Sandblasting Rims - What media to use
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kwe1982, Aug 20, 2020.
  1. Aug 20, 2020 at 1:52 PM
    Kwe1982
    Kwe1982 [OP] Well-Known Member
    Wisconsin
    Gone - Just a couple Tundras and a Sequoia
    Got another one for the group, I've got an old set of rims I'm looking to clean up and repaint.
    I found a post somewhere on another forum on rim refinishing that said you shouldn't use sand as a blasting media on aluminum rims, it said to use aluminum oxide.
    @turbodb I know you've done this, or if anyone else has any comments on what to use.
    Thanks
    Ken
  2. Aug 20, 2020 at 2:00 PM
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    I just sanded by hand using the superfine purple sanding pads. First degreaser, then cleaning, sanding and painting. I went from aluminum color to gunmetal. Mine turned out great.
    F5-E8-C9-A0-EFD4-4684-A51-A-63-FA9-E0-E4_9a1c5348b7b243af604e0cd23cb40021e1bda6d5.jpg
  3. Aug 20, 2020 at 2:02 PM
    dangeroso
    Jon
    Dallas, TX
  4. Aug 20, 2020 at 2:06 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I just used play sand from Home Depot. $5 for a ~50lb bag. Then, I used some window screen I had around to filter out the larger grains and I ended up with material that was perfect for blasting. Was it "technically" the right thing to use? No idea. But it worked amazingly well, and the wheels still look like the day I painted them... well, except for the rock rash.
    Wheel Makeover - Extreme Labor for a Totally Non-Functional Mod
    tony2018 and dangeroso like this.
  5. Aug 20, 2020 at 2:13 PM
    Kwe1982
    Wisconsin
    Both look great, mine are in a little rougher shape, so I can't just sand them.
    I'll probably just use sand then, its not like its a show truck.
    Now I need to decide on a color, bronze or black.
    dangeroso likes this.
  6. Aug 20, 2020 at 2:14 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    great job!
    dangeroso[QUOTED] likes this.
  7. Aug 20, 2020 at 2:15 PM
    MemphisTaco
    MemphisTaco Well-Known Member
    Cody
    Nashville TN
    2018 TRD offroad Tacoma
    Kings 2.5 front/rear, ICON RXT, RR2-s, 285/75/17 KO2
    What color is your truck?
  8. Aug 20, 2020 at 2:44 PM
    Kwe1982
    Wisconsin
    Silver, black is pretty neutral, dark bronze is a maybe
  9. Aug 20, 2020 at 3:08 PM
    MemphisTaco
    Cody
    Nashville TN
    Bronze may look pretty sharp.
  10. Sep 12, 2020 at 3:51 PM
    Kwe1982
    Wisconsin
    Went with sand, tried the aluminum oxide, the powercoating they use is really tough stuff, I gave up, so I took them to a local guy.
    75.00 was worth it.
    Another note.
    That self etching primer goes on real thin, jeepers.
    My plan is to let the primer sit a week them have the tires put on, touch up any marred up areas, then mask it off paint then clear.
    hopefully it works out well.
    Weejub and Steves104x4 like this.
  11. Sep 12, 2020 at 3:54 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    A guy near me uses glass. Gets the broken up glass pieces from the dump and blasts with that.
  12. Sep 12, 2020 at 4:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    His wife must be pleased
  13. Sep 12, 2020 at 4:17 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    If you're replying to me, it's his business so I don't I think she cares :D
    Steves104x4[QUOTED] likes this.
  14. Sep 12, 2020 at 4:20 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Ya. If I started carting home broken glass my wife would not be pleased but go Man, go! Here’s a pic of my rims blasted with Tick Turds from the local SPCA then primed green8B10E3D9-81B6-427E-9FC9-955FDE5D8078.jpgand painted silverB7187ABA-8AA6-44CF-8941-4FF067E59E74.jpg I’m sorry... watching Smokey and the Bandit; that Buford T Justice is a rip!
  15. Sep 12, 2020 at 4:22 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Garnet or Starblast are both good options
    Kwe1982[OP] likes this.
