Bussman RTMR Fuse/Relay Boxs Complete Kits and Blue Sea Mounting Plates
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Yotamac, Sep 8, 2013.
  1. Apr 19, 2015 at 5:32 AM
    #381
    4x4Taco09
    4x4Taco09 Well-Known Member
    Dane
    Louisiana
    09 TRD Sport 4x4 BSP DC LB
    Kings, Deavers, Brute Force, Prinsu, Lights, all the stuff
    Can we get this plate but with a spot for a circuit breaker as well? And this does clear the redline hood trust as well correct?
  2. Apr 19, 2015 at 10:05 AM
    #382
    Yotamac
    Yotamac [OP] Well-Known Member Vendor
    Ze
    562- Cerritos, CA
    07 PreRunner
    Stuff, stuff and more stuff
    The Med Size RTMR plate should work. Also, The double decker plate should work. PM sent
  3. Apr 19, 2015 at 10:09 AM
    #383
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Let me know what you guys figure out. I have a leg on my platform that runs down to the inner fender well for support. I believe I used the bolt and threaded hole that holds the front diff breather in place.
    I can certainly point folks your way if you have a good solution for the different configurations.
    Nathan
  4. Apr 19, 2015 at 1:00 PM
    #384
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    Thanks Nathan, PM sent
  5. Apr 19, 2015 at 1:24 PM
    #385
    skygear
    skygear                    
    That thing is huge..................................................
  6. Apr 19, 2015 at 2:16 PM
    #386
    SMKYTXN
    Nathan
    Houston
    DCFB
    The NSA switch panel is 9-3/8"L x 2"T x 6-7/8"W.
  7. Apr 19, 2015 at 3:34 PM
    #387
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    It solves my primary problem though. I had no place in the interior I was willing to hack up to install 8 switches. Plus, no waiting. It is sitting on my table ready for install. :D
    I'm considering mounting it vertically on the passenger side back towards the firewall with the cables exiting from the front for easy access. There are two threaded spots for bolts, no drilling required. It clears my hood struts and there is plenty of room. It would protrude out a little over 2" if mounted sideways.
  8. Apr 30, 2015 at 3:21 AM
    #388
    Alament92
    Alament92 Well-Known Member
    Austin
    Arizona
    2012 Tacoma TRD Sport
    HID's, Rancho quicklift, 295/75/16 Nitto Terra Grapplers, Method Race Wheels, K&N CAI, LED interior dome, map, license plate lights, 30 inch Avec LED light bar, Anti-dark hood lighting kit
  9. Apr 30, 2015 at 10:31 AM
    #389
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    PM replied:)
  10. May 3, 2015 at 3:07 PM
    #390
    euroshowoff
    euroshowoff Well-Known Member
    Stafford, VA
    15 Superwhite DCSB 4x4 V6
    Toytec lift, Trailgear sliders, CBI ditch light brackets, Trailtoys LED ditch lights, Trailtoys LED reverse pods, Custom Roll-Bar, TRD skid plate, TRD sport grill, TRD custom bedsides, Custom BlueSea wiring block, OTTRAW Rockers, Pro Comp 7036, BFGoodrich KO2s, Bestop soft topper,VIAIR 88p
    Test fit mine today, thing is solid.
  11. May 7, 2015 at 1:37 PM
    #391
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    Looks Great!!! Thanks!!!
  12. May 7, 2015 at 1:50 PM
    #392
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    has anyone tried to fit this in a 3rd gen 4runner?
  13. May 7, 2015 at 2:04 PM
    #393
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    I have sold plates to 4 runner guys too. Just need to confirm measurements when purchasing to make sure they fit properly. The engine bay varies on the same vehicles.
  14. May 7, 2015 at 2:10 PM
    #394
    ramonortiz55
    Ramon
    Texas
    stock
    do you know where they have placed it at?
  15. May 7, 2015 at 7:08 PM
    #395
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    I believe its mounted to same area. Snap a pic if you can..
  16. May 8, 2015 at 10:12 AM
    #396
    ramonortiz55
    Ramon
    Texas
    stock
  17. May 8, 2015 at 1:37 PM
    #397
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    What year is the 4 Runner? I dont know how it would work in there.
  18. May 8, 2015 at 3:36 PM
    #398
    ramonortiz55
    Ramon
    Texas
    stock
    2001 4runner
  19. May 8, 2015 at 3:40 PM
    #399
    Yotamac
    Ze
    562- Cerritos, CA
    07 PreRunner
    I think the plates were on newer 4runners. If you decide to use the RTMR box, I offer a universal plate fits in small spots.
  20. May 21, 2015 at 6:08 AM
    #400
    ramonortiz55
    Ramon
    Texas
    stock
    https://www.tacomaworld.com/threads...-rtmr-5-relay-no-blue-sea-spod.336590/page-44
    skygear made one to fit in that spot, post 863. He has the same year 4runner i do. what are the dimensions of your small skygear box mounting plate?
    https://www.tacomaworld.com/threads...-rtmr-5-relay-no-blue-sea-spod.336590/page-43
    ^^ post 856
