Burning plastic smell
Discussion in 'Technical Chat' started by jwinky, May 30, 2014.
  1. May 30, 2014 at 5:51 AM
    jwinky
    jwinky [OP] Well-Known Member
    oklahoma
    2006 Access cab 4x4 5 speed
    5100's with OME 885 coils, Wheeler's 2" AAL
    Sorry if this is the wrong place to post this but starting a week ago, I have this burning plastic smell when my ac is on. Smells like burning wires or plastic. I opened the hood and looked all around and could not see anything that looked like it would be causing the issue. I don't have a clue if this is something I should worry about or what. When I smell it, it is only when the ac is on, if I turn it off, it goes away.
    Thanks for any info you can give me.
  2. May 30, 2014 at 6:02 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
  3. May 30, 2014 at 10:51 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Look at your AC compressor clutch.
  4. May 30, 2014 at 7:11 PM
    jwinky
    oklahoma
    Thanks, I'll take a look at that tomorrow. Oddly enough, I just made the 4.5 hour drive back home and never smelt it. Possibly could be because I had the ac on low most of the trip versus it being on full blast all the time while I was in Kansas City.
  5. May 30, 2014 at 7:23 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    With that being said, it could be the fan motor resistor plug and only happen when the fan is on a certain speed. I'm not sure exactly where that is on your truck, but I have seen a couple posts recently about the connector melting.
    Is the smell in the cab or outside in the engine bay?
  6. May 30, 2014 at 9:25 PM
    jwinky
    oklahoma
    Inside the cab
  7. May 30, 2014 at 9:29 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
    Yep. Sounds like its probably what I described earlier. Until you find and fix it, make a note of what speed(s) the fan is on when you smell it and just don't use those speed(s) until you can fix it.
  8. May 30, 2014 at 9:39 PM
    o0oSHADOWo0o
    Shadow
    Va Beach
    Just a few LEDs...
  9. May 30, 2014 at 10:03 PM
    jwinky
    oklahoma
  10. May 31, 2014 at 1:00 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    My blower motor harness connection on my 2001 became black and burned once. It was causing that smell and an intermittent operation of the fan on high setting. I went to the junk yard and found a connector off of a wrecked Camry and spliced it into the good part of the harness on the truck. It fixed it...
