bump stops
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bigguy78619, Jul 10, 2008.
  1. Jul 10, 2008 at 11:52 AM
    bigguy78619
    bigguy78619 [OP] Well-Known Member
    san diego, ca
    07 TRD Off-Road PreRunner DC
    anyone know about these bump stops called "joust bumpstops" i belive!? supposilby they are there bolt on kind, no fabrication needed.
  2. Jul 10, 2008 at 12:07 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Jounce Shocks, and they are awesome. Light Racing makes a great product.
    You'll have to cut the existing front bumpstop bracket but it's a piece of cake. Pull your coil-over so you can fit your tools in there and drill holes where needed. It's time consuming but not difficult.
    As for the rears, drill out the 4 frame rivets on each side of the truck and bolt in the jounce shocks. You'll have to loosen the leaf spring u-bolts to add the strike plate but that's not a big deal. Just make sure you soak the nuts with a penetrating lubricant to make them easier to loosen.
    I bought mine on Ebay and got a sweet deal. Around $1200 shipped for the all four corners.
  3. Jul 10, 2008 at 12:19 PM
    mjp2
    NJ
    What rear suspension are you running? FYI, these things require some fabrication to work with AllPro's u-bolt flip kit
  4. Jul 10, 2008 at 1:50 PM
    bigguy78619
    san diego, ca
    yeah those are the ones i was talking about, its very minor fabrication almost bolt on...i love this site everyone is always on the ball.....thanks!
  5. Jun 25, 2023 at 11:26 AM
    Lit 4x4
    Lit 4x4 New Member
    Austin
    2013 Silver Tacoma 4x4
    Tuned Fox performance elite series shocks front and back
    Are these stock lower arms?
  6. Jun 25, 2023 at 2:27 PM
    mjp2
    NJ
    That was a looooong time ago but yes those were the stock lowers with skidplates bolted to them.
    Lit 4x4 likes this.
