Busted fuel door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rango120, Sep 14, 2021.
  1. Sep 14, 2021 at 8:19 AM
    rango120
    rango120 [OP] Member
    ryan
    Sal Lake City
    2017 tacoma TRD OFF ROAD
    2" OME lift with 2021 Method wheels
    Does anyone know if you can just replace the fuel door or is that something that Toyota will take care of? My door is hanging on slightly.. I tried to buy a new one with no luck yet. Just curious what the best route would be?
    Thank you!
  2. Sep 14, 2021 at 8:51 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Seems to be a common issue. Toyota will take care of it for $$$, I'm sure.
  3. Sep 14, 2021 at 10:14 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Yep, and don't forget to periodically grease the hinges on the new one.
    beergeek likes this.
  4. Sep 14, 2021 at 10:20 AM
    Smk8609
    Smk8609 Well-Known Member
    2016 dcsb trd sport 4x4
    yup - had to bend mine back and grease the hinges. Quite a frustrating little quirk
  5. Sep 14, 2021 at 12:24 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Bertw192 likes this.
  6. Sep 14, 2021 at 12:27 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
  7. Sep 14, 2021 at 12:47 PM
    zoo truck
    None
    Unfortunately its called maintenance.
  8. Sep 14, 2021 at 1:03 PM
    Smk8609
    Maintenance not noted by Toyota - if it was included, it would be nice. Never happened on my '98 Tacoma either - luck of the draw I suppose.
  9. Sep 14, 2021 at 1:18 PM
    zoo truck
    None
    Idk if toyota tells you when your door hinges need lubricating either, but it should be done when they get sticky.
    djgynee likes this.
  10. Sep 14, 2021 at 1:27 PM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
    I hit my hinges once with white lithium years ago and it hasn’t need lubed since.
  11. Sep 14, 2021 at 1:30 PM
    Smk8609
    Touche' not disagreeing by any means - I am a pretty mechanically inclined individual and I honestly didn't even notice mine sticking until I pulled it open at the pump, went to close it and it didn't line up anymore. Luckily mine was able to be realigned and greased up!
  12. Sep 14, 2021 at 7:36 PM
    Tacomaryan18
    Tacomaryan18 Well-Known Member
    18 Ltd Dbl SB super white
    in 25 years of driving I’ve never once greased the hinge of a fuel door, nor have I had any issues with a fuel door up until this Tacoma. The Tundra before it I had for eight years and the Jeep before that ten years. It IS a frustrating little quirk.
  13. Sep 15, 2021 at 6:27 AM
    zoo truck
    None
    I had to grease the hinges on my 2001 tundra at lear once a year or it'd have issue's. Imo, you've been lucky.
  14. Sep 15, 2021 at 6:56 AM
    Tacomaryan18
    Interesting, I mean it makes sense to grease the door, I’ve just never had to or thought to and I’m pretty good about maintenance. When the dealer replaced mine under warranty they were well aware of this issue, it sounded like they do several a month. I’ve had 8 Toyota’s and several domestics and never encountered this before.
  15. Sep 15, 2021 at 1:31 PM
    zoo truck
    None
    I can't remember what i did for maintenance on my toyota pickups before i had the tundra, but i never had the need to replace a fuel door....and thats going back to the late 70's.
  16. Sep 15, 2021 at 1:44 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    To prevent your fuel door from breaking here is some advice.
    If your arm looks like this, use 1 finger to open the door because you all are opening the thing way too hard.
    j-utah likes this.
  17. Sep 15, 2021 at 7:39 PM
    rango120
    ryan
    Sal Lake City
    Appreciate all the insight friends. Any suggestions of specific lube to use?
  18. Sep 16, 2021 at 4:16 AM
    grandpawmoses
    David
    No money
    I prefer the Fluid Film spray. It seems to stay on longer than WD-40.
    (But anything is better than nothing.)
    zoo truck likes this.
  19. Sep 16, 2021 at 5:15 AM
    djgynee
    djgynee Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    What are we talking about here? His door is hanging on slightly? Like broken hinge? 2nd gen to 3rd gen sucked. 2gentje actual door just had these press plate clamps you could bend to remove door. Gen 3 is Riveted. If it’s the door itself. Drill out the old rivets and install new ones. I had to take my door off to have it sense as a sample to color match my shell. So we drilled out the rivets took the door off put new rivets on and now everything is perfect I’ve never had any issues in my entire life with any vehicle and a fuel door problem and I’ve had some beaters in my day. I’ve never heard of nor has anyone ever told me until this Thread that you have to periodically give maintenance to the fuel door how ridiculous
  20. Sep 16, 2021 at 5:18 AM
    MildWild
    MildWild Active Member
    Massachusetts
    TRD OR
    Mine was all bet out of shape for some reason, could of been due to no lubrication. i tried bending it every time i fuled up and it never sat correct. I had it replaced by the body shop associated with the local dealer. They did all the work up front after the initial visit, prime/paint ect. showed up a week later and took them about an hour to put it on, fits perfectly. Was under $200 all said and done, worth it to me for the fit and finish. as we all know we spend too much time at the gas station and it bugged me every time i filled up.
