===>BUMPERS<=== - 2nd Gens Only
Discussion in 'Armor' started by theduck911, Jul 2, 2011.
  1. Jun 11, 2013 at 3:42 PM
    #721
    fjfar80
    fjfar80 Well-Known Member
    Mark
    Fairfax, Virginia
    '09 TRD OR DC
    Total Chaos UCA's, King Coilover Front Suspension w/ Remote Reservoir Shocks, King / OME Dakar Rear Suspension with Remote Reservoir Shocks, DO Front Bumper, BruteForce Custom Rear Bumper, Slee Offroad Sliders, Warn w/synthetic line, Softopper, etc.
    Prior to owning my 2009 double cab TRD Off Road Tacoma, I owned a 1997 FZJ80 Land Cruiser. The Land Cruiser was heavily modified and I loved it, especially the custom rear bumper. The rear bumper was designed with dual swing-outs and was built by Iron Pig Offroad with some 4x4 Labs parts. When I purchased my Tacoma I knew that I would eventually want a similar bumper on the Tacoma. I spent the last few years looking at rear bumper options and nothing really struck my fancy. So, I eventually talked with Billy from Brute Force Fabrication and he offered to build me a custom bumper based on design cues from me and pictures of my FZJ80 bumper. The masterpiece below is that bumper. The bumper is a high clearance / dual swing-out design with rear bed protection in the form of slightly flared DOM tubing. It has integrated recovery points and a hidden tow-hitch. The dual swing-outs can hold the 33” spare, two Jerry cans, and a Hi-Lift (currently not mounted). The high clearance design required cutting the bed. I cut the bed by running a tape line to the wheel well using blue painters tape. The bed was then cut using both an electric cut-off and pneumatic cut-off tool. After the metal was cut to the desired specification (using the Mach 1 eyeball); I used a Dremel with different bits to debur and radius the edges. Once they were smooth I painted them (inside and out) with Rust-Oleum Truck Bed Coating Spray. I then followed that up with actual semi-gloss black Rust-Oleum Protective Enamel from a half-pint can. The installation was pretty easy and everything went together – including the factory tow-plug and license plate lights perfectly. The bumper is extremely well built and I opted to paint the bumper fully using Rust-Oleum Automotive Sandable Primer followed by numerous coats of flat black Rust-Oleum Protective Enamel from the infamous rattle can. I did this so I can quickly and easily touch-up any scrapes gathered while playing in rocks or in the woods. I actually use my truck and wanted to avoid powder coating the rear bumper; which, from my experience gets dragged over rocks a lot more than the front bumper. None the less, enjoy the pictures. The installation took 2 days – partly because of the rain and partly because I am anal and pretty detail focused. If you want an awesome bumper call Billy and ask for the "Mark Special".
    - Mark
  2. Jun 11, 2013 at 3:53 PM
    #722
    ffdawson
    ffdawson Dirt Head
    Penngrove
    08 Tacoma Rugged Trail 6spd
    Kings, Armor, big taaaarrrs
    Looks great! Just curious, any reason the spare's on the drivers side vs the passenger side?
  3. Jun 11, 2013 at 3:56 PM
    #723
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
  4. Jun 11, 2013 at 4:06 PM
    #724
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    that BF bumper looks so sick!!!
  5. Jun 11, 2013 at 5:59 PM
    #725
    fjfar80
    Mark
    Fairfax, Virginia
    '09 TRD OR DC
    Visibility, I have good visibility through the driver side rear view mirror and I can look passenger side through the back since the gas cans are below the tailgate sight line. It works for me...I'm also really light so the tire and wheel combo helps balance things out.
    - Mark
  6. Jun 11, 2013 at 7:50 PM
    #726
    Thedarkight
    Thedarkight Active Member
    Oregon
    12 4x4 Black TRD
    None so far.
    Anyone in the Oregon area ever herd of NWT? I came across a craigslist ad with them selling weld together steel bumper kits. What things should i think about before purchasing a steel bumper? Are installs pretty straight forward?
  7. Jun 12, 2013 at 5:28 AM
    #727
    dmmoody
    dmmoody Active Member
    San Antonio
    '13 MGM PreRunner SR5
  8. Jun 12, 2013 at 11:29 AM
    #728
    ffdawson
    ffdawson Dirt Head
    Penngrove
  9. Jun 12, 2013 at 1:12 PM
    #729
    FMF
    FMF Well-Known Member
    Topher
    Chicago Illinois
    2013 4x4 TRD OffRoad
    SUSPENSION ARB Old Man Emu BP-51 OME Internal Bypass coil overs and rear shocks Suspension ARB Dakar one ton Rear Hi-Lux Leafs EL091 U Bolt Flip Kit Firestone Ride-Rite Air Helper Spring Daystar Universal Air Bag Cradle Wheelers Front Super Bump Stops SPC Performance Adjustable Front Upper Control Arms All-Pro 4" Steel Braided Brake Lines EBC Green Stuff Brake Pads WHEELS TIRES TRD 16-in Off-Road Beadlock-Style Alloy Wheels Bronze BFGoodrich Mud-Terrain KM2 255/85R16 with matching full size spare. ARMOR ARB Deluxe Bull Bar with Quadratec Q9500is Winch with Dyneema Synthetic Rope B.A.M.F Kick Out Rock Sliders PERFORMANCE ARB Safari Snorkel TRD Performance Exhaust System INTERIOR Clazzio Leather Seat Covers LIGHTING ARB IPF 900XS Extreme Driving Lights Rigid Industries Dually Flood Lights All interior lighting swapped to LED's AUDIO Front Doors: Rokford Fosgate p1694 6x9 Rokford Fosgate Tweeter P1T-s Back Doors: Rokford Fosgate P16 6 ½ OTHER Custom Martin Truck Bodies Aluminum Flatbed Weather Tech Window Rain Deflectors Bird Dawg Tech Extreme Deck Gadget Mount PrinSu Design Aluminum Roof Rack T6 Aluminum Devil Horn Toyota Emblem Ceramic Window Tint Bushwacker fender flares
    I finaly got a responce from a company I was looking into for there rear bumper and WOW they are a bit more expencive than what I would have thought! Whats yalls take on Kaymar bumpers?
    Below is the what the company emailed me.
    K3930 - Kaymar Rear Bar W/ twin pivots and Lights in bar - $1,725.00
    USA-TAC - Rear Bar W/ LHS tyre carrier - $2,421.00
    KITTAC - Kaymar Rear Bar W/ LHS & RHS tyre carriers - $3,045.00
    KitTAC-L-JCD - Kaymar Rear Bar W/ LHS tyre carrier and RHS double jerry can holder - $3,146.00
    KitTAC-R-JCD - Kaymar Rear Bar W/ RHS tyre carrier and LHS double jerry can holder - $3,146.00
    K0500 Mounted telescopic work light - $241.00
    Now the fine print...Prices are for a credit card sale and can be slightly lower for cash or check, Orders from Australia include shipping from Australia, but not from our Las Vegas warehouse.
    As for the specs below is a picture of the Tacoma rear bar on the OP work truck. It has a built in two hitch that accommodates the Toyota tow package and is rates at or above vehicle ability. It comes with the tow hitch, however not with the tow ball.
  10. Jun 12, 2013 at 1:58 PM
    #730
    Monster Coma
    Monster Coma Well-Known Member
    Corey
    Pittsburgh, PA/Houston, TX
    Sponsored by Mom and Dad
    For a non HC rear bumper?^^^
    F that noise
  11. Jun 12, 2013 at 2:10 PM
    #731
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Very cool Alexander!
    Best Taco in Mother Russia! :thumbsup:
  12. Jun 13, 2013 at 10:49 AM
    #732
    Ninjayota
    Ninjayota Well-Known Member
    South Texas
    2012 regular cab base 4x4
    Mb 352 wheels, 265/75/16 duratracs
    What are my options for bolt on front and rear bumpers? I'd like something that is like the hybrids I've been seeing here but I'm open to other options. Truck is a 2012 with a 2.7 so the lighter the better.
  13. Jun 13, 2013 at 1:59 PM
    #733
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    read the freaking thread man..... how much easier do you want it? should we really just spoon feed the answers into your brain?
  14. Jun 13, 2013 at 2:18 PM
    #734
    Ninjayota
    South Texas
    Thank you for your great contribution:rolleyes:.
  15. Jun 13, 2013 at 2:26 PM
    #735
    XXXX
    sKiP
    05 Prius
    I've contributed plenty here. Look at my threads. Now stop being a lazy ass
  16. Jun 13, 2013 at 2:29 PM
    #736
    Ninjayota
    South Texas
    I joined this forum since its a place to ask questions. Get over it.
  17. Jun 13, 2013 at 2:32 PM
    #737
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    He's right though. Read just the first page alone
  18. Jun 13, 2013 at 2:58 PM
    #738
    XXXX
    sKiP
    05 Prius
    If you have a technical question regarding relentless or arb let me know and ill give great info. If you want to know what bolts on do some reading, see what you like, narrow it down, and come back with questions. At least you didn't start a thread so ill give you props on that.
  19. Jun 13, 2013 at 3:02 PM
    #739
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    :thumbsup:
  20. Jun 13, 2013 at 3:57 PM
    #740
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    yep
