BUYER BEWARE: 2nd & 3rd Gen Tacoma In-Cab 120vAC 400W Anytime Power Outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Aug 2, 2019.
Thread Status:
Not open for further replies.
  1. Oct 26, 2019 at 4:04 PM
    #301
    ceo32312
    ceo32312 Active Member
    Charles
    2018 White Tacoma SR
    Will this work in an SR?
    elaudtr and KTJO 4x4[OP] like this.
  2. Oct 26, 2019 at 4:10 PM
    #302
    kwill
    kwill Well-Known Member
    Does the SR have the outlet in the bed? If so, this will work. If not, then I assume it does not have the inverter under the center console and will not work.
  3. Oct 26, 2019 at 5:12 PM
    #303
    BongoTheOneEyed
    BongoTheOneEyed Well-Known Member
    Is there an outlet out there with a dual 120 and 12v connector for the back handrest ? or would it require some kind of voltage converter of some kind ?
  4. Oct 26, 2019 at 5:18 PM
    #304
    JeffB
    JeffB Well-Known Member
    Jeff
    N.E. CT
    2017 TRD Sport
    Great option. Thanks for the URL.
  5. Oct 26, 2019 at 6:42 PM
    #305
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Tap into to the power port in the storage compartment. Yellow is positive, connect it to the red wire for the USB. White w/blk is negative, connect it to the black wire for the USB , or connect the black USB to the chassis ground next to the inverter.
    chiefjim likes this.
  6. Oct 26, 2019 at 7:01 PM
    #306
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    @KTJO 4x4 If I go this route for desk grommet outlet, can I only buy the Plug n Play harness for the $45 listed on Page 1?
    KTJO 4x4[OP] likes this.
  7. Oct 26, 2019 at 7:21 PM
    #307
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    Yes. You can do that
  8. Oct 26, 2019 at 7:23 PM
    #308
    KTJO 4x4
    Katie
    Oregon
    I would follow the link that gives the instructions on how to remove your center console and check your converter plug. If it is the same, then I don’t see why not. Worse case, you tell me it doesn’t and you send it back for a refund
    ceo32312[QUOTED] likes this.
  9. Oct 26, 2019 at 7:25 PM
    #309
    KTJO 4x4
    Katie
    Oregon
    Wow. Looks great!!!
    Jeff Dartfrog likes this.
  10. Oct 26, 2019 at 7:26 PM
    #310
    KTJO 4x4
    Katie
    Oregon
    Cigarette Lighter will work since they are right there.
  11. Oct 26, 2019 at 7:35 PM
    #311
    KTJO 4x4
    Katie
    Oregon
    Package 1 is the PNP Harness for the Inverter and then the PNP Harness for the Outlet. In order to wire up the USB you will need to tap into your cigarette lighter wires. The yellow and white wires. Yellow is positive. That goes to the orange wire. White is negative. That goes to the black wire.
  12. Oct 26, 2019 at 7:38 PM
    #312
    KTJO 4x4
    Katie
    Oregon
    You can still get it when I release them after my vendor gets them made.
    nudavinci64 and rmorse[QUOTED] like this.
  13. Oct 26, 2019 at 7:41 PM
    #313
    KTJO 4x4
    Katie
    Oregon
    Ground :)
  14. Oct 26, 2019 at 7:44 PM
    #314
    KTJO 4x4
    Katie
    Oregon
    Yes I posted a write up in this thread of my install
  15. Oct 26, 2019 at 7:51 PM
    #315
    Khoadattran
    Khoadattran Well-Known Member
    Khoa
    Thanks for the information. Love the product.
  16. Oct 27, 2019 at 3:16 PM
    #316
    fatboyfirebass
    A couple more pictures:
    I snipped off the connector for the power outlet in the storage compartments, and connected it to the wires from the USB outlet.
    Then, when I re-installed the storage compartment, I connected back to the original yellow and white w/blk wires.
    Then I put some heat shrink on it for good measure.
    After that, I tidied up the routing and re assembled the rest of the center console..
    JeffB likes this.
  17. Oct 29, 2019 at 9:31 AM
    #317
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    I've looked and can't find an answer,
    Does anyone know if a dual usb port is available, for the square holes below the AC knobs in a 13. Don't want to lose a 12v socket.
  18. Oct 29, 2019 at 10:40 AM
    #318
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    I found one on Amazon. It's actually one "data" port and one charging port. I just received it yesterday, so I don't know anything about the quality. But it's really one of the few items I've found that'll fit down there. I have an alternate solution for one USB port on the way, but I won't steer people that way until I know it fits in the center stack.
    https://www.amazon.com/gp/product/B01N12G8QY/ref=ppx_yo_dt_b_asin_title_o00_s01?ie=UTF8&psc=1
    Edit: Just realized you have a 2nd gen. So I don't know. The above are what people refer to as the Toyota short switch.
    ACEkraut likes this.
  19. Oct 29, 2019 at 11:31 AM
    #319
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    The fitment refers to the size of the charger. They offer two different sizes, one that will fit the center console of the Tacoma and one that fits the side switch holders on the Tacoma. They are standard sizes and are the same for 2nd and 3rd Gen Tacomas.
  20. Oct 29, 2019 at 11:37 AM
    #320
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Then the one I linked will work. I just got it last night and only verified fit. I know nothing else about it.
    ponts likes this.
Thread Status:
