Burning rubber smell
Discussion in '4 Cylinder' started by rickcrna, Dec 26, 2013.
  1. Dec 26, 2013 at 10:22 AM
    rickcrna
    rickcrna [OP] Well-Known Member
    Rick
    Vancouver, WA
    '13 AC SR5 4WD I4 Auto MGM
    Nearly every time I pull into my garage after using the truck for errands I smell some kind of burned rubber odor coming from engine bay. The truck has 2800 miles on it and so I thought maybe this is more of a new engine kind of odor.
    Has anyone else experienced this odor on their trucks?
  2. Dec 26, 2013 at 11:19 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    New engines will often give off a mild plastic/rubber/chemical-type smell for the first several thousand miles until all components have been thoroughly cooked with heat cycles. The key word here is "mild." Personally I kinda like this smell.
    If the odor is strong or if you can see smoke, this is a serious issue.
  3. Dec 26, 2013 at 5:15 PM
    kylenotjon
    kylenotjon Well-Known Member
    If the smell is quite bad and you think it's something more than a break-in smell, look your engine bay over to make sure nothing is rubbing the exhaust or burnt. If you can't find anything and the smell gets worse or stays around, get it checked out.
  4. Dec 26, 2013 at 5:16 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
  5. Dec 26, 2013 at 5:18 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Sounds like typical off gassing to me. Trucks have a ton of voc's they give off. One reason why garages should be sealed from the living space.
  6. Dec 26, 2013 at 5:25 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    As long as you do not smell that...and vasoline...I think it's normal:rolleyes:
  7. Dec 26, 2013 at 8:49 PM
    rickcrna
    Rick
    Vancouver, WA
    Based on your comments, the most logical explanation is new engine break-in heat cycles. The odor is not severe and I've never seen anything unexpected in the engine bay. Was just curious about it...
  8. Dec 27, 2013 at 5:11 PM
    mrbadwrench
    mrbadwrench Well-Known Member
    Cleveland Ohio area
    2014 GMC Sierra 4x4, 1988 Mitsubishi J53
    Don't worry, that's just the scent of Toyota Quality.
  9. Dec 30, 2013 at 2:02 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    I had a question about a 'heat' issue so paid a visit to a local fire station. They took out their thermal imaging camera and it saw the issue. No charge. :) Remember, so-called electric devices are actually powered by smoke. When the seal breaks you see smoke come out. Then it is declared broken. Get it checked.
