Busted leaf springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by beachtaco, Jan 12, 2010.
  1. Jan 12, 2010 at 5:49 PM
    beachtaco
    beachtaco [OP] Member
    New York
    95 6 cyl 5 spd
    Hi, I'm new to the Tacoma forum, I just puchased a 95 extended cab 6 cyl 4x4. I've got a couple of busted leaf springs, and I'm wondering who you'd recomend in the way of venders, and if you've got any suggestions on the install. Any information would be a great help, thanks.
  2. Jan 12, 2010 at 5:54 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    check out wheelersoffroad.com,they got replacement leaf packs
  3. Jan 12, 2010 at 5:54 PM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
  4. Jan 12, 2010 at 6:00 PM
    humtaco
    humtaco Well-Known Member
    I just replaced mine recently and wasn't after extra lift, just wanted a good set of springs that could handle the occasional heavy load. I went with these:
    1995-1997 Tacoma 5 Leaf Spring Set: 459.00/pr
    From Wheelers: They give 1 1/2" lift over the stock height. I'm happy with them, still a pretty smooth ride. You may need to use different shocks to accommodate the extra lift I already had the Bilstein 5100s so it wasn't a problem for me.
    Good luck!
  5. Jan 12, 2010 at 6:09 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
  6. Jan 12, 2010 at 6:27 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    i haven't ever noticed it until you pointed it out. But something definetly doesn't look right.
  7. Jan 12, 2010 at 9:29 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    he is running a custom shackle with the leaf pack...
    stock is about 3 inches, eye to eye, this one looks about 6 inches... the longer shackle coupled with the leaf pack helps with articulation and travel, but can lift it up a bit...
  8. Jan 13, 2010 at 6:29 PM
    beachtaco
    New York
    95 6 cyl 5 spd
    Thanks for all the help, I'll let you know how I make out.
