Bumper blues
Discussion in '1st Gen. Tacomas (1995-2004)' started by lennys, Sep 20, 2011.
  1. Sep 20, 2011 at 6:03 PM
    lennys
    lennys [OP] Well-Known Member
    Buena Park Hills Ca.
    02 Tacoma 4x4
    Put my Elite bumper on today (without winch) and It dropped the ft end 1/4" the stock bumper is 32lb the Elite is 100lb with my light bar and lights,put a smity built 8k winch on that adds another 80lb...............What did you guys do to get your ride height back?????????????:eek:
  2. Sep 20, 2011 at 6:05 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    i dealt with it... realigned it and went with it... i didnt want top make my cv angles any worse. it made them better:)
  3. Sep 20, 2011 at 6:05 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Stiffer springs. 883's maybe.
  4. Sep 20, 2011 at 6:06 PM
    lennys
    02 Tacoma 4x4
    882 are stronger then 883
  5. Sep 20, 2011 at 6:07 PM
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    my elite and winch didnt do a thing to my toytec ultimate i thought it would so know i have to crank the coilovers down
  6. Sep 20, 2011 at 6:08 PM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Oh didn't notice the 882's.
  7. Sep 20, 2011 at 6:46 PM
    lennys
    02 Tacoma 4x4
    When I put the OME kit on with the 882 they sagged alittle over a 1/4" so I put a 1/4" spacer from toytec in and its been fine,toytec has a 1/2 spacer has anyone did this????????????
  8. Sep 20, 2011 at 6:58 PM
    sander1036
    I would say thats a good plan... you would just have to deal with the sag from the weight of the winch then
  9. Sep 20, 2011 at 7:01 PM
    lennys
    02 Tacoma 4x4
    Im thinking of just putting the stock bumper back on.
  10. Sep 20, 2011 at 7:07 PM
    Pope953
    Pope953 That's a fact Jack!
    Wesley
    Asheville, NC
    SR5 Pickup
    35% up front, 20% in the back window tint, 15" Mickey Thompson bullet hole wheels, with 31x10.5 Firestone Destination A/T tires. Glass Pack, High Flow Cat, S&B CAI, Custom Light Bar with 4 fog lights. 2 10" Rockford Fosgate P2 subs with 1000 watt Rockford Fosgate Amp, CB.
    Pictures of your truck with the bumper on with the sag?
  11. Sep 20, 2011 at 7:14 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    its a 1/4'' kinda negligible IMO. Not worth taking the bumper off.
  12. Sep 20, 2011 at 7:39 PM
    lennys
    02 Tacoma 4x4
    The only reason I put the bumper on was for the winch and I really dont want to screw with my setup,if 68lbs droped it a 1/4" the 88lb winch is going to kill it and will the 882 keep sagging????
  13. Sep 20, 2011 at 7:40 PM
    TacoMX
    Jonathan
    Deltona, Florida
    oh, I misread. I thought you already put on the winch...my bad. Maybe sell the elite bumper and buy a tube bumper? Then again, with the winch you may be only sagging 1/2-3/4'' Maybe just see if it makes a noticeable difference?
  14. Sep 20, 2011 at 7:41 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    my Eibach 5100 handles it nicely
  15. Sep 20, 2011 at 7:43 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    Ill be running Nitrochargers w/882's & the 10mm Trim packer. Hopefully i'll fit 33's.
  16. Sep 20, 2011 at 7:50 PM
    lennys
    02 Tacoma 4x4
    what sping rate
  17. Sep 20, 2011 at 7:53 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    If mine still sags ill be dealing with it until I save enought to get ICON's
  18. Sep 20, 2011 at 8:45 PM
    Blue
    Dylan
    Sierras
    620. I just have an Elite bumper in the front. Not sure how it will handle the winch if/when I get one
  19. Sep 20, 2011 at 10:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    One thing you can do is get rid of that wire rope and go with a synthetic line. Its safer and will weigh about 25# less.
    I had a net gain of 130# over stock. That's with the Elite bumper and winch. My XRC8 only weighed 60# with synthetic rope. I've also added BudBuilt skids, neat gain of another 100#.
    The SAWs with 650# Eibach coils are handling the weight pretty good.
  20. Sep 21, 2011 at 5:51 AM
    lennys
    02 Tacoma 4x4
    thanks for the info
