bumpstop size
Discussion in 'Suspension' started by gordi, Feb 15, 2016.
  1. Feb 15, 2016 at 11:39 AM
    gordi
    gordi [OP] Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    what size bumpstop do i need for a 1.5aal on a tsb 4 leaf pack? is a 4.5inch one too much?
  2. Feb 15, 2016 at 12:07 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Is the overload leaf going to be retained? Need more info.
  3. Feb 15, 2016 at 12:13 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    When I swap to dakars probably not keeping the aal as I won't have a plate rear or bed rack/tent. But I want it to be at around 2.5lift in the rear.
  4. Feb 15, 2016 at 12:36 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Okay. And how big of a bump stop are you looking to get? What brand? Do you have a link to the bump stop if you don't know?
    Oh and what size shock are you looking to get? What is the stroke? What brand, and what is the part number? It's all relevant.
  5. Feb 15, 2016 at 1:01 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    http://www.amazon.com/Energy-Suspen..._UL160_SR160,160_&refRID=1921Y3SPQNQS6FV50SQC
    this bump stop for a top down bump stop with regular dakars and the toytec u bolt flip kit. Was thinking the extended bilstein 5100 for a 3-4inch lift, i think is a 11inch stroke.
  6. Feb 15, 2016 at 1:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No. Get the GM Silverado polyfoam progressive bump stoppers PN 15712438 they are cheap and easily obtainable at any local GM, Chevy dealer. Add a stack of thick washers as your spacers to acheive the additional .5" of spacing that you desire. To reach 4.5 inches. It will give you a total of 3" of useable bump before bottoming out. They feel like pillows. You have no idea they are even hitting.
    Mount it onto the frame portion and use your U bolt flip kit as the bump striker. 1/4 thick plating for the flip kit plates.
    Stand by so I can get information on your shocks. It is really hard to figure it out when you do not have the hardware installed on your truck as you cannot measure shock shaft heights. So you may have to install the sorings and shocks as well as the bumps first then make your measurements accordingly so I can tell you how much spacing you will need off the frame so you can utilize all of the bump travel to bottom out.
    IronPeak likes this.
  7. Feb 15, 2016 at 1:17 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    Ya im figured that was the case. I saw your thread on the Gm ones earlier. How much was it for a set? Im just piecing it all together now for everything.
  8. Feb 15, 2016 at 1:17 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    3" to 4" Rear lift, Shock Part # RCD/BE5 B110-T5
    Extended Length: 27.28"
    Collapsed Length: 16.34"
  9. Feb 15, 2016 at 1:18 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    so just shy of 11
  10. Feb 15, 2016 at 1:18 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I cannot remember. I do not run them anymore as I switched to Hydro bumps some time ago. They will be cheap and highly effective for your build, for anyone'sreally unless you like to mob down whoops and washboards at higher speeds.
  11. Feb 15, 2016 at 1:22 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    10.94" stroke to be exact.
    I'll be honest with you. I do not know how much shock shaft you will have exposed, as your overall leaf height will not only be a .5" difference from mine, but also because you will be running a shock shaft with a full .94" of additional of stroke over what I've got. You are most likely going to have to install it all first, and then at which point I'll tell you to drive it and compress the suspension some to allow it to settle then I will have you measure the shock shaft exposed on the shock at ride height, then I'll make you measure strike distance from the u bolt flip plate to the bump stop mount portion of the frame and give me those two measurements.
  12. Feb 15, 2016 at 1:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can then give you an accurate spacing value so you can properly space out the bump stops and use all of it on upstroke full travel.
  13. Feb 15, 2016 at 1:45 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    sounds good. I appreciate it all. I will revisit this post when It happens in the next few months. I will hold off on bumps for now.
  14. Feb 15, 2016 at 1:48 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Get them and drill your holes required for them. Get them set up. Once I get you the spacing numbers then you can add or remove washers if needed.
  15. Feb 15, 2016 at 1:48 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    so get the GM ones and then adjust them later when i upgrade the leafs and shocks.
  16. Feb 15, 2016 at 1:50 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes exactly. Set the up to 4.5" using necessary washers to do so then secure them using a slim profile nylock nut or lock washer/ nut combo and call it good until you can get the rest of the info required to set it right.
  17. Feb 15, 2016 at 1:56 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    thanks. I will get those taken care of.
