BUYER BEWARE: 2nd & 3rd Gen Tacoma In-Cab 120vAC 400W Anytime Power Outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KTJO 4x4, Aug 2, 2019.
Thread Status:
Not open for further replies.
  1. Aug 27, 2019 at 11:31 PM
    #141
    KTJO 4x4
    KTJO 4x4 [OP] Well-Known Member
    Katie
    Oregon
    2017 TRD OFF-ROAD 4x4 DCSB BARCELONA RED
    Nitro 4.88 Gears OVTune 1.05 91Oct DirtyDeeds Exhaust
    I’m about to get some shut eye but I will get back to you in the morning with what all you need :)
    Black1Tacoma[QUOTED] likes this.
  2. Aug 27, 2019 at 11:35 PM
    #142
    Black1Tacoma
    Black1Tacoma #TRUKTOY
    Carlsbad
    2017 Black Tacoma TRD OffRoad 4x4
    Thanks! I am in and I’ll pay then also let me know what shipping is. 92009
    KTJO 4x4[QUOTED][OP] likes this.
  3. Aug 27, 2019 at 11:36 PM
    #143
    KTJO 4x4
    Katie
    Oregon
    I have 60 PMs that I am still sorting through. I get through 20 and then I wake up and it’s back up to 60. It will get there. If you have PMd and have followed the payment process with sending me all of your shipping information and full name, I will get everything updated that you have made your payment. I promise.
  4. Aug 27, 2019 at 11:39 PM
    #144
    Black1Tacoma
    Carlsbad
    Also does this leave the bed outlet at 400w all the time when engine is running?
  5. Aug 28, 2019 at 3:55 AM
    #145
    Pyrotech
    Pyrotech Well-Known Member
    Looks like that outlet was designed for that location.
    I can see one going in that spot passenger side along with rear center console.
  6. Aug 28, 2019 at 4:28 AM
    #146
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Thanks for the update! Nothing like a desired product to keep you busy. :)
  7. Aug 28, 2019 at 5:34 AM
    #147
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
  8. Aug 28, 2019 at 6:01 AM
    #148
    KTJO 4x4
    Katie
    Oregon
    I’ve been playing around with this and I’m thinking the only way is through the dual battery system but I’m still working on it. The only way I’ve done it in the past is ACC mode. I’d like to have this as well. Stay tuned
  9. Aug 28, 2019 at 6:05 AM
    #149
    KTJO 4x4
    Katie
    Oregon
    My plan isn’t to have a batch at all. Once I get these I will have enough to ship them all out at the same time. Everyone will get them at the same time. So everyone can pay now
    Black1Tacoma likes this.
  10. Aug 28, 2019 at 6:06 AM
    #150
    KTJO 4x4
    Katie
    Oregon
    This has made it difficult. I’m not going to lie
  11. Aug 28, 2019 at 6:07 AM
    #151
    KTJO 4x4
    Katie
    Oregon
    When someone sees that this switch is in stock can someone pm PLEASE let me monkey. It has been out of stock FOREVER!!! I plan on getting this mod but only when that switch is back in stock
  12. Aug 28, 2019 at 6:23 AM
    #152
    KTJO 4x4
    Katie
    Oregon
    UPDATE:
    I also wanted to let you guys know that I had to make an adjustment to the length of the PNP Harness for the AC Power Outlet Harness that originally was set at 12”. When I did my personal install, I have seat heaters that are installed as well under there and when you run your wires you MUST run them underneath the bracket due to the 10mm bolts that you use to anchor your Center Console down with in the middle. Otherwise, you will end up smashing your wires. Please please do not forget this step when you install this. However, when I did this, I ended up being about 5” short.
    Therefore, I extended the harness from 12” and I have decided to make them 20”. Most of you probably will not have anything here and will have it completely open so you will not have to go to the side where I had to go. However, for those that may have some things, I did not want to take that risk, so I wanted to make sure everyone was covered for this install. I think 20” should cover this location for this Power Outlet.
    Anyways, I just wanted to share my findings during testing of my install and why I like to personally install it prior to releasing first.
    NoOne, dilbert, Pyrotech and 3 others like this.
  13. Aug 28, 2019 at 9:11 AM
    #153
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Thanks a lot for the info. Are there any videos or information about doing it via the battery set up. I would prefer not to go that way if I didn’t have to but still would like to read up on it.
  14. Aug 29, 2019 at 1:58 PM
    #154
    KTJO 4x4
    Katie
    Oregon
    I actually have a diagram but before I release anything I want to wire everything up on my truck first and test it. Which I am planning to do after release and after I get all my IN-CAB OUTLETS Installed. :D Once I know it is good, I will release the Wiring Diagram and any PNP Harnesses I create for others to purchase for the REAR POWER OUTLET CONSTANT POWER ANYTIME MOD
  15. Aug 29, 2019 at 3:08 PM
    #155
    KTJO 4x4
    Katie
    Oregon
    UPDATE:
    What do you think? I wanted to do something different and I noticed the Tundras have a storage compartment here so I wanted to install something here on my Tacoma :)
    A closer look at the inside...
  16. Aug 29, 2019 at 8:48 PM
    #156
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Tell me more about those bags... Do you have a source for them?
  17. Aug 30, 2019 at 12:07 AM
    #157
    KTJO 4x4
    Katie
    Oregon
  18. Aug 30, 2019 at 7:43 AM
    #158
    dilbert
    dilbert AI Member
    PNW
  19. Aug 30, 2019 at 7:56 AM
    #159
    KTJO 4x4
    Katie
    Oregon
    The even better thing is, the Taco pouches fit a variety of places perfectly in our cab. They fit in the middle console, glove box, and in our door cubbies.
    dilbert[QUOTED] likes this.
  20. Aug 30, 2019 at 9:36 AM
    #160
    crazyfingers
    Chuck
    Annapolis, MD.
    HOT DAMN !!!! Thats great to hear!!!! Thanks again
Thread Status:
