bumper compatibility
Discussion in '1st Gen. Tacomas (1995-2004)' started by dud122, Oct 31, 2009.
  1. Oct 31, 2009 at 12:48 PM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    some of you may have seen the bumper i was selling and i have a question about it.
    it was built for my 02 tacoma and someone with an 00 tacoma wants to buy it.
    the way it was supposed to mount to my truck was via a new cross member that was to be welded between the ends of the frame in the front. and then the bumper would bolt to that.
    my question is... is the frame of an 02 tacoma the same as an 00 tacoma? at least the distance between the ends of the frame?
    anyone have any reason to believe this wouldn't work on an 00 taco?
    thanks
  2. Oct 31, 2009 at 12:54 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    it SHOULD work
  3. Oct 31, 2009 at 3:47 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    any other thoughts?
  4. Nov 1, 2009 at 8:43 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    If I recall correctly the lateral distance between the frame rail ends is the same for both 1998 - 2000 and 2001 - 2004 generations. However, the length of the rail ends (longitudinally; relative to the front) are not the same. As a result, bumper fitment is not the same between these two generations.
  5. Nov 1, 2009 at 8:44 AM
    JimBeam
    JB
    2015 Tundra
    right...but with this being a weld in cross member...it could be welded at the distance necessary for a proper fit regardless of year as long as its 98-04
  6. Nov 1, 2009 at 12:19 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    right... the way i was told to mount the bumper was to align it on the truck the way i wanted with the cross member bolted on. once it was where i wanted mark where the cross member was, detatch it from the bumper, weld it on, then mount the bumper back on.
    so as long as the frame rails are long enough to allow some wiggle room to line up the bumper i think it should be fine.
  7. Nov 1, 2009 at 12:28 PM
    JimBeam
    JB
    2015 Tundra
  8. Nov 1, 2009 at 12:36 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    thanks man
