's mounted to bottom out at the same point as the coilover.
    I guess it'd be progressive in as much as the nitrogen charge gets compressed in the cylinder. Best to call the manufacturer for specific information.
    Pics?
  8. Jun 11, 2010 at 1:18 PM
    mjp2
    NJ
    x2
    That Mike guy's a jerk. :p
  9. Jun 12, 2010 at 12:49 PM
    teddygrahams
    depending on where you mount the stopper is where its going to kick in, further out near the wheel or near the joint of the arm... but i talked to some people and riding on them is fine. So if the stop is compressed while stack its fine it will just be kinda of stiff. and the stoppers are not progressive. So using 2" of a 4" bump stop is the same as using all the travel on a 2" bump stop..
    Thanks for the info fellers
