Busted my 5100?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MxRacer190, Jul 19, 2011.
  1. Oct 19, 2011 at 1:06 PM
    #121
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    im running the rcd 3"-4" 5100's and they work great with my expo pack......bumps hit before shock tops out....
    funny thing is i was running 2"aal and 1" blocks for 2 years with stocker shockers and no problems.\
    and yes i do wheel the shit outa it
  2. Oct 19, 2011 at 8:33 PM
    #122
    joebob1319
    joebob1319 Well-Known Member
    Memphis,TN
    '08 Tacoma 4x4
    Bilstein 5100's up front at 2.5in, Toytec 1.5in AAL in rear. MB 72's, Goodyear Duratracs 285/75/16, Wet Okole seat covers.
    I've found that after lifting my truck recently with front 5100 Bilsteins set to 2.5in and installed a rear Toytec 1.5in AAL, my truck sits pretty level. I have felt my stock rear shocks top out when pulling into steep driveways. I have been looking for rear shocks and have found that that aftermarket 5100 Bilsteins for the rear are only 0.4in longer than my stock shocks so I wouldn't necessarily gain much going with them.
    Now going off the Downsouth Motorsports site shows lengths of the 5100 rears listed below in two different sizes, factory length and extended length...
    0" to 1.5" Rear Lift on NON-TSB leaf springs, Shock Part #: BE5-C478-T0
    Extended Length: 22.94"
    Collapsed Length: 14.02"
    3" to 4" Rear Lift Shock Part #: BE5-B110-T5
    Extended Length: 27.28"
    Collapsed Length: 16.34"
    Now since I know my Tacoma didn't have the TSB done on it for the rear and only adding a Toytec 1.5in rear AAL, I decided I wanted to find a shock with measurements somewhere in between the two sizes listed for the 5100 rears. Looking at the available sizes in the 5125's, they have one that looks to be perfect for 1.5" to 3" void that the 5100's don't really provide.
    Here's a list of the lengths available of the 5125's below...
    Shock Travel Extended Length Collapsed Length Mounting
    5.0" 16.50" 11.12" Eye to Eye
    6.63" 18.50" 12.03" Eye to Eye
    8.13" 21.54 13.58" Eye to Eye
    8.60" 22.50" 14.06" Eye to Eye
    9.24" 24.35" 15.11" Eye to Eye
    10.17" 25.93" 15.91" Eye to Eye
    11.0" 28.01" 17.00" Eye to Eye
    11.94" 29.70" 17.91" Eye to Eye
    14.30" 34.90" 20.75" Eye to Eye
    6.65" 18.42" 11.77" Stem to Eye
    7.62" 20.45" 12.83" Stem to Eye
    8.23" 21.50" 13.27" Stem to Eye
    I knew I wanted a shock with an extended length between 22.94 and 27.28 and a collapsed length between 14.02 and 16.34. Well the 5125 has one with 9.24" of total travel with 24.35 extended travel and 15.11 collapsed travel. It appears it would be a good length rear shock for my setup.
  3. Oct 19, 2011 at 10:58 PM
    #123
    Poffdaddy
    Poffdaddy Member
    Carlsbad, CA
    09 Tacoma 4x4 TRD Sport Long bed
    TSB, AAL, TRD Baja suspension kit, SnugTop Cab-hi shell, front tint
    That's a good point, I'll ask DSM about it tommorrow. Thanks for the help!
  4. Oct 20, 2011 at 3:02 PM
    #124
    Downsouth Motorsports Downsouth Motorsport Vendor
    Lakeside, Ca. 92040
    2017 4-Runner Dirt King Long Travel King 2.5 Coil-Over / 2.5 Bypass Front and Rear ICON Rear Upper and Lower Arms ICON Rear 2" Springs 34" x 10.50" x 17 Toyo Tires on 17" x 9" RaceLine Wheels
    Good point, BUT.....
    You need to take into account the fact that you'll need a loop to stem adapter, to make that shock work on your Tacoma. And said adapter adds approximately 1.5" to the length. So your 15.11 collapsed dimension will become 16.5-ish...the B110 shock will be shorter when collapsed, with no adapter required.
    -Marco
  5. Oct 20, 2011 at 7:19 PM
    #125
    joebob1319
    Memphis,TN
    '08 Tacoma 4x4
    Yeah that's true, I didn't take that into account. Thanks for the advise.
  6. Nov 12, 2012 at 6:20 AM
    #126
    Telkins88
    Telkins88 Well-Known Member
    Ohio
    2021 TRD Sport 4x4 Premium
    Goodyear Ultraterrain AT 265/70r17 1” front and rear lift
    I have rear TSB springs and a 1" block and I recently installed the longer 5100's. I had to make bumpstops about 3/4" longer than factory. I am very happy with the longer 5100's they have tons of droop and still compress the tires well into the fender. The shorter Bilsteins top out way too much for me.
  7. Nov 12, 2012 at 6:26 AM
    #127
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Did you have to go with longer brake lines also?
  8. Nov 13, 2012 at 5:06 AM
    #128
    Telkins88
    Ohio
    I did not install longer brake lines, I made a relocation bracket for them. I took a piece of 1 1/2" square tubing and cut it in half. So it was basically a C shape, then drilled a hole in the top and bottom. I unbolted the bracket that mounts on top the axle housing and put the new bracket in between the mount on the axle housing and the brake line bracket. I now have plenty of slack in the rear lines when flexed.
    But to answer your question you will need to either relocate your lines or buy longer ones with the longer bilstein shocks.
  9. Dec 9, 2012 at 7:29 PM
    #129
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    OP, can you report back on how the 3-4'' rcd rear 5100's are doing? do they bottom out?
  10. Dec 28, 2015 at 8:24 PM
    #130
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    What about part BIL 33-230337? These look like they don't need an adapter for the 5125 and measure 15.01″ collapsed x 24.38″ extended?
  11. Dec 30, 2015 at 10:54 AM
    #131
    yeos
    yeos OCD Member
    Moses Lake, WA
    2007 Lexus GX
    Good for the thread resurrection for me. I noticed the boot slipped off my passenger side rear 5100 last week and had to push it back down. I am running the wheelers 1.5 AAL and kept the overload in place, technically giving me 2" of lift. I only do off roading on forest roads, but this was after a trip to the ski resort. Gonna read through this thread to see what's up.
  12. Dec 30, 2015 at 11:07 AM
    #132
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I'm looking to do the same lift in the rear... just haven't decided whether I will be leaving the overload in or not. I was also glad to see this thread pop up to see what suits best.
