BUYER BEWARE: 2nd & 3rd Gen Tacoma In-Cab 120vAC 400W Anytime Power Outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Aug 2, 2019.
Thread Status:
Not open for further replies.
  1. Jan 24, 2020 at 2:44 AM
    #381
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    UPDATE:
    Ok everyone...here is a look at all of the Packages for the very first time!!!!
    PACKAGES AVAILABLE TO PURCHASE SOON:
    PACKAGE 1 - “2nd & 3rd Gen IN-CAB AC 120V 400W POWER OUTLET” for those members that are not wanting to take the time to mod their own Wiring Harnesses and would rather purchase them ready to install. To qualify for this option you need to be able have the ability to remove your Center Console, as well as, a couple other parts such as the shift knob to have access to your OEM Inverter that is located directly underneath. This is where you will connect the PNP Harnesses. This is a true “Plug-N-Play” Package that will directly connect to One Brand New Toyota OEM In-Cab AC 120V 400W Power Outlet.
    This Package includes:
    1. Inverter In-Cab AC 120V 400W Anytime Power Outlet Plug-N-Play Harness w/ Red (6”) Wire Grounding Terminal
    2. In-Cab AC 120V 400W Power Outlet Plug-N-Play Wire Harness: JST 2Pin (19”) w/ Black (19”) Wire Grounding Terminal
    PRICE: $60.00 (FREE SHIPPING LOWER 48)
    PACKAGE 2 - “2nd & 3rd Gen IN-CAB AC 120V 400W POWER OUTLET” for those members that are not wanting to take the time to mod their own Wiring Harnesses and would rather purchase them ready to install. To qualify for this option you need to be able have the ability to remove your Center Console, as well as, a couple other parts such as the shift knob to have access to your OEM Inverter that is located directly underneath. This is where you will connect the PNP Harnesses. This is a true “Plug-N-Play” Package that will directly connect to Two Brand New Toyota OEM In-Cab AC 120V 400W Power Outlet (Part No. 85530-35050-C0).
    This package includes:
    1. Junction Block In-Cab AC 120V 400W Anytime Power Outlet Plug-N-Play Harness
    2. In-Cab AC 120V 400W Power Outlet Plug-N-Play Wire Harness: JST 2Pin (12”) w/ Black (12”) Wire Grounding Terminal
    *You may upgrade to 19ft Wire Harness if necessary
    3. Plug-N-Play In-Cab AC 120V 400W Power Outlet Harness: JST 2P (5ft) Extension Harness
    *You may upgrade to 10ft Extension if necessary
    PRICE: TBA (FREE SHIPPING LOWER 48)
    PACKAGE 3 - “2nd & 3rd Gen IN-CAB AC 120V 400W POWER OUTLET” for those members that are not wanting to take the time to mod their own Wiring Harnesses and would rather purchase them ready to install. To qualify for this option you need to be able have the ability to remove your Center Console, as well as, a couple other parts such as the shift knob to have access to your OEM Inverter that is located directly underneath. This is where you will connect the PNP Harnesses. This is a true “Plug-N-Play” Package that will directly connect to Three Brand New Toyota OEM In-Cab AC 120V 400W Power Outlet (Part No. 85530-35050-C0).
    2. In-Cab AC 120V 400W Power Outlet Plug-N-Play Wire Harness: JST 2Pin (12”) w/ Black (12”) Wire Grounding Terminal x 2
    3. Plug-N-Play In-Cab AC 120V 400W Power Outlet Harness: JST 2P (5ft) Extension Harness X 2
    RECOMMENDED ITEMS:
    1. AC 120V 400W Power Outlet (Part No 85530-35050-C0).
    2. Bezel Power Outlet (Part No 85536-35020).
    3. USB Power Port (Part No 00016-00225).
    4. Toyota Power Outlet Socket Assembly (Part No 85530-35100-B0)
    5. Junction Block (Part No 82671-30360)
    KC.Taco likes this.
  2. Jan 24, 2020 at 2:54 AM
    #382
    KTJO 4x4
    Katie
    Oregon
    IN-CAB 120vAC 400W ANYTIME POWER OUTLET
    PACKAGE 2
    PACKAGE 3
    SAMPLE OF PACKAGE 2
    97duc748 and KC.Taco like this.
  3. Jan 24, 2020 at 8:12 AM
    #383
    Barnitz
    Barnitz Well-Known Member
    Evan
    Ohio
    2019 Cement DCSBOR
    Ok, so I previously purchased Pkg1. I want to upgrade to Pkg2, placing the second plug up by the passenger footwell with the first plug at the back of the console.
    What parts do I need and price?
    KTJO 4x4[OP] likes this.
  4. Jan 24, 2020 at 10:07 AM
    #384
    KTJO 4x4
    Katie
    Oregon
    Give me a little bit to release the price. I will be out most of today and tomorrow. Just checking here and there, but then I’ll be back on here most likely Sunday. Quickly, first plug will be taken care of by Package 1 19” and your second plug that you are wanting to install at the passenger side kick panel should be good with a 5Ft Extension. I’m thinking the regular Package 2 will be good. You shouldn’t need to upgrade to the 19” or upgrade to the 10Ft. As for the price, I’ll have to get back to you on the one on Sunday. :thumbsup:
    Barnitz[QUOTED] likes this.
  5. Jan 24, 2020 at 10:13 AM
    #385
    Barnitz
    Evan
    Ohio
    2019 Cement DCSBOR
    Awesome thanks. I was having a hard time following your outline of the packages... will someone always have to buy Pkg 1 to make Pkg 2 work?
    Too much info between the packages thats the same.. seems like the post is longer than it needs to be.
    With my critique said.. Thank you for building these! The pkg 1 product I received looks professional and great.
    KTJO 4x4[QUOTED][OP] likes this.
  6. Jan 25, 2020 at 5:07 AM
    #386
    KTJO 4x4
    Katie
    Oregon
    That is correct. Package 1 comes first which is why I released it first and that is why I did it this way :thumbsup: Which is what I explained in the very beginning. Package 2 and Package 3 will be combination Packages that build off of Package 1 and then you have the option of the Extension Harnesses of 5ft and 10ft depending on where you are going to be installing your additional Power Outlets inside your Cab or your Truck. This was the plan from the beginning and hopefully now everyone will see how it all comes together as one Full Complete Package
  7. Jan 27, 2020 at 7:59 AM
    #387
    Barnitz
    Evan
    Ohio
    2019 Cement DCSBOR
    Do you have a diagram/picture of how pkg 2 connects to pkg 1? Im having trouble imaging where the junction block fits.
    Also, is there a link to the order for the junction box?
  8. Jan 29, 2020 at 7:42 AM
    #388
    garner2002
    garner2002 Well-Known Member
    DFW TX
    2018 TRD Pro Cavalry Blue
    KTJO,
    I would like to put (2) 120v plugs in my Tacoma.
    1. In the back of the center console
    2. Under the glove box in the passenger footwell
    What do I need to buy?
    What will it cost?
    Do I need to buy anything else?
    How do I pay you?
    Do you have instructions?
    I am having a difficult time following your post/description???
    Thanks!
    KTJO 4x4[OP] and MountainManGuy like this.
  9. Feb 12, 2020 at 6:00 AM
    #389
    garner2002
    DFW TX
    Any update?
  10. Feb 14, 2020 at 7:11 PM
    #390
    KTJO 4x4
    Katie
    Oregon
    Post #382 :thumbsup:
  11. Feb 14, 2020 at 7:19 PM
    #391
    KTJO 4x4
    Katie
    Oregon
    You would need Package 1 and Package 2. I would think that the 5ft would reach there. Just to give you an idea, when I did the mod for routing my wiring from the opener to the cigarette lighter, I routed my wiring from the passenger kick panel, down the side foot panel, across the carpet under the seat, and then up the side to where the cigarette lighter is located. That took a total of 48" of wiring. You can order on the website. I actually have not made instructions because I find this one hard to do instructions with as everyone is installing their outlets in different locations. However, I do have a link on the first post of my own install. I also have a link to how to remove panels and access this area. If you have any other questions please feel free to contact me
  12. Feb 15, 2020 at 4:33 AM
    #392
    BongoTheOneEyed
    BongoTheOneEyed Well-Known Member
    There is a Toyota OEM car cigarette 12V plug inside the counsel arm rest compartment, I think its commonly used for plugging in things like a CB or HAM radio and whatnot. Could this be re-positioned / combined with the 120v plug somehow so they are both installed outward from the back of the counsel arm rest facing the back of the cab ?
    Also, if my thinking is correct here, wouldnt that give oneself the option of both 12v and 120v plugs at the same time ?
    Separately, how many watts does that 12v plug provide compared to the 120v plug at 400 ?
  13. Feb 16, 2020 at 9:15 AM
    #393
    BigBeej
    BigBeej Well-Known Member
    Bryan
    Vista, Ca
    I have package 1 and I ordered all the toyota parts from original post with the plug and the USB dual outlet listed. My question is what do I connect the wires off the USB outlet to?
  14. Feb 16, 2020 at 9:22 AM
    #394
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Your can connect them to the power outlet in the console. See my pics in post #316.
    If you don't have one there, you can extend the wires and run them up to the power outlet under the AC controls.
  15. Feb 16, 2020 at 12:01 PM
    #395
    BigBeej
    Bryan
    Vista, Ca
    Thank you. Is there a video or instructions on how to hook up package 1? Getting the console off etc. is easy, where do I connect the red wire off the plug and the black wire off the extension?
  16. Feb 16, 2020 at 12:25 PM
    #396
    fatboyfirebass
    I have some additional out my pics in post #305.
    Tap into to the power port in the storage compartment. Yellow is positive, connect it to the red wire for the USB. White w/blk is negative, connect it to the black wire for the USB , or connect the black USB to the chassis ground next to the inverter.
  17. Feb 16, 2020 at 12:38 PM
    #397
    fatboyfirebass
    Don't know about a video but, the brown and white PNP harness will only go in 1 way. Unplug the factory harness from the inverter and put in the PNP harness between the factory harness and the inverter. Then the little black JST connector will mate to the JST plug on the other end of the harness that plugs into the back of the 110 V outlet.
    It is IMPORTANT that you connect the ground wires. The eyelets can be connected to the stamped steel bracket under one of the existing screws. If you do not connect this ground wires, the system won't work.
  18. Feb 16, 2020 at 12:57 PM
    #398
    fatboyfirebass
    Here is a picture with the wires labeled.
    stiles88 likes this.
  19. Feb 16, 2020 at 7:05 PM
    #399
    97duc748
    97duc748 Well-Known Member
    07 Tacoma
    Snugtop, lift, Prinsu Rack and lead foot.
    Pm sent. I would like two outlet set
  20. Feb 17, 2020 at 11:20 PM
    #400
    KTJO 4x4
    Katie
    Oregon
    Sounds good. Please feel free to purchase on the website. Everything has been listed on there. I will also check your PM. Thank you for your interst
Thread Status:
